my jeep is im afraid at its end - JeepForum.com
post #1 of 9 Old 08-20-2013, 10:07 AM Thread Starter
southernbell
My idiot ex put 6 quartz too many of oil in my jeep cherokee 2005. Ive been having problems ever since. First thing was as soon as we left after he did this it started over heating and blowing white smoke. Replaced the temp sensor and it fixed the problem. Then my passanger floor board started getiing puddles in it. Cracked heater core. Hadnt fixed it yet and continued to drive it very short distances and drove it maybe a mile and it started spuddering like crazy. Pulled over and it was just acting nuts and when I got home I started messing with it and you turn it on and it just rough idles my rpms bounce from a little below one to between one and two. Check engine light came on took it to auto zone to get the code read and it said missfire in cylinder two. Changed all sparkplugs which were burnt. Changed my coil pack to cylinder two and also changed my pcv valve and now when it runs the lights in my car flicker. Wth is going on.
southernbell is offline
post #2 of 9 Old 08-20-2013, 11:19 AM
BAH101
2008 WK
Did you remove the extra oil?
2008 CRD QDII, OME HD, Pintlers wheels with 265/70/17 Goodyear Silent Armour's, Jeepinbyal UCA's. 4XGuard Front guard, Side Guard, belly guard, Matrix HC. GDE ECO Tune w/ delete.
BAH101 is offline
post #3 of 9 Old 08-20-2013, 11:38 AM
paroxysym
2007 WK
probably should drain and refill the oil- otherwise all that oil will blow a gasket at some point
2007.5 WK Laredo 4.7
OEM+
paroxysym is offline
post #4 of 9 Old 08-22-2013, 04:25 PM Thread Starter
southernbell
Did a full oil change and everything was fine other than the heater core
post #5 of 9 Old 08-23-2013, 06:09 AM
paroxysym
2007 WK
glad to hear it, make sure your next bf is a true jeep guy
OEM+
post #6 of 9 Old 08-23-2013, 11:16 AM
rsurran
One quart over is one thing, but six? Its a wonder it didn't overflow out the fill tube.
2005 WK, 5.7L, Gold, Leather
2003 TJ 4.0L Freedom Edition, Flame Red, 5 spd., CAI, Warn, stinger, Hella/KC trail lights.
Dick Surran
"When you stop contributing you are just taking up space."
rsurran is offline
post #7 of 9 Old 08-23-2013, 11:43 AM
90grandoneer
90grandoneer's Avatar
2006 WK
I can't see where the engine being overfilled would have anything to do with a cracked heater core. Probably just a coincidence, or did he do something with the cooling system since you've had two problems now?? What engine are we talking about here?
06 GCO, Dk Khaki, QDII, Flshing Hi 3rd Bk Lt, MDS "ON" Lt, Airtab Vortex Gens, Debadged, Fumoto Drain Valve, BT Catch Can, Chopped EGR Tube, SRT8 CAI, K&N Filter, Sonnax Trans Line Press Booster, SC Tuner W/Adv Trans Tune App, DS Tuner, Cust tubular hdrs w/3 in Magnaflow/Xlerator AP Exh Sys, Bilsteins, SRT Springs/Sways, Cust Eng Cvr, SRT8 frt/rear bumpers, FRI Sidewinder Cam/6.1 valvetrain, SLP 25% UD Pulley, BBK true 90mm T-Body, SOS Ign Coils w/.060 spark plug gaps, SRT Reps with 265/45&295/40X20's.
90grandoneer is offline
post #8 of 9 Old 08-25-2013, 09:52 AM Thread Starter
southernbell
He checked my oil on a incline like the idiot he was. After the oil change and temp sensor change it was fine until it over heated and I turned it off. Tur ed it on and that's wheb I got the rough idle problem. I'm just at a loss for it at this point.
post #9 of 9 Old 08-25-2013, 10:13 AM
Jeepforthewin
2010 JK Wrangler
If it overheated it may have blown a head gasket. A rough idle would make sense then. Any white smoke coming out the exhaust? I would take it to a shop and have them perform a block test. It'll test to see if you have a blown head gasket.
2010 JKU - Stock for now
2005 WK - 6" lift, 35" BFG's, a lot more (SOLD)
Jeepforthewin is offline
