Mpg drop after lift - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Mpg drop after lift
SPARTAN LOCKERS are on sale BIG TIME at ROCKRIDGE 4WD!ROCK BOTTOM prices on LIFT KITS at Rockridge4wd!! WANT TO NEW JK WRANGLER GRAB BARS NOW at ROCKRIDGE4WD
Unread 06-06-2014, 09:42 AM   #1
slowurroll
2005 WK
Mpg drop after lift
Hey guys. I'm curious to know what you guys with lifts are experiencing with your mpgs. I got my ome hd in a couple days ago and noticed I am averaging about 12-12.5 versus the 14-15 i was before. I haven't even put my 265s on yet. Is this normal to drop that much?
2005 Silver WK 4.7L - Silver WK Club #33
slowurroll is offline   Reply With Quote
Unread 06-06-2014, 10:08 AM   #2
NotDamian
If you took off the air dam, it will drop it at a least 1 mpg.
NotDamian is offline   Reply With Quote
Unread 06-06-2014, 10:18 AM   #3
luckyse7ens
2010 XK Commander
I find this hard to believe
Black WK Club #152
luckyse7ens is offline   Reply With Quote
Unread 06-06-2014, 10:29 AM   #4
paroxysym
2007 WK
well you changed the aerodynamics of the vehicle so its going to drop. the addition of tires will cause another hit. done any maintenance aside from the lift lately? are you planning on adding a tuner to your jeep to adjust the speedo for the 265s? most tunes will help your gas mileage.
try it and find out... thats the concensus- you lose the airdam and you lose a bit of gas mileage.. i trimmed mine and really didnt notice a difference.
2007.5 WK Laredo 4.7
OEM+
paroxysym is offline   Reply With Quote
Unread 06-06-2014, 03:42 PM   #5
slowurroll
2005 WK
Originally Posted by paroxysym
well you changed the aerodynamics of the vehicle so its going to drop. the addition of tires will cause another hit. done any maintenance aside from the lift lately? are you planning on adding a tuner to your jeep to adjust the speedo for the 265s? most tunes will help your gas mileage. try it and find out... thats the concensus- you lose the airdam and you lose a bit of gas mileage.. i trimmed mine and really didnt notice a difference.
I realize it would change but I didn't expect a 2ish mpg drop before tires went on. I haven't. Other than I'm getting an alignment as we speak. The 265s won't be on until I get back from a two week California trip. I want a tune. But I wasn't sure i wanted to fork over the cash so soon. Can the dealership do anything about adjusting the speedo when the tires go on? I've heard people say that about the air dam. I Want to remove it but haven't yet.
Unread 06-06-2014, 06:44 PM   #6
tjkj2002
2002 KJ Liberty
More air passing under the vehicle since it was raised the less mpg's you wil, get.Yes IFS lifts increase ground clearance in the front even without adding larger tires.
tjkj2002 is offline   Reply With Quote
Unread 06-06-2014, 09:33 PM   #7
modernblueWK
I lost 1 mpg with the strut spacer, 2 mpg when i took the airdam off. These are highway numbers. I have not adjusted the speedo for the tires. I used to average 16.5 combined now im in the 13's combined, hwy/city. Im taking a trip to Denver in a few days then 900 miles around the san juans. Curious to see how it does all highway with no airdam.
2008 WK 4.7 245/70-17 Grabber AT2 - Magnflow - JBA - G2 - Steel Armadillo - MLL's
Blue WK club #4
modernblueWK is offline   Reply With Quote
Unread 06-07-2014, 08:24 AM   #8
twistedlizard72
2007 WK
I've got a 4.7L on a Superlift and 285/70's, mileage XS tune (superchips) with air dam on and have been Averaging 15.5 (EVIC) mixed city/Hwy.
Kevin K.
WANTED: Steel Armadillo Sliders/Rock rails.
twistedlizard72 is offline   Reply With Quote
Unread 06-07-2014, 07:54 PM   #9
slowurroll
2005 WK
Hm. So it sounds like maybe i am close to expected. But I feel like I'm on the low side. Superchips tune sounds like it will be in my future then.
Unread 06-07-2014, 09:51 PM   #10
816jared
2005 WK
2005 4.7L
  • OME HD
  • airdam still on
  • superchips 91 tune
  • afe CAI
  • full magnaflow exhaust
  • tire size - 255/70/18
my commute is ~30 miles with 6-8 stoplights depending on the route I take. keep the cruise control set somewhere around 72. my EVIC always shows between 18-20mpg.
2005 WK // 4.7L // OME HD // lots more
816jared is offline   Reply With Quote
Unread 06-08-2014, 02:25 PM   #11
slowurroll
2005 WK
Damn that's not bad at all. I could go for that. Sounds like I really need to get that tune.
Unread 07-03-2014, 05:50 AM   #12
danb303
2005 WK
Did any of those add dons give you a significant gain Iin mpg? I only get 18 (everything is stock right now) on the interstate so I'm curious.
Originally Posted by 816jared View Post
2005 4.7L
  • OME HD
  • airdam still on
  • afe CAI
2005 WK Limited. HEMI QDII, (OME HD lift) on order , (255/75/17 BFG's) waiting on lift!
danb303 is online now   Reply With Quote
Unread 07-03-2014, 06:50 AM   #13
IndyBlueWK
2005 WK
Mine is awful, something like 10-11 in the city and maybe 16 on the intrstate if im lucky. 2 inch lift, "still have air dam", 265's, Dynomax Cat back, Hypertech 87 tune.
Has anyone toyed around with air dam/blocker thats behind the grill. I thought about leaving this on but went with the direct air flow theroy being better....
IndyBlueWK is offline   Reply With Quote
Unread 07-03-2014, 07:58 AM   #14
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
^^^ This.
True........but I get a laugh when the whole airdam vs mpg thing gets brought up. The only way to honestly and accurately assign a 1mpg drop is to run the Jeep with and w/o the airdam for the exact same miles; exact same terrain; exact same rpms; exact same load; etc., etc.,
In otherwords, a controlled test if you will - not in the field.
~Mike~
My Build Thread WK
My Other Build Thread XJ
'01 XJ with some stuff
Sept 2013 Cherokee of the Month
'07 WK with some other stuff
~RED WK CLUB #7~
'11 KK with mostly stock stuff
'06WK our first Jeep with stock stuff - totalled and gone
JeepN4KC is online now   Reply With Quote
Unread 07-03-2014, 03:01 PM   #15
bhawks28
2009 WK
I get around 14 MPG in the city driving. I can get it up to about 18 if I cruise at 55MPH on the highway. This is with 3.7L, OME HD, 255/75/17 BFG MT, K&N intake, and hypertech programmer.
2009 Grand Cherokee Laredo 3.7L V6 QT1 | OME HD lift | 255/75/17 BFG Mud-Terrain on Moab wheels
bhawks28 is offline   Reply With Quote
