Modified OME HD or MD coils? - Page 5 - JeepForum.com
post #61 of 124 Old 05-05-2014, 11:35 AM Thread Starter
ChiliPepperXJ
2006 WK
If you're gonna run 285s it might not be a bad idea.
Really depends on how you plan to use the rig. Aggressive wheelin will stuff the rear at some point.
Thanks man.... Are these more important for the rear I'm assuming? I noticed that Omelet put extended bumpstops on both front and rear. As of now, I don't plan on extreme wheeling.
To install longer bumpstops, the coil needs to be out correct? Not something that would be fairly easy to install after the fact if I decided I needed them?
ChiliPepperXJ is offline
post #62 of 124 Old 05-05-2014, 11:39 AM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
If you're gonna install them I'd do it when everything is broke down for lift install. Honestly, I'd skip the extended bumpstops if you're just gonna take it on dirt roads and what not.
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is offline
post #63 of 124 Old 05-05-2014, 11:53 AM Thread Starter
ChiliPepperXJ
2006 WK
Thanks man. Thinking about it, and a little searching on another forum, I found this article:
Extended Bump Stops
Figured they wont hurt to put in, and should I come to a time when I do need them, I'll be glad they are there. On another note, I have done both the front pinch weld mod, and the rear fender mod.
post #64 of 124 Old 05-06-2014, 11:23 AM
Just_Josh
Anybody hear how difficult it is to get the coil in once the spacer is in? All I know is I dread using those coil compressors!
They really aren't as scary to use as people make them out to be, used them twice now with no problems. I had to use them to compress one side after I had got the spacer installed on the other side without them. The trick is to not put the bump stop in place until you've seated the coil and that'll give you about 3" more clearance for getting the coil back in.
Just_Josh is offline
post #65 of 124 Old 05-06-2014, 08:16 PM
kdawgFL
2005 WK
Does anyone know if using 5100s up front with ome will cause axle to over droop and create any problems ?
2005 5.7L limited, 2'' BDS Lift, 255-70-17 Revo II
kdawgFL is offline
post #66 of 124 Old 05-06-2014, 08:30 PM
pancake
2005 WK
Well potentially... But we don't have an axle in the front...
Jk. You'll probably read something about a 23" mark. This is the hub to fender measurement you're gonna wanna stay under with out a superlift kit because of geometry issues. To answer your question, more specifically, it depends on your engine, winch, bumper/gaurd setup to give an accurate assessment of whether you'd be above or below that magic number. It varies jeep by jeep.
If you stay under that you won't have any problems with droop or anything I don't believe.
05 Jeep WK Laredo 4.7L QTII | K&N CAI | Flowmaster 40 | ...lift and such in planning phase...|
pancake is offline
post #67 of 124 Old 05-06-2014, 11:20 PM
hulikner
2008 WK
I think it's 23.5 but could be remembering wrong. I also was told OME HD + 5100's would put you over that mark without a lot of extra weight up front (arb bumper) but with MD's it wouldn't. The OP is using HD I think so I'm curious to see his measurements after install.
hulikner is offline
post #68 of 124 Old 05-07-2014, 06:36 AM
JeepN4KC
JeepN4KC's Avatar
Not sure what you mean by axle droop.
The way the OME lift coils work (and anything added to it for that matter) is by putting the suspension in somewhat of a "default" down travel. The spring rate is higher, causing the unibody to sit higher on top of them - this is the same as if you'd take a stock WK, jack it up 2", put jackstands under it, and let the tires (suspension) drop to the ground.
The problems encountered when modifying the spring lift include upper control arm ball joint stress, cv joint stress at the front axles (yes, we have axles in the front - 2 cv shafts), poor front driveshaft angles, rear axle alignment (trackbar) and depending on how much additional lift in the back it's possible to run into upper/lower control arm and sway connect length issues.
~Mike~
WK
XJ
JeepN4KC is offline
post #69 of 124 Old 05-07-2014, 09:52 AM Thread Starter
ChiliPepperXJ
2006 WK
Again, I am going with the OME HD all around, adjustable 5100's up front set at 0.75", and Rustys rear poly spacers for the rear.
After all this talk, it's making me kind of wish I just went with 265's and the OME HD haha or if anything just go with my current plan except use the MD coils up front. I just looked around and seemed everybody with the Hemi recommended the HD coils. Plus, I know JeepN4KC was sitting around 22.25" up front right after lift install with the HD (he is running the 4.7L). So add the 0.75" MAXIMUM that I will get out of the struts up front, plus the extra weight of my Hemi, I feel confident I'll fall under that 23" mark. If I don't right after install, I suspect things will settle out to there. Just hoping someone agrees with me so I don't change my mind on all of this madness! haha
I did purchase some RRO UCA's since I will be in there, and to eliminate a second alignment when the stockers go out. I thought I was pretty confident in the modified OME, but almost sounds like I'm getting myself into more, especially with all these different opinions.
post #70 of 124 Old 05-07-2014, 10:13 AM Thread Starter
ChiliPepperXJ
2006 WK
So talk me into sticking with my plan people!
post #71 of 124 Old 05-07-2014, 11:57 AM
Clone451
2005 WK
I got OME HD for my Hemi and I do wonder if MD might have suited better, at least for the front. On the rougher speedbumbs I sometimes find the front wheels "hanging" and wanting to "spring" from the landing. On the other hand the ride and on-road handling is much better than with the original springs.
I have no extra weight at the front.
Clone451 is offline
post #72 of 124 Old 05-07-2014, 12:12 PM Thread Starter
ChiliPepperXJ
2006 WK
You running modified OME or just the HD?
post #73 of 124 Old 05-07-2014, 03:51 PM
Clone451
2005 WK
Just the HD
Clone451 is offline
post #74 of 124 Old 05-07-2014, 04:16 PM
kdawgFL
2005 WK
I currently have the 5100s sitting in abox. but after reading about the member chadwi having problems adding the 5100s to a r.c lift I have yet to get them installed. don't understand why you can add them to the OME and not a spacer lift. If I need to swap out my front spacer for an ome setup that's what I will do
kdawgFL is offline
post #75 of 124 Old 05-07-2014, 04:46 PM Thread Starter
ChiliPepperXJ
2006 WK
Haven't read about any of those problems, maybe somebody can chiime in here regarding that. Plenty of people have run the 5100's with the OME, so I guess I'm not quite sure why it wouldn't work with the RC.
Just waiting for someone to push me over the edge and tell me to go for it
