Modified OME HD or MD coils? - Page 3 - JeepForum.com
post #31 of 124 Old 04-20-2014, 10:11 AM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
Originally Posted by ChiliPepperXJ View Post
If you go with modified OME you are going to want the adj trackbar. All I need now is the trackbar, rear spacers and I'm beginning to think about getting UCA's. What are your guys opinions on that? Will I be fine on stock for awhile or should I just get them?
You'll be okay with the stock uppers and lowers.
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is offline
post #32 of 124 Old 04-20-2014, 10:24 AM Thread Starter
ChiliPepperXJ
2006 WK
good! That will let me get this done sooner... Then I will replace the stock with aftermarket. Obviously he JBA seem to be superior, anybody use the RRO? I knew they had problems at first and was wondering if they had been resolved.
Also, anybody know of a good thread or installation instructions for the OME?
ChiliPepperXJ is offline
post #33 of 124 Old 04-20-2014, 11:04 AM
zeprider25
2005 WK
I think most threads I read just recommended them, not something you need but something you'll eventually need. I got them because I have 285/70r17 that I'm going to put on and didn't know if they would rub the bolt back there and found them new in the for sale area for a great deal.
zeprider25 is offline
post #34 of 124 Old 04-20-2014, 11:32 AM
JeepN4KC
JeepN4KC's Avatar
Ah.....my bad, I was assuming you were talking about the rear control arms. Still, the front stock uppers will be good.....might eventually look to upgrade them.
~Mike~
WK
XJ
JeepN4KC is offline
post #35 of 124 Old 04-20-2014, 11:48 AM
pancake
2005 WK
I understand the whole trac bar idea, but if most of my "off-roading" is just light trails around my hunting camp and farm, and 95% just daily driving, do I need the longer sway bar links and brake line brackets or what ever or would I be fine with the stock stuff out back (with ome hd springs, and a 1.5" spacer)
05 Jeep WK Laredo 4.7L QTII | K&N CAI | Flowmaster 40 | ...lift and such in planning phase...|
pancake is offline
post #36 of 124 Old 04-23-2014, 08:50 PM
zeprider25
2005 WK
Are the extended rear sway links really needed??
post #37 of 124 Old 04-24-2014, 04:29 AM
pancake
2005 WK
x2 that's what I was asking. Especially for almost completely daily driving and some light trail riding.
pancake is offline
post #38 of 124 Old 04-24-2014, 08:18 AM Thread Starter
ChiliPepperXJ
2006 WK
From what I understand, if you are going with just the OME setup, you shouldn't need extended links; however, if you are running the modified that you will need them. Also, with the rear trackbar, it will significantly shift your axle about 0.5". I do believe some have run the modified without the trackbar, but eventually ended up installing one.
post #39 of 124 Old 04-29-2014, 10:34 AM Thread Starter
ChiliPepperXJ
2006 WK
Adj. trackbar and rear poly spacers on in route via UPS, then I will be ready!!
post #40 of 124 Old 04-29-2014, 01:43 PM
BoraBora
2015 JK Wrangler
285?
'15 JK 2.5" lift on 35's
'06 WK 3.5" lift on 33's (Sold)
BoraBora is offline
post #41 of 124 Old 04-29-2014, 01:51 PM Thread Starter
ChiliPepperXJ
2006 WK
Originally Posted by BoraBora View Post
285?
They sure are!
post #42 of 124 Old 04-29-2014, 03:04 PM
BoraBora
2015 JK Wrangler
Nice man! You'll love it!
BoraBora is offline
post #43 of 124 Old 04-29-2014, 03:10 PM Thread Starter
ChiliPepperXJ
2006 WK
I can't wait man! Are you running UCA's on your lift?
post #44 of 124 Old 04-29-2014, 03:36 PM
BoraBora
2015 JK Wrangler
I am, but it took around 3-4 months for my stock ones to wear out. That was with offroading regularly.
BoraBora is offline
post #45 of 124 Old 04-29-2014, 03:48 PM Thread Starter
ChiliPepperXJ
2006 WK
Perfect. That should let me get by for a few months before putting the UCA's on. You are running RRO correct? How do you like those?
