Modification to Grille & Insert - JeepForum.com
post #1 of 5 Old 10-20-2013, 05:07 PM Thread Starter
1EvilHemi
2007 WK
Hey all. I decided to modify my grille and insert. Previously my grille was Chrome and the insert was black however I wanted to be different and swapped the colors. We painted my insert silver and the grille black. I used plasti dip on the grille so at least I can remove it if need be. The insert however was painted. I need opinions because I honestly do not like it. There is something off about it.. Maybe the silver insert is too silver? Maybe the black doesn't belong? Maybe I should try tinting my headlights so it blends better with the black? I am having someone paint the Mopar racing stripe down my entire jeep..it will be painted silver so I figured painting the insert silver would match. I don't know.. I need some opinions/advice.
Thanks a lot!
Ashley
07 Red Rock Crystal Jeep Grand Cherokee Overland 5.7 QDII. Gibson 3" Cat Back exhaust, modified K&N FIPK cold air intake wet sanded, primed & painted PEM Red Rock Crystal with custom "EVIL HEMI" K&N decal design. Custom Mopar Engine Cover Insert with additional air slots. Removed OEM sticker pin striping. Hawk Performance LTS Brake pads, Stillen cross drilled rotors, OEM calipers custom Duplicolor mix-painted dark red. LED lighted red cup holder rings. 2" Daystar lift kit & Bilstein shocks purchased (awaiting installation).
1EvilHemi is offline
post #2 of 5 Old 10-20-2013, 05:17 PM
Jeepforthewin
2010 JK Wrangler
Plasti dip your emblems black and tint your headlights/fogs. If you do that I think you will be set! I like the idea of swapping the colors!
2010 JKU - Stock for now
2005 WK - 6" lift, 35" BFG's, a lot more (SOLD)
Jeepforthewin is offline
post #3 of 5 Old 10-20-2013, 09:17 PM
jjt250
2007 WK
Personally, I like the grill. I think if you did something to the headlights like Anon155 (http://www.jeepforum.com/forum/f67/a...03/index2.html) did to his but in black, it would really go together.
2007 Grand Cherokee Limited | QDII | 3.0L Diesel | S4xC Shackles Mounts | Goodyear Duratracs
Bilstein HD Front/Rear | Rusty's 1/2" Strut Spacer | Hemi XK Front/Rear Coils | HID Projectors
jjt250 is offline
post #4 of 5 Old 10-21-2013, 03:10 AM
james_2k
2003 WJ
yeah you need more black bits to compliment the grille
by the looks of things, that cat doesnt like it either!
james_2k is offline
post #5 of 5 Old 10-21-2013, 03:05 PM Thread Starter
1EvilHemi
2007 WK
Haha yepp my cat defiantly photobombed that one! I appreciate all the responses.. I'm going to get black headlights and see how it looks then. The boyfriend says not to tint the headlights because of the HID's..I'll take his word for It and just buy new ones. Will post a pic after I get those in.. Hopefully it will do the trick.
Thanks again!
Ashley
