Moms cherokee needs help 2006 Jeep cherokee - JeepForum.com
post #1 of 7 Old 07-09-2013, 08:20 AM Thread Starter
sethhawk1
My moons 06 grand cherokee is having an intermittent AC problem. All I know is that the blower motor well with in the mornings and more the afternoons/evenings or when hot. She lives 4 hours away so I haven't been able to touch the vehicle but she is coming down in a few days and I would like to get it fixed for her.
Please don't let mom down. Jk
Is this the blower motor?
sethhawk1 is offline
post #2 of 7 Old 07-09-2013, 10:12 AM
tom19511
2014 WK
Dont understand your question... It works then doesn't???
Tom
tom19511 is offline
post #3 of 7 Old 07-09-2013, 10:18 AM
jaysix
2006 XK Commander
It may just need the system recharged?
jaysix is offline
post #4 of 7 Old 07-09-2013, 10:57 AM Thread Starter
sethhawk1
I'm sorry damn Android Swype. The blower intermittently doesn't work. In the mornings it will work but in the evenings/afternoons it won't work. Also when its hot it won't work.
Its not a recharge issue cause the blower itself isn't blowing.
post #5 of 7 Old 07-09-2013, 12:03 PM
tom19511
2014 WK
Maybe blower motor resistor.. Search the forum for replacemnt procedure.. easy fix..
Tom
tom19511 is offline
post #6 of 7 Old 07-11-2013, 01:37 PM
JeepCares
FCA Customer Care
JeepCares's Avatar
I know the problem is intermittent and I don't know if this info will be useful or not. Just disregard if it's not. It's from the service manual.
BLOWER MOTOR OPERATION
The blower motor is used to control the velocity of air moving through the HVAC housing by spinning the blower wheel within the HVAC air inlet housing at the selected speed or, in the ATC system, at the selected or programmed speed.
On models equipped with the manual temperature control (MTC) heating-A/C system, the blower motor will operate whenever the ignition switch is in the On position and the blower motor control in any position except Off. On models equipped with the automatic temperature control (ATC) system, the blower motor will operate whenever the ignition switch is in the On position and the A/C-heater control power is turned on.
For the MTC system, blower motor speed is controlled by directing the ground path for the blower motor through the correct resistor wire to obtain the selected speed.
For the ATC system, blower motor speed is controlled by the blower motor power module which provides the blower motor with power and a path to ground. The blower motor power module also sends a blower control signal to the A/C-heater control. Using input from the blower motor control (manual mode) or sensor data (automatic mode), the A/C-heater control processes the blower control signal from the power module and sets the speed at which the blower motor will run.
The blower motor and blower wheel are factory balanced and cannot be adjusted or repaired and must be replaced as an assembly if found inoperative or damaged.
OPERATION
Possible causes of an inoperative blower motor include:
Open fuse
Inoperative blower motor resistor or power module (depending on application)
Inoperative blower motor switch
Inoperative mode control switch
Inoperative blower motor circuit wiring or wire harness connectors
JeepCares is online now
post #7 of 7 Old 07-11-2013, 01:54 PM Thread Starter
sethhawk1
Thank you
