Modified OME HD or MD coils? - JeepForum.com
post #1 of 124 Old 04-14-2014, 05:32 PM Thread Starter
ChiliPepperXJ
2006 WK
Calling all modified OME's!!
Finishing up purchasing my lift for my WK, and purchased my coils yesterday through Kolak (he is having a sale this month by the way), and having trouble decide between MD and HD coils up front. Here is what I will be running:
285/70/17 Duratracs
2014 Rubicon takeoff's
1.5 Spidertrax wheel spacers
5100 Blistein Adj - Front (Yes, I already have them)
5125 Blistein - Rear
JKS 2001 Rear swaybar disconnects
Rustys Rear spacer
Rustys Rear Adj Trackbar
I was going to get the HD coils all around, however, Kolak mentioned I should get the MD for the front so I don't exceed that 23" hub to fender. I do have the 5.7 Hemi, and will eventually be getting armor and hidden winch up front (not too sure when). What do you guys recommend, either the HD or MD for the fronts?
ChiliPepperXJ is offline
post #2 of 124 Old 04-14-2014, 05:51 PM
eMc9002
2007 WK
Sticking around for this one, Looking to get the exact setup.
07 WK 4.7L V8 Limited l Flowmaster 44 l Spidertrax 1.5" l JK Moab's l Black WK #137.
eMc9002 is offline
post #3 of 124 Old 04-14-2014, 07:12 PM
Aclow33
2006 WK
I went with the HD coils and I like them.
06 WK-5.7L-Modified OME HD Lift-SRT8 Volant Intake-1.5 Spacers-2014 Rubicon Wheels-22" Magnaflow
Aclow33 is offline
post #4 of 124 Old 04-14-2014, 08:00 PM Thread Starter
ChiliPepperXJ
2006 WK
I may have asked you already are you running the 5100 or rustys spacers up front?
post #5 of 124 Old 04-14-2014, 09:20 PM
pancake
2005 WK
What you could do (I thought about this) is going the md route and if it's not tall ebough or you want more height, add the thin spacer on top of that.
05 Jeep WK Laredo 4.7L QTII | K&N CAI | Flowmaster 40 | ...lift and such in planning phase...|
pancake is offline
post #6 of 124 Old 04-14-2014, 09:26 PM
fafafofi
2006 WK
OME MD front w/Rustys strut spacer
OME HD rear Bilstein 5100s all around 285/70/17 Duratracs
22.5" front 21.5" rear
5.7 HEMI no armor or winch yet
fafafofi is offline
post #7 of 124 Old 04-14-2014, 09:52 PM Thread Starter
ChiliPepperXJ
2006 WK
Definitely an option. I'm trying to eliminate a spacer up front at all cost. If it wasn't tall enough with the MD coils I would try adjusting the struts to 1.00".
Looks great man. So you don't have the rustys spacer in the rear? Just the HD coil, correct?
Attachment 1263393
post #8 of 124 Old 04-14-2014, 09:53 PM Thread Starter
ChiliPepperXJ
2006 WK
Stuff is hard on my iPad haha
post #9 of 124 Old 04-15-2014, 12:43 AM
zeprider25
2005 WK
Is there anyone who makes a 1-1.5 rear spacer?
I noticed the rustys is 2 which might put you above 23
zeprider25 is offline
post #10 of 124 Old 04-15-2014, 04:14 AM
hulikner
2008 WK
I've wondered that too but couldn't figure it out. I wanted to do OME HD front and back with the .5 strut spacer in front and some kind of 1-1.5 spacer in the back. I'd like to keep the stock rake.
hulikner is offline
post #11 of 124 Old 04-15-2014, 04:36 AM
fafafofi
2006 WK
I don't have a spacer in the rear yet. You can use Rustys 2" if you put it in place of the coil isolator. This will give you 1.5". Remember to pick up an adjustable tracbar and some longer sway links too.
fafafofi is offline
post #12 of 124 Old 04-15-2014, 08:15 AM Thread Starter
ChiliPepperXJ
2006 WK
Exactly what fafafofi said, you remove the existing coil isolator and put the spacer in its place. That will make it an 1.5" higher in the rear. Still haven't made a decision on the coils. You guys are making me lean towards the HD pretty heavily!
Fafafofi, do you know, does the rear spacer go on the top or bottom of the coil?
post #13 of 124 Old 04-15-2014, 09:17 AM
fafafofi
2006 WK
Not sure. I haven't seen the spacers yet. Maybe the bottom so you can still use the bump stops up top
fafafofi is offline
post #14 of 124 Old 04-15-2014, 09:27 AM
pancake
2005 WK
I'm 90% sure they go on top like any other rear spacer
pancake is offline
post #15 of 124 Old 04-15-2014, 09:57 AM Thread Starter
ChiliPepperXJ
2006 WK
Anybody hear how difficult it is to get the coil in once the spacer is in? All I know is I dread using those coil compressors!
