Mopar 75w140... Unicorn Blood - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Mopar 75w140... Unicorn Blood
Rough Country Lift Kits and Parts!Artec July Promo - FREE STUFF, SHIRTS, & SHIPPING!PRP Seats & Harness at CCOR 706-207-4140
Unread 08-12-2014, 07:38 PM   #1
Rollin
2005 WK
I am sorry, but $33 a quart is a wee bit ridiculous. Plus the cost of the friction modifier (QDII). I have a question about my alternatives:
There are other choices in synthetic gear oil in that weight. All of them already have friction modifier in them. Do I run just the oil with the modifier, add the Mopar additive, or order non friction modified oil online and put the additive in like I would be doing if I was using the fluid made out of ground up ivory from the dealer?
I would prefer to use Royal Purple, which has a price edge on the dealer stuff by $17 a quart.
2005 WK Limited 5.7l, QDII
Imported from Detroit
Rollin is offline   Reply With Quote Quick reply to this message
Unread 08-12-2014, 08:07 PM   #2
mooninite
Royal Purple
2006 Jeep Wrangler Unlimited Rubicon
2010 Jeep Commander Limited HEMI 4X4
mooninite is offline   Reply With Quote Quick reply to this message
Unread 08-12-2014, 08:30 PM   #3
caulk04
2008 WK
Mobil 1 or Royal Purple. I don't care for Royal Purple myself, too much 'gimmickery' with the purple dye for me.
Either way, run the Mopar friction additive in those fluids as well.
08 5.7 Limited WK - Basic stuff...
caulk04 is offline   Reply With Quote Quick reply to this message
Unread 08-12-2014, 10:11 PM   #4
Supermanbaja
2008 WK
I just put lucas syn. gear oil in and no chatter.
2008 Grand Cherokee Overland Diesel, DPF Delete, Resonator Delete, Eco Tune
Supermanbaja is offline   Reply With Quote Quick reply to this message
Unread 08-12-2014, 10:15 PM   #5
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
This.
Mobil1 is much cheaper than dealer.
~Mike~
Build Thread WK
Other Build Thread XJ
September 2013/January 2015 COTM
JeepN4KC is offline   Reply With Quote Quick reply to this message
Unread 08-13-2014, 02:37 PM   #6
Fast55
2010 WK
This.
Yep, in both diffs right now. Definitely use the additive.
2010 WK Limited
Hemi, Volant, Superchips 3872, Bilstein 5100's, LED's, etc.
Fast55 is offline   Reply With Quote Quick reply to this message
Unread 08-13-2014, 04:40 PM   #7
Rollin
2005 WK
Even if the bottle says it has friction modifier in it already?
Unread 08-13-2014, 05:19 PM   #8
TurboDiesel
2008 WK
i used amsoil
2008 CRD // GDE Eco // DPF delete // 3" intercooler // OME HD // 265 dirtytracs etc.
TurboDiesel is offline   Reply With Quote Quick reply to this message
Unread 08-13-2014, 05:46 PM   #9
Fast55
2010 WK
Yes, no matter what brand of gear oil or what it says on the bottle.
2010 WK Limited
Unread 08-13-2014, 07:08 PM   #10
SSF556
2008 WK
check out Redline as well....
http://www.amazon.com/Red-Line-57104...redline+75w140
Silver WK Club Member #1
2008 CRD QT2
SSF556 is offline   Reply With Quote Quick reply to this message
Unread 08-13-2014, 07:28 PM   #11
ChrisWK
2005 WK
My differentials in the rear making noise I was using Mobil 1, I am going to get the mopar stuff. I found a place online BuymoparPartsnows.com they are selling mopar for. $19.00 a quart I need to call make sure it is the right stuff.
Limited HEMI Dark Khaki Pearl SRT8 Full Body Kit, Roof Rails,SRT8 Engine Strut Bar, Lund Rear Spoiler, MYGIG INSTALLED with LOCKPICK, Kenwood Sub,AFE Intake, Taylor Spark Plug Wires,G2 Silver Painted Brake Calipers, Billet Tech Catch Can, Addco Sway Bars Front and Rear, Eibach Lowering Springs,Xenon Volt HID Lows 6k,Chrome SRT Reps
ChrisWK is offline   Reply With Quote Quick reply to this message
Unread 08-14-2014, 08:15 AM   #12
Forcus
2005 WK
I paid $34 / bottle for the unicorn blood / leprecaun semen the first time around... then a couple hundred miles later it got tossed when I decided to have a professional shop redo my diff. Anyway some shops have a a drum of the stuff (this shop specializes in Jeeps, gear swaps, etc.). They indicated it was much cheaper than the per qt. price. So I guess what I am saying is if you don't want to compromise (I have a hard time going with an alternative without knowing it is at least equal to stock), you might be able to find an independent shop that buys drums of the stuff, and it will be cheaper. Heck they may just sell you a gallon jug if you bring your own bottle in. Just a thought.
2005 Grand Cherokee 4x4
1974 International 100 4x4
Forcus is offline   Reply With Quote Quick reply to this message
Unread 08-14-2014, 08:45 AM   #13
JeepN4KC
JeepN4KC's Avatar
It isn't compromising to use a less expensive, and likely better quality, gear oil other than generic gear oil with a Mopar sticker on the bottle. You don't change your motor oil/filter with "genuine" Mopar oil and filter do you?
It's not a bad idea to hit up a trusted shop but even they would probably upcharge you for any fluids. What did they itemize the gear oil out to when they redid your differential?
~Mike~
Build Thread WK
Unread 08-14-2014, 09:26 AM   #14
caulk04
2008 WK
...(I have a hard time going with an alternative without knowing it is at least equal to stock)...
This is why the manual states industry standards (such as API ratings/classifications) and why the shelf brands comply to them.
I'm not saying you can't use factory fluids, but if there's a readily available fluid that meets or exceeds OE specs I'm going to use it.
Unread 08-14-2014, 10:08 AM   #15
Fast55
2010 WK
Any GL-5 full synthetic is fine as long as the additive is used. There is no "factory oil" because Mopar doesn't make gear oil.
2010 WK Limited
