Milton's Jeep Build - Page 26 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Milton's Jeep Build
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 03-22-2013, 07:27 PM   #376
kennymo
they are very easy make actually. you can get round bar and then get link bar end links that you can thread onto the bar and use it as an adjustble track bar. i used to make link bars like this when i built link kits for trucks with air ride
looking to buy the matrix mounting platform. pm me if you have one for sale
kennymo is offline   Reply With Quote Quick reply to this message
Unread 03-22-2013, 07:49 PM   #377
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
^^^ Are you talking about boring out the ends of a solid round bar and tapping it in order to thread in a link end?
~Mike~
Build Thread WK
Other Build Thread XJ
September 2013/January 2015 COTM
JeepN4KC is offline   Reply With Quote Quick reply to this message
Unread 03-22-2013, 09:21 PM   #378
kennymo
no. you get like 1'' OD tube that has a 3/16 wall and then these
http://thorbros.com/4-link-parts/4-l...d-zerk-fitting
thread the ID of the tube screw this into it with a jam nut and you get an adjustable track bar.
Unread 03-22-2013, 09:23 PM   #379
kennymo
this one is already threaded on one end
http://thorbros.com/4-link-parts/4-l...-tube-24-piece
Unread 03-22-2013, 10:35 PM   #380
JeepN4KC
JeepN4KC's Avatar
^^^ Pretty slick. I'm going to look into this some more. My only concern is 1" x 3/16" tubing being too weak. I don't know if it is or isn't. I know RRO uses .25" wall DOM, not sure what Rusty's uses. The stock looks to be 1.25" square tube and I have no idea the wall thickness.
~Mike~
Build Thread WK
Unread 03-22-2013, 11:27 PM   #381
kennymo
you can definatly get thicker/bigger tube. i was simply using those as examples
Unread 03-22-2013, 11:30 PM   #382
kennymo
but also keep in mind. these bars that i linked, are meant for air link setups. which take a ton of abuse and are the MAIN part of the suspension on a vehicle with air ride. like leaf springs. so 1'' with 3/16 wall would be ok
Unread 03-22-2013, 11:35 PM   #383
kennymo
if you want to use sqaure tubing you would use this bung. weld it into the end of the square tubing and then use the same end lings
http://thorbros.com/4-link-parts/4-l...ed-4-link-bung
http://thorbros.com/steel-tubing/30-...-x-2-x-14-wall
this is roughly what the final product would be
http://thorbros.com/4-link-parts/4-l...-poly-bushings
Unread 03-23-2013, 07:09 PM   #384
JeepN4KC
JeepN4KC's Avatar
So I did some research on the parts linked and concluded that without modifying the end links (i.e. chopping them down) they aren't going to fit the mounting points. The smallest bushing they offer is 2" and I can't find any info on the width of the steel end that the bushing gets pressed in, and control arm end links are certainly wider than the stock tracbar links. I am going to look for other vendors but I really don't want to have to modify parts for a modification if ya know what I mean. Not when about $30 more puts a bolt in adj. trackbar at my door from the guy in the brown truck.
~Mike~
Build Thread WK
Unread 03-23-2013, 08:02 PM   #385
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Just get Rusty's bar and don't looks back! It's a perfect fit and totally trouble free.
See How It Was Made
Omelet is offline   Reply With Quote Quick reply to this message
Unread 03-23-2013, 08:05 PM   #386
straightsixjeep
Look around before you jump on one, Iv been weary of rusty's trac bars.
straightsixjeep is offline   Reply With Quote Quick reply to this message
Unread 03-23-2013, 10:03 PM   #387
JeepN4KC
JeepN4KC's Avatar
^^^ Yep, this is what I am leaning toward Appreciate the nudge, Nathan!
I don't know, Griffin, assuming that is actually a Rusty's product, that pic looks like a TRE of a draglink coming off the pitman arm in the steering linkage of a solid front axle. Which sees different forces than the tensile and compression of a rear trackbar on a WK. Thanks for lookin out for a fellow Jeeper though
~Mike~
Build Thread WK
Unread 03-23-2013, 10:32 PM   #388
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
^^^ BAHAHAHA, WOW!!! He must just troll threads looking to bash companies with off topic parts! Clearly that is a tie rod failure and it's not even a track bar. My guess it's not even a Rusty's part either.
Rusty's bar is the best one for our platform. RRO sells one for slightly less, but needs modification to bolt in and JBAs bar is $200 more than Rusty's. I have been torturing mine for the past 2.5 years and have had zero issues with it!
See How It Was Made
Unread 03-23-2013, 10:36 PM   #389
straightsixjeep
I have read several threads regarding problems with rustys track bars however none were for a wk. Im sure you will be fine. As far as that meme goes, yes that does appear to be the steering tie rod end. Fail.
Not bashing any companies.
Unread 03-23-2013, 10:44 PM   #390
JeepN4KC
JeepN4KC's Avatar
Nah - I'll vouch for him. He means well.
~Mike~
Build Thread WK
