Monroe Load Levelers - Page 2 - JeepForum.com
post #16 of 24 Old 06-25-2013, 10:14 PM
elfirebird
2005 WK
Mine creak a little, but thats the standard rubbing of the coil against the shock body that you get with the F150 MLLs.
2005 WK Limited Deep Beryl Green Hemi QD2 - Daystar, Bilsteins and MLL - 265 70 17 Toyo AT II - Black Rock Viper Black wheels - Aq1200D + SDC2.512 = 870 watts RMS
elfirebird is offline
post #17 of 24 Old 06-26-2013, 05:52 AM
Jeepforthewin
2010 JK Wrangler
At first i thought it was the plastic peice hitting it over bumps which is was close so i cut part of it off. Went on a test drive figuring that was the fix but it still made the sound. Wasn't making contact anywhere between the Jeep and shock so i ordered another set of shocks ( Only other thing i figured could be wrong was a bad shock ) and will install them today.
2010 JKU - Stock for now
2005 WK - 6" lift, 35" BFG's, a lot more (SOLD)
Jeepforthewin is offline
post #18 of 24 Old 06-26-2013, 06:48 AM
Budasac
2005 WK
Before installing the new shocks, dis-assemble them and glue the rubber sleeves in place. Most of the time when people complain about noise with these it's caused by the spring making contact with the shock body upon compression due to the sleeve moving out of place.
Budasac is online now
post #19 of 24 Old 06-26-2013, 07:03 AM
Jeepforthewin
2010 JK Wrangler
I did that before i installed them haha. The sound is only coming from the shock on the driver side the passanger side shock is perfectly normal so my only other thought was a bad shock. Once i get the new set installed ill let you guys know what it was.
post #20 of 24 Old 06-26-2013, 07:07 AM
jevonsaj
2007 WK
Did you lube up all the bushings when you installed them? Mine were making noise at first, I also cut the plastic but it didn't help. Then I just sprayed the bushings with white lithium grease and all noise went away. I'm running the Jeep MLL's on my Hemi with 2" RC lift.
jevonsaj is offline
post #21 of 24 Old 06-26-2013, 07:33 AM
Jeepforthewin
2010 JK Wrangler
That is something i did not do. Bushings as in the eyes? Sorry if its a dumb question im still learning alot. I will give that a try once i get off work.
post #22 of 24 Old 06-26-2013, 01:40 PM
Jeepforthewin
2010 JK Wrangler
Swapped out the shock making the noise and the sound is gone now. Bad shock haha. Love the feel of these shocks!
post #23 of 24 Old 03-06-2014, 10:13 AM
ISUzj
2005 WK
Its been almost a year, still running the MLL? and still like them?
Can't wait to get started, but my wallet can......
~~~_______oooo_
~~ / ../...\...\_____\
~~[_---_____---_\-\\\\\\-\
~~~(o) )-o---(o) )-o---) )
94ZJ 5.2 Red; Rusty's 3" Coils,Skyjacker hydro's, Brush Guard, Custom Rear Bumper, Custom Roof Rack, KVG Quick Discos, 31-10.50-15's DAYTON TIMBERLINE A/T OBA 2 Gallon tank
Can't buy it? BUILD IT!! Do it cheap too cuz your in college
ISUzj is offline
post #24 of 24 Old 03-06-2014, 12:40 PM
Jeepforthewin
2010 JK Wrangler
Still running them and hate them personally, they are coming off Saturday when I install my mod SL. The rake that I had gained back from them didn't take long to disappear and the ride with them got extremely rough. Also the noise issue I was having with them came back about 2 weeks later. Never had an issue with any shock making noise on the Jeep before these, the noise has gotten quiter in the past couple months but i still notice it, passengers not so much anymore.
