Mountain Driving - JeepForum.com
post #1 of 9 Old 10-22-2013, 01:28 PM Thread Starter
tylerd
2006 WK
Mountain Driving
Hello,
I do a lot of driving on I70 through the Rockies in Colorado. This is the first winter season I have my WK to do the drive.
Does anyone have any recommendations on performance in this driving environment? I drove up the hill yesterday and was not impressed with the rpms I was getting to hold a steady speed. Any advice?
Thank you.
tylerd is offline
post #2 of 9 Old 10-22-2013, 02:28 PM
ryann04
2008 WK
Originally Posted by tylerd View Post
Hello,
Thank you.
I don't know how bad the rockies are on your side (Colorado), but the rockies in canada are a bit extreme at times.
The WK is a blast to drive in the winter! Just be careful, I don't care if your driving a tank, ice is ice, and when you slid, AWD/4x4/etc wont save you.
Just have fun and respect the road conditions.
On another note, the jeep wk's seem to have alot of body roll (not good for winter cornering, braking, etc.) I fixed this issue with the OME HD lift. This and the WK roll-over rating isnt the finest
2008 - Jeep Grand Cherokee - 3.0L CRD - Quadra Drive II - GDE Hot-Tune - OME HD Lift Kit - OEM Full Steel Skids
Blue WK Club Member #42 // DIESEL FTW !!!! -Ryan
ryann04 is offline
post #3 of 9 Old 10-22-2013, 03:05 PM
R4TCHET
2005 WK
Originally Posted by ryann04
I don't know how bad the rockies are on your side (Colorado), but the rockies in canada are a bit extreme at times. The WK is a blast to drive in the winter! Just be careful, I don't care if your driving a tank, ice is ice, and when you slid, AWD/4x4/etc wont save you. Just have fun and respect the road conditions. On another note, the jeep wk's seem to have alot of body roll (not good for winter cornering, braking, etc.) I fixed this issue with the OME HD lift. This and the WK roll-over rating isnt the finest
I find stock with swaybar I got very little body roll compared to other SUVs, WKs have a 4 star rollover rating, now though my swaybars are off I'm lifted, and have bigger tires I get a fair amount of body roll but nothing too bad.
Sent from my Jailbroken iPhone using JeepForum
| (dark)KHAKI WK CLUB MEMBER 17 | 2005 4.7L QTII | JBA UCAs | Modified OME MD 3.5" lift | Rusty's Adj. track bar | 4XG Matrix | 285/70r17 Duratracs | 17" KMC Enduro Wheels | Rola Roof Rack | 21" Bean LED Light bar on Roof Rack | 2 12" Punch P3 Subs | Expanded Sheet Grille | SA Sliders |
R4TCHET is offline
post #4 of 9 Old 10-22-2013, 03:36 PM
ryann04
2008 WK
Jeep Grand Cherokee Found 'Fatal' In Evasive Maneuver
Jeep Grand Cherokee's failed the Evasive Maneuver, otherwise known as the "moose test".
When they turned too sharply (evasive maneuver), the front tire would bust at the bead releasing all the tires air and leaving it prone to a rollover.
I would like to clairify, my facts are said to be true for the WK2, couldnt verify if they are true for the WK as well.
This being said, its a 4x4 off road jeep BEAST, not a rally car/sports car. Drive it as such. =)
ryann04 is offline
post #5 of 9 Old 10-22-2013, 03:42 PM
tjkj2002
2002 KJ Liberty
Hello,
Thank you.
Some of those long climbs on I70 west of Denver I'm at 5200+rpm's(2nd,2nd gear),granted far from stock.It's a Jeep so drive as such.
tjkj2002 is offline
post #6 of 9 Old 10-22-2013, 04:48 PM
modette
2005 WK
I just pulled an enclosed trailer from Springs to Green Valley, UT by way of I-70....with the 5.7L I had no issues keeping the speed limit.
modette is offline
post #7 of 9 Old 10-22-2013, 07:15 PM
drrabazz
2007 WK
What engine? I drive denver-silverthorne weekly. A normally aspirated engine only makes about 70% power abover 10k feet depending on temperature. Turbo charging an engine is the only way around dropping all that power. I have a 4.7 and down shift a couple gears in Georgetown and leading up to the tunnel etc. Granted I run bigger tires with a lift so I downshift more than stock.
The hankook at tires (dynapro) im running now have done the best by far im the snow, definitely not snow tires tho.
drrabazz is offline
post #8 of 9 Old 10-22-2013, 07:20 PM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
OP -
Use the auto-stick to find the right gear.
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is offline
post #9 of 9 Old 10-22-2013, 07:58 PM
LouC
2007 WK
How is the snow/ice there in winter? I have used the General Altamax Arctic snow tires studded, with QDII it makes the WK a phenomenal snow machine.
2007 WK Limited Hemi QDII
1998 ZJ Laredo 4.0 Selectrac
LouC is offline
