Multi gauge/scanner for diesel jeep? - JeepForum.com
post #1 of 5 Old 07-27-2013, 06:15 AM Thread Starter
Cvincent
I actually have a 2008 mercedes ml with the same motor as some of the jeeps, i hope i am in the right sub forum....
Any mods i have found for this truck are on the jeep forums! Thank you guys!
So i am here asking for help
I have scan gauges for all my cars and it works on the ml but cannot read egts/trans temps etc
I contacted scan gauge and they said mercedes is not very forthcoming with the info they need to set up x gauges for these trucks
So my question is- does anyone know of something similar to the scan gauge/ bully dog/ aero force set ups that will work for our trucks and read egts/ trans etc?
I am not having any luck doing google searches
Thanks for any help you can offer!
Cvincent is offline
post #2 of 5 Old 08-03-2013, 12:37 PM
10Xk
2014 WK
Starscan
10Xk is offline
post #3 of 5 Old 08-03-2013, 04:30 PM
BAH101
2008 WK
Supposedly the Dashhawk can. I don't have one but there are a few on this forum who do.
2008 CRD QDII, OME HD, Pintlers wheels with 265/70/17 Goodyear Silent Armour's, Jeepinbyal UCA's. 4XGuard Front guard, Side Guard, belly guard, Matrix HC. GDE ECO Tune w/ delete.
BAH101 is offline
post #4 of 5 Old 08-04-2013, 12:17 AM
suzieque
2008 WK
Yup the dashhawk can do the cat1b1 temperature which is the temperature of the catalytic converter or diesel particulate filter - I'm not sure which. And definitely can do the transmission temperature. I suspect there is an engine temperature sensor and engine oil pressure sensor but i do not have the codes to read those.
In my opinion the autoenginuity product is the best with ghe ability go actually test sensors and actuators. http://www.autoenginuity.com/
Some Sprinter owners have bought the Ultraguage, I bought one for my car but I couldn't seem to get all the same readings as my Dashhawk when I tested the Ultraguage on the CRD.
2008 WK "S" Limited bright metallic silver exterior, light graystone interior, 5 speed W5J400 transmission, June 18/2008 build, C213RE rear differential with 3.73 axle ratio, C200FE front differential with 3.73 axle ratio, 245/60R18 Goodyear Fortera tires (stock summer tires), NV245 transfer case, GT2056V turbo, 3.0L CRD (OM642.980)
suzieque is offline
post #5 of 5 Old 08-12-2013, 03:12 AM Thread Starter
Cvincent
thanks for the info on these, i have been busy but will do research on these next week
if i get one i will post with my observations, etc
Cvincent is offline
