Modified OME with 26" Ome shocks? - JeepForum.com
post #1 of 21 Old 06-17-2013, 07:14 PM Thread Starter
WieSeL
I want to do the modified OME lift but am wondering if the regular OME rear shocks would work. I don't wanna have to get new shocks when the ones I have are basically new. What is everybody else using?
WieSeL is offline
post #2 of 21 Old 06-17-2013, 10:15 PM Thread Starter
WieSeL
Bump
WieSeL is offline
post #3 of 21 Old 06-17-2013, 11:10 PM
ca07wk
2007 WK
Check out omelets build thread.
Crawl-Offroad.com-Boycott Paved Roads
2006 WK Limited Modified QT2
OME HD/RRO UCA/Wrangler MTRs on Moabs/JKS Rear Discos/Steel Armadillo Skids, Sliders,Front Shackles,Antenna Mount/Crawl Rear Skid
ca07wk is offline
post #4 of 21 Old 06-17-2013, 11:31 PM Thread Starter
WieSeL
I already know what kind of shocks he has. I wanted to know if it was possible to run the stock OME shocks with an added spacer
WieSeL is offline
post #5 of 21 Old 06-17-2013, 11:52 PM
ca07wk
2007 WK
I'm pretty sure he had the modifed OME with the OME shocks before swapping them out.
ca07wk is offline
post #6 of 21 Old 06-18-2013, 05:41 AM
sk1er18
2007 XK Commander
If you already have them, they will be fine.
If you dont already have them, there are better options for maximizing rear travel.
-Matt
sk1er18 is offline
post #7 of 21 Old 06-18-2013, 07:18 AM Thread Starter
WieSeL
Ok thanks.
WieSeL is offline
post #8 of 21 Old 06-18-2013, 12:36 PM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
^^^Agreed.
The only thing you'll really compromise by sticking with the OME shocks with you're proposed set-up is down travel because the rear will sit at a "defaulted down travel" position relative to the standard OME set-up.
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is offline
post #9 of 21 Old 06-18-2013, 06:19 PM Thread Starter
WieSeL
Ok. How thick is the optional trim packer kit in the ome page from RRO? I heard it was 9/16 but can't find any info anymore. I also can't find any rear spacers less than 2 inches anywhere. Any ideas?
WieSeL is offline
post #10 of 21 Old 06-18-2013, 07:56 PM
jjt250
2007 WK
I assume you're talking about the strut spacer? RROs is 9/16th I think. JBA and Rusty's makes a 1/4" strut spacer. They're all gonna yield about 1/2" of lift. I think BDS makes a 1.5" rear coil spacer but you might have to call to just order the rear part of their lift. Taking the coil isolater out and just using that coil spacer from BDS would probably give you just over 1" of lift in the back.
2007 Grand Cherokee Limited | QDII | 3.0L Diesel | S4xC Shackles Mounts | Goodyear Duratracs
Bilstein HD Front/Rear | Rusty's 1/2" Strut Spacer | Hemi XK Front/Rear Coils | HID Projectors
jjt250 is offline
post #11 of 21 Old 06-18-2013, 08:17 PM Thread Starter
WieSeL
How does a 9/16 and a 1/4 spacer both yield 1/2 inch when they are different sizes? Just wondering... 9/16 x 2 is 1.125 inch and 1/4 x 2 is 1/2 inch. Since they usually yield double what the plate width is...
WieSeL is offline
post #12 of 21 Old 06-18-2013, 08:46 PM
jjt250
2007 WK
I said they would both yield about 1/2" of lift. I highly doubt you'll notice 1/8" of lift....
jjt250 is offline
post #13 of 21 Old 06-19-2013, 07:45 AM Thread Starter
WieSeL
Not 1/8, wouldn't it yield more like 1 inch because it usually is twice the height at the wheel than the spacer thickness? 9/16 x 2 is 1 1/8
WieSeL is offline
post #14 of 21 Old 06-19-2013, 11:21 AM
JeepN4KC
JeepN4KC's Avatar
Your steering rack and UCA/ball joints will be screaming with that set-up. You'll also need longer strut tower bolts if you're gonna stack 2x9/16" spacers up front.
~Mike~
WK
XJ
JeepN4KC is offline
post #15 of 21 Old 06-19-2013, 05:43 PM
jjt250
2007 WK
Oops made a typo, the RRO one is only 3/8" thick but they claim 9/16" lift (not sure how true that is). Either way you're not gonna notice a huge difference so you might as well just go with the cheapest one. I went with the Rusty's. Also, if you stack two, you'll need longer strut tower bolts like JeepN4KC said.
jjt250 is offline
