-   WK Grand Cherokee & XK Commander Forum (http://www.jeepforum.com/forum/f67/)
-   -   My breaks suck!!! (http://www.jeepforum.com/forum/f67/my-breaks-suck-1931545/)
WKHemi57 12-27-2013 09:00 PM
I have an 05 WK.. The brakes are mushy and terrible. Is this common?? What do I need to do to remedy this problem!??
Patrick
And by the way.. I know how to spell brakes.. Autocorrect sucks!! Lol!!! :-)
Shafer57 12-27-2013 10:26 PM
Sounds like you need your brakes serviced:laugh:
No car should have "horrible, mushy" brakes.
Fluid looks good? When were your rotors, and pads done last? Last time actual brake fluid was replaced? Miles on vehicle?
WKHemi57 12-27-2013 10:34 PM
Brakes and pads look good. Fluid isn't bad at all.. I checked it all. Some seem to just be worse than others on some models of cars. I've heard from others at work that the WK and commander break packages suck. I just sold my '11 liberty and those brakes were grossly undersized. Anyone change them with slotted rotors or anything?
Kolak 12-27-2013 10:40 PM
I've sold a tremendous amount of Stillen rotors and pads for the WK over the last few years. They're a great upgrade for better stopping power, fade resistance and pedal feel. Send me a PM or email me at kolak@aol.com and I'll send you all the information - I have them on special right now too! :)
Anon155 12-27-2013 10:42 PM
Changing my pads to a higher grade ceramic helped a lot. I know many that have put new slotted rotors from Stillen or r1 concepts. I will be switching to the r1's when mine get warn down more. Kolak usually has some pretty good prices on the Stillen rotors. Add a good quite ceramic pad and you should be set!
Shafer57 12-27-2013 10:49 PM
As Kolak said, better brake pads/rotors will help. But keep in mind, these are WK's, not exactly a high-performance brake setup out of the factory (excluding SRT). It won't stop as quick as a smaller SUV like the Liberty. These bricks weigh a ton, and the best thing to do is buy good rotors and pads.
I have basic rotors (advance auto parts) and RockAuto pads (Evolution Ceramics). They work pretty well, but no doubt it could be better, but that's also hardware more than just pads and rotors. The Brembos on an SRT are crazy compared to these stock calipers. Get better rotors and pads to see if that helps, but you might have an underlying issue if they're THAT bad.
twistedlizard72 12-27-2013 10:57 PM
1 Attachment(s)
Maybe check the rubber lines and make sure none are swelling from fluid leaking between the layers of the line.
Question for Kolak, and anyone else with Stillen rotors, do the Stillen rotors have issues with warping?
caddydaddy 12-27-2013 11:29 PM
I'm a big fan of EBC brake pads. I have them on my car, SUV and motorcycle. Much better than the stock pads!
Kolak 12-28-2013 05:28 AM
No issues with warping with the Stillens - they only use the best quality one-piece cast rotor blanks.
Jeepforthewin 12-28-2013 05:51 AM
I need to get me a set here in the next few months.
WKHemi57 12-28-2013 12:47 PM
Thanks everyone!! I'm glad it's not just me that thinks the brakes suck. I mean I know this isn't a sports car and all and it's a heavy ***** but the stock ones suck balls!!
WKHemi57 12-28-2013 12:48 PM
Kolak.. I'm at work now but will send a pm shortly with my brake needs and maybe we can work something out :-)
kc2mrg 12-29-2013 08:00 AM
i have a set of thermoquiet pads and wherever rotors from advance all around on my moms WK with some DOT4 brake fluid in it and it stops on a dime
816jared 12-29-2013 08:31 AM
r1's are a solid choice, that's what I'm currently rocking on my rig. (r1 slotted/drilled + wagner thermoquiet)
very happy with the improved performance over the worn out stock setup. plus, the slotted/drilled rotors do look pretty badass.
JeepN4KC 12-29-2013 10:47 AM
Really dunno what all the fuss is about with the stock brakes on these WKs. I never found an issue with either of the WKs brakes we've had. On the '06 I swapped out the rotors and pads at around 60K miles IIRC - oe style replacements - did great. On our '07 I swapped in new oe style pads when I bought it (~53K miles) and kept the stockers until this summer (~70K miles). I put Centric rotors and Akebono pads on this go around - far less coin than Stillens - never had an issue.
I've wheeled it moderately, heavily, Offroad Parks, very steep CO trails, hauled with it, pull my XJ on a 16' tandem axle with it - no problems, no squeaking, no squishing, never had an issue stopping when I needed to.
:dunno:
The time now is 02:19 PM.
