Milton's Jeep Build - Page 26 - JeepForum.com
 1Likes
post #376 of 591 Old 03-22-2013, 06:27 PM
kennymo
they are very easy make actually. you can get round bar and then get link bar end links that you can thread onto the bar and use it as an adjustble track bar. i used to make link bars like this when i built link kits for trucks with air ride
looking to buy the matrix mounting platform. pm me if you have one for sale
kennymo is offline
post #377 of 591 Old 03-22-2013, 06:49 PM Thread Starter
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
^^^ Are you talking about boring out the ends of a solid round bar and tapping it in order to thread in a link end?
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is offline
post #378 of 591 Old 03-22-2013, 08:21 PM
kennymo
no. you get like 1'' OD tube that has a 3/16 wall and then these
http://thorbros.com/4-link-parts/4-l...d-zerk-fitting
thread the ID of the tube screw this into it with a jam nut and you get an adjustable track bar.
kennymo is offline
post #379 of 591 Old 03-22-2013, 08:23 PM
kennymo
this one is already threaded on one end
http://thorbros.com/4-link-parts/4-l...-tube-24-piece
kennymo is offline
post #380 of 591 Old 03-22-2013, 09:35 PM Thread Starter
JeepN4KC
JeepN4KC's Avatar
^^^ Pretty slick. I'm going to look into this some more. My only concern is 1" x 3/16" tubing being too weak. I don't know if it is or isn't. I know RRO uses .25" wall DOM, not sure what Rusty's uses. The stock looks to be 1.25" square tube and I have no idea the wall thickness.
~Mike~
WK
XJ
JeepN4KC is offline
post #381 of 591 Old 03-22-2013, 10:27 PM
kennymo
you can definatly get thicker/bigger tube. i was simply using those as examples
kennymo is offline
post #382 of 591 Old 03-22-2013, 10:30 PM
kennymo
but also keep in mind. these bars that i linked, are meant for air link setups. which take a ton of abuse and are the MAIN part of the suspension on a vehicle with air ride. like leaf springs. so 1'' with 3/16 wall would be ok
kennymo is offline
post #383 of 591 Old 03-22-2013, 10:35 PM
kennymo
if you want to use sqaure tubing you would use this bung. weld it into the end of the square tubing and then use the same end lings
http://thorbros.com/4-link-parts/4-l...ed-4-link-bung
http://thorbros.com/steel-tubing/30-...-x-2-x-14-wall
this is roughly what the final product would be
http://thorbros.com/4-link-parts/4-l...-poly-bushings
kennymo is offline
post #384 of 591 Old 03-23-2013, 06:09 PM Thread Starter
JeepN4KC
JeepN4KC's Avatar
So I did some research on the parts linked and concluded that without modifying the end links (i.e. chopping them down) they aren't going to fit the mounting points. The smallest bushing they offer is 2" and I can't find any info on the width of the steel end that the bushing gets pressed in, and control arm end links are certainly wider than the stock tracbar links. I am going to look for other vendors but I really don't want to have to modify parts for a modification if ya know what I mean. Not when about $30 more puts a bolt in adj. trackbar at my door from the guy in the brown truck.
~Mike~
WK
XJ
JeepN4KC is offline
post #385 of 591 Old 03-23-2013, 07:02 PM
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Just get Rusty's bar and don't looks back! It's a perfect fit and totally trouble free.
Omelet is offline
post #386 of 591 Old 03-23-2013, 07:05 PM
straightsixjeep
Look around before you jump on one, Iv been weary of rusty's trac bars.
straightsixjeep is offline
post #387 of 591 Old 03-23-2013, 09:03 PM Thread Starter
JeepN4KC
JeepN4KC's Avatar
^^^ Yep, this is what I am leaning toward Appreciate the nudge, Nathan!
I don't know, Griffin, assuming that is actually a Rusty's product, that pic looks like a TRE of a draglink coming off the pitman arm in the steering linkage of a solid front axle. Which sees different forces than the tensile and compression of a rear trackbar on a WK. Thanks for lookin out for a fellow Jeeper though
~Mike~
WK
XJ
JeepN4KC is offline
post #388 of 591 Old 03-23-2013, 09:32 PM
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
^^^ BAHAHAHA, WOW!!! He must just troll threads looking to bash companies with off topic parts! Clearly that is a tie rod failure and it's not even a track bar. My guess it's not even a Rusty's part either.
Rusty's bar is the best one for our platform. RRO sells one for slightly less, but needs modification to bolt in and JBAs bar is $200 more than Rusty's. I have been torturing mine for the past 2.5 years and have had zero issues with it!
Omelet is offline
post #389 of 591 Old 03-23-2013, 09:36 PM
straightsixjeep
I have read several threads regarding problems with rustys track bars however none were for a wk. Im sure you will be fine. As far as that meme goes, yes that does appear to be the steering tie rod end. Fail.
Not bashing any companies.
post #390 of 591 Old 03-23-2013, 09:44 PM Thread Starter
JeepN4KC
JeepN4KC's Avatar
Nah - I'll vouch for him. He means well.
~Mike~
WK
XJ
JeepN4KC is offline
build my jeep with $3k zjilla ZJ Grand Cherokee Forum 24 01-25-2009 08:26 AM
Live Jeep Q/A RIGHT NOW - Tell them what you want them to build! Keith ZJ Grand Cherokee Forum 0 03-25-2008 03:12 PM
Live Jeep Q/A RIGHT NOW - Tell them what you want them to build! Keith WK Grand Cherokee & XK Commander Forum 0 03-25-2008 03:12 PM
How do I get a build sheet for my Jeep? 02Lightning ZJ Grand Cherokee Forum 9 12-14-2005 07:13 PM
Obtaining build sheet from Jeep djorkboy ZJ Grand Cherokee Forum 25 12-10-2004 01:26 AM
