Modified OME HD or MD coils? - Page 4 - JeepForum.com
post #46 of 124 Old 04-29-2014, 04:32 PM
BoraBora
2015 JK Wrangler
Yes I am. No complaints so far. I saved cash over the JBA ones. The JBA ones have a lot of hype, and they are great; however, the RRO aren't garbage as everyone makes them out to be. They have been revised and look strong. Don't let someone who doesn't even run them trash talk them. They are just fine.
'15 JK 2.5" lift on 35's
'06 WK 3.5" lift on 33's (Sold)
BoraBora is offline
post #47 of 124 Old 04-29-2014, 04:43 PM Thread Starter
ChiliPepperXJ
2006 WK
Thanks for the opinion man. I knew they had problems up front, but I think have long since been resolved. I'm always open to products, especially if it can save a few bucks.
ChiliPepperXJ is offline
post #48 of 124 Old 04-29-2014, 05:45 PM
eMc9002
2007 WK
Minus the wheels and tires what's a list of everything you got for the lift man?
07 WK 4.7L V8 Limited l Flowmaster 44 l Spidertrax 1.5" l JK Moab's l Black WK #137.
eMc9002 is offline
post #49 of 124 Old 04-29-2014, 08:28 PM Thread Starter
ChiliPepperXJ
2006 WK
Blistering 5100 adj struts for front, 5100 (28" extended length) shocks for rear, JKS 2001 disconnects for rear, OME HD coils front and rear, rustys adj trackbar, rustys rear 2" poly spacer, Spidertrax 1.5" wheel spacers, and just for others reading, 2014 JK Moab wheels, 285/70/17 Goodyear Duratracs
post #50 of 124 Old 04-29-2014, 08:45 PM
pancake
2005 WK
That's exactly what I want to do.... Can't wait to see it together!!
05 Jeep WK Laredo 4.7L QTII | K&N CAI | Flowmaster 40 | ...lift and such in planning phase...|
pancake is offline
post #51 of 124 Old 04-29-2014, 08:46 PM
zeprider25
2005 WK
Nice. I went with 4600 in the front with the strut spacers (5100 still back ordered) , 5100 rear, ome all around, rustys trackbar, rustys 2" spacer, and 285/70/17 maxis bighorn.
I'll get disconnects for front and back at some point and some nicer rims. Hopefully install it when I get back from California next week
zeprider25 is offline
post #52 of 124 Old 04-29-2014, 09:12 PM Thread Starter
ChiliPepperXJ
2006 WK
I'm so excited! Got tracking info on the rustys stuff and isn't supposed to be here until Monday, so that means not this weekend, but next!
Nice man! You have any pictures of it? Did you go HD or MD coils?
post #53 of 124 Old 04-29-2014, 09:20 PM
BoraBora
2015 JK Wrangler
Just a heads up, when you dial that Rusty's track bar in and adjust it to recenter your axle, add locktite or another thread locker to the nut. Mine and JeepN4KC's came loose and created a popping sound.
BoraBora is offline
post #54 of 124 Old 04-30-2014, 12:03 AM Thread Starter
ChiliPepperXJ
2006 WK
Thanks for the heads up man. I thought I seen that somewhere. Do you know how much longer than stock I need to adjust that out to?
post #55 of 124 Old 04-30-2014, 05:08 AM
Clone451
2005 WK
I just finished putting on OME shocks, struts and springs (no additional spacers). Having done the pinch weld, sadly, 285s are not an option (while they only rub lightly at full lock, they will rub a lot if the suspension is compressed and turning). Looking at 275s later today.
I thought about adding spacers but I think I need what little down-travel there is left so smaller tires it is (be looking at SL-styling later).
Clone451 is offline
post #56 of 124 Old 04-30-2014, 07:06 AM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
Depends on what your actual ride height is and how the axle sits. Best bet is trial and error really because individual results will vary.
I will tell you that a little bit goes a long way.
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is offline
post #57 of 124 Old 04-30-2014, 08:20 AM Thread Starter
ChiliPepperXJ
2006 WK
Thanks. Is this something that will be fined tuned when I take it in for an alignment after lifting?
post #58 of 124 Old 04-30-2014, 08:41 AM
JeepN4KC
JeepN4KC's Avatar
No - when you install the trackbar you set the length. The axle side (passenger) tb end is threaded. You spin it in or out depending on how your length needs to be. It is reverse thread btw, and when I did mine I had to play around with it. Set length, install, reassemble, tires back on, set on it's own weight, see how the axle sits side to side. Took a few take apart/put back together and was somewhat of a PITA but that's how I did it.
~Mike~
WK
XJ
JeepN4KC is offline
post #59 of 124 Old 05-05-2014, 10:21 AM Thread Starter
ChiliPepperXJ
2006 WK
Anybody know if I will need to add extended rear bumpstops? I've seen when people are using them, they are using PVC couplings?
post #60 of 124 Old 05-05-2014, 11:25 AM
JeepN4KC
JeepN4KC's Avatar
If you're gonna run 285s it might not be a bad idea.
Really depends on how you plan to use the rig. Aggressive wheelin will stuff the rear at some point.
~Mike~
WK
XJ
JeepN4KC is offline
