MLL rubbing? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > MLL rubbing?
Only 2 Days left to win $3,800 Jeep Parts!Count Down to KOH Sale!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 12-19-2012, 01:30 PM   #1
kVon
MLL rubbing?
I have an RC lift with MLl's in the rear and noticed the drivers left shock has the spring rubbing against the shock body. It's chewed through the finish and exposing bare metal. The dust boot is torn and useless at this point. Any ideas how to correct this to align the spring and shock so they don't rub? I don't mind just replacing them if it is a defect.
2005 WK 3.7 Laredo Rocky Mountain - 255/70R17 Grabber AT2 - RC 2" BB - Spidertrax 1.5" spacers - Bilstein HD & MLL - Rola roof basket - Midland CB w/2' Firestik - Solid Rear diff cover
Red WK Club Member #30
kVon is offline   Reply With Quote Quick reply to this message
Unread 12-20-2012, 12:48 AM   #2
06WKHEMI
2006 WK
They all rub because they aren't meant for this vehicle mine do the same
2006 Black wk overland HEMI QDII. OME HD bilstein struts with 58643 monroe load levelers RRO uca, afe cold air intake,hella 500FF behind grille, RC 1.5 wheel spacers s4xc cb antenna mount with 5ft firestik and midland 1001wx CB,265/70-17 falken rockymountain ats, pinch weld mod, door lock mod, Rola basket with 2 Hella 500 FF`s.
06WKHEMI is offline   Reply With Quote Quick reply to this message
Unread 12-20-2012, 05:09 AM   #3
sk1er18
2007 XK Commander
It has nothing to do with the vehicle.... thats just how these shocks are.
I used some axle grease the lubricate the are where the spring rubs and it stays quiet for a long time.
-Matt
sk1er18 is offline   Reply With Quote Quick reply to this message
Unread 12-20-2012, 09:58 AM   #4
kVon
I will try that. Thank you!
Unread 12-23-2012, 02:59 PM   #5
t3kmitch
2005 WK
I just gave mine a squirt of chain oil I had in the trunk and it's been silent for 3 weeks now. Works until I decide to fix it fully (my boot is still intact, just slides up).
Mine has also started rusting where it rubs, is this something to worry about? Will it rust out before the shock itself is worn out?
-Sold 3/13. Replaced by 2010 VW Jetta 2.5-
2005 WK 3.7L Laredo. RC 2", 265 70 17 Bridgestone Dueler Revo 2's. Class III OEM hitch added. Bilstein Struts. Monroe Load Levelers (58643).
Blue WK Club Member #32
t3kmitch is offline   Reply With Quote Quick reply to this message
Unread 12-24-2012, 11:44 PM   #6
Budasac
2005 WK
I had the same issue. Here's what I did. That was 7 months ago and I haven't had an issue since.
Budasac is offline   Reply With Quote Quick reply to this message
