Modified OME with 26" Ome shocks? - Page 2 - JeepForum.com
post #16 of 21 Old 06-19-2013, 06:24 PM Thread Starter
WieSeL
Originally Posted by jjt250 View Post
Oops made a typo, the RRO one is only 3/8" thick but they claim 9/16" lift (not sure how true that is). Either way you're not gonna notice a huge difference so you might as well just go with the cheapest one. I went with the Rusty's. Also, if you stack two, you'll need longer strut tower bolts like JeepN4KC said.
I wish someone sold 1/2 front spacers. I thought the total width of the rro spacers was 9/16 not 9/16 total lift. Bummer
WieSeL is offline
post #17 of 21 Old 06-19-2013, 06:27 PM Thread Starter
WieSeL
Your steering rack and UCA/ball joints will be screaming with that set-up. You'll also need longer strut tower bolts if you're gonna stack 2x9/16" spacers up front.
Didn't mean stack them, I meant that the spacers usually yield x 2 of the spacer width.
WieSeL is offline
post #18 of 21 Old 06-19-2013, 07:47 PM
jjt250
2007 WK
You can stack two 1/4" spacers to get a 1/2" spacer which should yield about an 1" of lift but you'll need longer strut tower bolts.
2007 Grand Cherokee Limited | QDII | 3.0L Diesel | S4xC Shackles Mounts | Goodyear Duratracs
Bilstein HD Front/Rear | Rusty's 1/2" Strut Spacer | Hemi XK Front/Rear Coils | HID Projectors
jjt250 is offline
post #19 of 21 Old 06-19-2013, 08:13 PM Thread Starter
WieSeL
There's about a half inch of threads of the stock strut plates above the nuts right now. I wonder if aftermarket upper strut plates might have a longer stud? I will look into that tomorrow at work and measure the length of the available threads on the stock studs
WieSeL is offline
post #20 of 21 Old 06-19-2013, 08:22 PM
jjt250
2007 WK
I have a Rusty's 1/4" strut spacer on mine and there's no way you could safely fit another one on the stock studs. Your best and easiest bet is to just knock out the old ones and weld in some newer, longer grade 8 bolts.
jjt250 is offline
post #21 of 21 Old 06-19-2013, 08:47 PM Thread Starter
WieSeL
IM Going to look into aftermarket strut plates from napa, and if no difference, knock out the old stud and hammer in new ones
WieSeL is offline
