MBRP CRD Exhaust Questions - JeepForum.com
post #1 of 6 Old 01-08-2010, 08:23 AM Thread Starter
CRD Dawg
2008 WK
I purchased the Pro Series MBRP Exhaust about 5 weeks ago from an online retailer. NOT directly from MBRP. Good price-$409 delivered. The system arrived quickly but one of the middle components (the Over Axle Pipe) was damaged. The box was fine. Everything seemed to fit snugly together, though (read on). I returned it and after 30 days of waiting (not MBRP's fault), my second one arrived. The return order got lost over the holidays. Well, I assembled it this morning to make sure everything was OK. This one looked much shinier and fit together much more easily. So I decided to completely assemble it. Every single connection point will not fully clamp together snugly no matter how far I crank the clamps down. The pipes are getting OVAL in shape as I crank down the clamps. The variances/tolerances between the flared ends of the pipes and where they slide into each other are just too big. The clamps appear to be too big as well. The Tail Pipe Tip also won't ever completely clamp on. Is this just normal fitment issues that come with all aftermarket exhaust systems? Did those of you who purchased one of these have this many problems? I don't intend to bash MBRP, but I'm REALLY disappointed and frustrated. Could use a little guidance/advice here...
2008 Grand Cherokee Limited 2wd CRD-InMotion Stage 2 Tune, K&N Air Filter, Elephant Hose CCV Mod, Gutted Turbo Resonator, MBRP Pro Series Exhaust
CRD Dawg is offline
post #2 of 6 Old 01-08-2010, 10:20 AM
wookiee
Bought, not built.
wookiee's Avatar
2007 WK
I just put some exhaust sealer at the joins and cranked the clamps down.
07 Steel Blue Overland CRD QDII | Bilsteins | 4xguard Matrix | Rear SRT8 SwayBar | DashHawk w/egt | Provent MBRP XP Exhaust | New Intake Tube & Seal + EHM | Alternator Splash Guard | Crank Sensor | GPS AL InMotion Hack | Swirl motor bypass | Blue WK Club Member #13 | 200,000 Mile Club | Dogpiled Club | pre-N23 FDCM |
89 GW w/plow
wookiee is offline
post #3 of 6 Old 01-08-2010, 01:58 PM
micky_blue
Mine went on easily. I was surprised but my jeep felt a bit quicker with the MBRP. I figured with a DPF it wouldn't hurt but wouldn't be very noticeable. I was shocked. Its not a huge difference but every bit counts in my eyes.
micky
micky_blue is offline
post #4 of 6 Old 01-08-2010, 03:40 PM
ctate
2007 WK
Mine was easy. I didnt have any problems. You should hit up MBRP for a new one. Sounds like the one you have has some issues.
07 Silver 3.0 CRD, Clifford matrix 50.5x remort start/turbo timer, 265/70R17 Goodyear DURATRACS, XD Series Spy wheels, OME Lift Kit, Kenwood navigation system with reverse camera, Inmotion tuned, Amsoil air filter, Fitch fuel catalyst, Air Lift suspension air bags with air compressor, P3 brake controller, MBRP Exhaust, Accu Pro Calibrator, Addco front/rear anti sway bar, Husky Liner floor mats, upgraded air intake tube, Quick Oil Drain Valve.
ctate is offline
post #5 of 6 Old 01-18-2010, 04:06 PM
MBRP
Try moving the clamps right to the ends of the expansions and make sure the bolt is over one of the slots...if this does not work,and you're having issues getting this tight, do not hesitate to call me directly at MBRP inc. at 1-888-636-7223 ext. 202. Hope this helps.
Steve
Scott
Phone 1-888-636-7223
Web
MBRP is offline
post #6 of 6 Old 01-19-2010, 06:19 AM Thread Starter
CRD Dawg
2008 WK
Steve,
Thank you. Haven't had a chance to work on it much further since. I'll try that next. I really like the workmanship of the pipes overall. It's the clamp on components that are giving me fits this time(clamps and tailpipe). I'll call you this week. Thanks for offering to help.
Chris
CRD Dawg is offline
CRD MBRP Exhaust Install wookiee WK Grand Cherokee & XK Commander Forum 37 11-07-2011 12:43 AM
Anyone Have an MBRP Exhaust?? BigStout99 WK Grand Cherokee & XK Commander Forum 16 09-27-2010 01:37 PM
MBRP DPF Back Exhaust CRD Dawg WK Grand Cherokee & XK Commander Forum 6 11-19-2009 03:53 PM
good price on MBRP exhaust CRD micky_blue WK Grand Cherokee & XK Commander Forum 9 08-24-2009 03:59 PM
MBRP performance CRD exhaust LJS8510 WK Grand Cherokee & XK Commander Forum 4 08-01-2008 07:19 AM
