Milton's Jeep Build - Page 28 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Milton's Jeep Build
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 04-17-2013, 01:32 PM   #406
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
Originally Posted by bhawks28 View Post
nice pics man, looks like you guys had a blast
Yes - it was a good day of wheelin in the WK.
Originally Posted by straightsixjeep View Post
Great pictures as always and Im glad to see the WK doing work. Glad you had a good time.
Thank you.
Originally Posted by RebelMS38WK View Post
I have a 2in RC lift will the 265's fit with wheel spacers im kind of confused about how much lift yours has and the recommended size for the RC is 265. I know you dont have the RC but hopefully you could give me insight cause im looking at the Goodyear Wrangler Authorities
265s will fit your lift w/ or w/o spacers.
My WK has an OME HD lift with rusty's spacers up front and homebrewed spacers in the back. Somewhat of a "modified OME." Although, truthfully I'm not so sure I didn't just bump my lift back to original measurements before any spring settling.
I got some pics sent to me of the waterhole I was mentioning that left the waterline in the rear coming out:
20130414_142657.jpg   20130414_142704.jpg   20130414_142955.jpg   20130414_142958.jpg
~Mike~
Build Thread WK
Other Build Thread XJ
September 2013/January 2015 COTM
JeepN4KC is online now   Reply With Quote Quick reply to this message
Unread 04-18-2013, 08:05 AM   #407
Myusername1674
Looks like a fun trip! At first looking at the pics I was like "Oh those trails look eeeasy". Then I saw your Jeep flexed out on some stuff. I'm now thinking those pictures don't do the trail justice. Looks fun either way
[SIZE="3"]95 FiveTwo ZJ, DD, Lifted, Locked on 35s, [URL="http://alturl.com/d6vk7"][B][COLOR="Blue"]Build[/COLOR][/B][/URL] (in progress)[/SIZE]
[URL="http://alturl.com/22263"][COLOR="Blue"]My 5.9 swap[/COLOR] (in progress)[/URL]
[URL="http://alturl.com/x4ryd"][COLOR="Blue"]Want your zj to be doorless in 60 seconds?[/COLOR][/URL]
Myusername1674 is offline   Reply With Quote Quick reply to this message
Unread 04-26-2013, 10:36 PM   #408
JeepN4KC
JeepN4KC's Avatar
My experience is the pics never do the trails justice.
They certainly aren't the most difficult rated trails in the park - but it was good to get the red Jeep out and push it a little.
~Mike~
Build Thread WK
Unread 05-21-2013, 09:26 AM   #409
816jared
2005 WK
took me awhile, but I finally made it through the entire build. lol
sick sick jeep!
I'm from Blue Springs as well, surprised I haven't seen the Red WK out romping around at some point.
816jared is offline   Reply With Quote Quick reply to this message
Unread 05-21-2013, 01:55 PM   #410
JeepN4KC
JeepN4KC's Avatar
sick sick jeep!
Pics of your rig and I'll keep an eye out for ya.
~Mike~
Build Thread WK
Unread 05-21-2013, 05:02 PM   #411
816jared
2005 WK
going to clean it up now and will throw some pictures up. I've only had it about 3 months, soooo it's still pretty boring.
Unread 05-24-2013, 08:08 AM   #412
JeepN4KC
JeepN4KC's Avatar
Yesterday I put this in the crankcase, gas tank, and sucked the rest up the brake booster vacuum line:
Today the red Jeep is getting fresh oil, rotation, etc. and new gear oil in the rear diff.
Fuuuun stuff Happy Friday
~Mike~
Build Thread WK
Unread 05-25-2013, 07:39 AM   #413
AJeepZJ
2006 WK
How far away are you from Fort Leonard wood?
All Gear, No Skill.
AJeepZJ is offline   Reply With Quote Quick reply to this message
Unread 05-25-2013, 09:06 AM   #414
JeepN4KC
JeepN4KC's Avatar
About 3.5 hrs (just under 200 miles) from the west side of the state. Blue Springs is 15-20 minutes to the east of KCMO.
The St. Louis side is a little closer than me.
We should try to put together a wheelin trip to SMORR sometime.
~Mike~
Build Thread WK
Unread 05-25-2013, 07:50 PM   #415
straightsixjeep
Mike, did you wheel ks rocks at all for the memorial day event? I really wanted to go however I stayed busy today, then I'm forced to work the next two days. Looks like a night run is coming up on the 22nd then in July on the 20th is the 10 year park anniversary event. Hope to see you on the trails soon.
straightsixjeep is offline   Reply With Quote Quick reply to this message
Unread 05-25-2013, 08:37 PM   #416
AJeepZJ
2006 WK
Yeah, i'm def. down for doing something like that... pm me sometime and I'll give you my cell. Or if you happen to be near FLW. We can grab a beer or two! (or 3) Take care.
All Gear, No Skill.
Unread 05-25-2013, 09:53 PM   #417
JeepN4KC
JeepN4KC's Avatar
^^^ Sounds good AJ!
So yesterday I got everything but the tires rotated.
Ran into a couple snags.
Once I pulled the front skid plate I realized I had some cleaning to do and then investigating. The diff end of my front drive shaft has been slingin grease:
I've been doing some searching and reading and calling and I still haven't come up with a solid answer on what my options are with regards to servicing/replacing the cv joints at both ends of the shaft.
Parts dept at a local dealer tells me the entire shaft has to be replaced. I've found kits to replace the t-case end cv but not the diff side -
I also noticed that my belly skid took one helluva hit a few weeks back when the red Jeep got to play:
That bent the front mounting flange to the point I couldn't line the mounting bolts up with the holes after removing the front skid. So - I had to pull the belly skid and beat the piss out of it to bend it back in order to mount it back up.
For now the front skid will sit at the ready:
...and I will likely have to pull the belly skid, again, along with the t-case skid and cross member in order to pull the front drive shaft to see what is going on. I know the t-case end cv has a rip in the boot but I can't see what's up with the diff end.
Anybody with some insight or previous experience feel free to chime in.
~Mike~
Build Thread WK
Unread 06-01-2013, 01:41 AM   #418
robswk
2008 WK
I get all excited when I see wks with the ome lift and spidertrax spacers cause that what I exactly want. Very cool jeep thanks for posting for future tips and whatnot
robswk is offline   Reply With Quote Quick reply to this message
Unread 06-09-2013, 08:53 AM   #419
ChopprJock
2005 WK
Great build! Just finished reading your entire thread and I'm impressed. I just picked up an 05 Limited and ordered my OME HD, so I've been waist deep in Jeep Forums for about a week... Love your jeep, looks like I want mine, so I'll be checking it out again once my lift comes in!
I actually lived in Manhattan, KS for a few years at the end of my army career so I appreciated the pics of your trips out there. Great town and beautiful country!
One quick question when you get a free minute or two- after running the Goodyears for so long, how do like them now? I'm going to need some new meat after I lift mine and I'm looking at my options. Once again, awesome Jeep!
Lyn
2005 Limited
5.7L Hemi
QDII
OME HD
255/75/17's on JK Rubicon wheels
ChopprJock is offline   Reply With Quote Quick reply to this message
Unread 06-17-2013, 08:39 AM   #420
JeepN4KC
JeepN4KC's Avatar
Been on vacation with the family so I haven't been on the forums until a couple drive by posts yesterday.
Had an amazing trip in Florida:
Ft. Lauderdale; South Beach Miami; Naples; Cape Coral; Estero Island; Ft. Myers Beach; Lover's Key; Sanibel; Bowman's Beach; Captiva; Captiva Beach; Cabbage Key; Cayo Costa......................I'd post pics but it seems the pic posting aspect of this site has gone to crap lately.
You folks living down that way are lucky S.O.B.s
Appreciate it - thnx!
Lyn
Aggieville is fun and Tuttle Creek is a great place to wheel.
The GY Authorities have stood the test so far and I really cannot complain about them.
~Mike~
Build Thread WK
