My CRD elephant hose mod - JeepForum.com
post #1 of 10 Old 02-15-2014, 04:08 PM Thread Starter
caddydaddy
2007 WK
I decided to do the elephant hose mod today, but I did it a little different than most of you have. I didn't want to just vent the fumes to the air, but wanted to have the advantage of no more oil going into the turbo.
What I did was get that pre-bent hose from NAPA that was on one of the threads here, and I hooked that directly to the little heater piece. The hose then went to a hole I drilled into the side of the air box, under where the air filter is. So now, any oil will drain to the bottom of the air box, and the fumes will go through the air filter and into the engine.
I plugged the intake tube hole with a Shibby Engineering aluminum plug, then added some electrical tape around it to help make sure it stays.
2007 CRD Limited w/QDII
GDE HOT Tune, Turbo Resonator Delete
2" RC lift
195,000+ miles!
caddydaddy is offline
post #2 of 10 Old 02-15-2014, 06:40 PM
Tango.
2008 WK
FYI ...
It is good to try new things ....
"but " ... All the oil fumes will clog up your air filter real fast, and then starve the engine from air.
You will need a catch-can with a breather filter in line to run a setup like that. The air filter box is not a very good catch-can.
Tango. is offline
post #3 of 10 Old 02-15-2014, 06:43 PM
Tango.
2008 WK
plus .. heater hose will decompose from the oil.
Tango. is offline
post #4 of 10 Old 02-16-2014, 12:04 AM
Chirpz
Chirpz's Avatar
2007 WK
Interesting set up. It would not be my first choice. I would keep a very close eye on the build up of gunk in your intake box. If you service it regular, you may get away with it.
When the EHM vents to atmosphere, there is less oil exiting the system because there is no suction on it from the turbo. I never get a drip in my drive way... not even one.... and it has been well over a year.
I do get some noticeable fumes sometimes...but conditions have to be right.
I know there are fumes there all the time...but not usually enough to notice.
Keep an eye on the heater hose... it may break down as everyone says..but it will take a long time. I paid an arm and a leg to buy 1" silicone hose....good forever. But I could have bought three or four heater hoses for the same money.
The key is to never let it get blocked!
Chirpz
2007 WK CRD, Quadradrive II, OEM Tow Hitch, GDE EcoTune, DPF-Delete, 4xGuard Front, Rear, Belly Guards, Side Rails & Full Matrix, OEM Skids, EHM, Dash Duck.
Chirpz is offline
post #5 of 10 Old 02-16-2014, 10:25 AM Thread Starter
caddydaddy
2007 WK
I figure that the large volume of the air box would create very little suction, compared to the hose end being right in front of the turbo. The air box does have a drain and there is a large capacity at the bottom, so by what everyone has said with how little oil actually comes out of the hose, I'd think it'd take a long time to notice much in the bottom of the air box.
Even if it takes years to break down the hose, the worst that would happen is it would split and vent the fumes under the hood. I'll keep an eye on it.
2" RC lift
195,000+ miles!
post #6 of 10 Old 02-16-2014, 10:45 AM
BAH101
2008 WK
Nope, you will see a lot, and quickly. I did that mod and was having to pull the airbox to wash it out quite regularly. I ended up not using it.
2008 CRD QDII, OME HD, Pintlers wheels with 265/70/17 Goodyear Silent Armour's, Jeepinbyal UCA's. 4XGuard Front guard, Side Guard, belly guard, Matrix HC. GDE ECO Tune w/ delete.
BAH101 is offline
post #7 of 10 Old 02-28-2014, 10:29 AM
IIMacGyverII
2007 WK
Is the elephant mod even necessary if you have the updated black seal intake pipe? If so why?
2007 WK CRD Limited Fully Loaded. GDE Hot Tune, SWK Member 115
1996 ZJ Limited -RIP
N23 Recall Victim
IIMacGyverII is offline
post #8 of 10 Old 02-28-2014, 11:52 AM
suzieque
2008 WK
I did the same setup but with a catch can in the hose before it goes to the air box because I was getting oil in the airbox and on the air filter. Not a big deal, just a bit of a mess that you have to clean up now and then.
http://www.jeepforum.com/forum/f67/i.../#post13526923
I am very happy with my setup, no smell and no mess.
2008 WK "S" Limited bright metallic silver exterior, light graystone interior, 5 speed W5J400 transmission, June 18/2008 build, C213RE rear differential with 3.73 axle ratio, C200FE front differential with 3.73 axle ratio, 245/60R18 Goodyear Fortera tires (stock summer tires), NV245 transfer case, GT2056V turbo, 3.0L CRD (OM642.980)
suzieque is offline
post #9 of 10 Old 02-28-2014, 12:26 PM Thread Starter
caddydaddy
2007 WK
I checked the air box today, and after 600 miles, there's nothing in the bottom of the air box. The filter has a 4 inch diameter stain on it though.
2" RC lift
195,000+ miles!
post #10 of 10 Old 02-28-2014, 12:27 PM Thread Starter
caddydaddy
2007 WK
Even with the new seal, it still puts oil into the air intake system, so the intercooler, intake manifold, etc. get oil in them.
2" RC lift
195,000+ miles!
