Merlin, could a heavily carbonned or oil clogged intake cause CRD problems? - JeepForum.com
post #1 of 5 Old 12-02-2009, 07:16 AM Thread Starter
suzieque
2008 WK
I read a post on another forum of a guy that had his swirl motor replaced, but shortly after the engine developed lots of blowby and performance issues. The dealer tore apart the manifold and found lots of carbon and oil in the intake. Could the carbon and oil somehow cause blowby and performance issues? Maybe damaging the butterfly valves controlled by the swirl motor?
2008 WK "S" Limited bright metallic silver exterior, light graystone interior, 5 speed W5J400 transmission, June 18/2008 build, C213RE rear differential with 3.73 axle ratio, C200FE front differential with 3.73 axle ratio, 245/60R18 Goodyear Fortera tires (stock summer tires), NV245 transfer case, GT2056V turbo, 3.0L CRD (OM642.980)
suzieque is offline
post #2 of 5 Old 12-02-2009, 02:01 PM
merlinTec
merlinTec's Avatar
Hi
YES, I have seen them bent and this way why I like taking off the manifold to clean them out on very swirl motor job I did but warranty stopped paying for this so now only do the motor.
UK Chrysler Jeep Master Tec.
merlinTec is offline
post #3 of 5 Old 12-04-2009, 06:58 AM Thread Starter
suzieque
2008 WK
thanks Merlin.
How many more hours of labour to pull the manifold and clean it?
suzieque is offline
post #4 of 5 Old 12-04-2009, 01:10 PM
merlinTec
merlinTec's Avatar
Originally Posted by suzieque View Post
thanks Merlin.
Hi
only another 2.
post #5 of 5 Old 12-14-2010, 01:41 PM
Bzwth
2008 WK
Another Forum?!?!?
What kind of problems/symptoms occur when a swirl motor goes bad? I updated my intake tube already, but it leaked oil down onto the swirl motor for almost 30k miles before I changed it out. I can see a lot of burnt oil/carbon down there in the swirl motor area is aswell. And I haven't gotten around to installing my CCV filter yet either, so I'm guessing that problems might be right around the corner.
Bzwth is offline
CRD Intake Leak - Merlin? 2007GrandDiesel WK Grand Cherokee & XK Commander Forum 3 03-02-2009 04:16 PM
calling merlin Re: WK O2 sensors tednelson83 WK Grand Cherokee & XK Commander Forum 1 03-04-2008 12:59 PM
Question for you Merlin TRZ WK Grand Cherokee & XK Commander Forum 11 02-27-2008 06:13 AM
Merlin- Help with trans pan! IMFLASH WK Grand Cherokee & XK Commander Forum 5 12-18-2007 12:23 PM
VIDEO: heavily modified AEV Jeep Commander being tested nedsud WK Grand Cherokee & XK Commander Forum 3 10-27-2007 09:19 AM
