MB 3.0 CRD compatiabilty with VM Motori 3.0 CRD - JeepForum.com
post #1 of 10 Old 08-22-2013, 10:11 AM Thread Starter
10Xk
2014 WK
With the manufactures changing from MB to VM Motori are any of the parts interchangeable?
10Xk is offline
post #2 of 10 Old 08-22-2013, 10:16 AM
jediknight
2008 WK
If possible I'd like to interchange the trany for sure
2008 WK CRD Blue, QD II, Startech SD6 mod.
jediknight is offline
post #3 of 10 Old 08-22-2013, 10:20 AM
suzieque
2008 WK
the pictures I've seen of the VM looks quite different from the Mercedes version. I suspect only the displacement is the same. maybe even the bolt pattern for the transmission is different.
2008 WK "S" Limited bright metallic silver exterior, light graystone interior, 5 speed W5J400 transmission, June 18/2008 build, C213RE rear differential with 3.73 axle ratio, C200FE front differential with 3.73 axle ratio, 245/60R18 Goodyear Fortera tires (stock summer tires), NV245 transfer case, GT2056V turbo, 3.0L CRD (OM642.980)
suzieque is offline
post #4 of 10 Old 08-23-2013, 07:26 AM
jaje
2007 WK
They would have nothing in common completely different OEMs. Any attempt to swap parts across would require fabrication. It's like trying to use parts from a Chrysler v8 and a Ford v8 or a Chevy v8. Same configuration but different engines, chassis's, transmissions, computers, etc.
'14 WK2 EcoDiesel Limited
'13 Subaru BRZ
#74 Exocet - NASA ST3 / E0
jaje is offline
post #5 of 10 Old 08-23-2013, 08:57 PM
Zlartibartfast
2007 WK
Originally Posted by jaje View Post
T.... It's like trying to use parts from a Chrysler v8 and a Ford v8 or a Chevy v8. Same configuration but different engines, chassis's, transmissions, computers, etc.
It would be worse than that. The old one is German and the new one is Italian. Vinegar and Oil.
Zlartibartfast is offline
post #6 of 10 Old 08-24-2013, 06:26 AM
SSF556
2008 WK
Germans build engines and Italians design cars......nuff said
Silver WK Club Member #1
2008 CRD QT2
SSF556 is offline
post #7 of 10 Old 08-24-2013, 06:39 AM
Robert J. yates
The veiled dig on VM reliability is noted. Gale Banks however has a huge ton of respect for the new engine though and is using it as a base for development work for the US military. There are a number of notable strength features of the new CRD that speak to long term durability. I think the trick will be in getting ancillary systems to function reliably over time.... Something my Benz CRD certainly has not excelled at in some areas.... Particularly the glow plug circuit and plugs themselves. I have gone through 2 modules and 3 complete sets of plugs in 115000 miles. Compared to the swirl motor issues others have had I guess I should be thankful
Originally Posted by samgm2 View Post
And yes, I am an exceptional scientist and engineer.
Robert J. yates is offline
post #8 of 10 Old 08-24-2013, 09:55 AM
SSF556
2008 WK
I have had 3 Mercedes 3.0L diesels with and without DEF in the last 5 years and I have had no issues at all....just luck no matter the manufacturer....
Also remember that the VM diesels running in Australia do not need DEF....that adds a lot of complexity to the VM diesels coming to America.
2008 CRD QT2
SSF556 is offline
post #9 of 10 Old 08-25-2013, 08:07 AM Thread Starter
10Xk
2014 WK
Hopefully they will get it right this time. VM is 50% General Motors, maybe that will help.
10Xk is offline
post #10 of 10 Old 08-25-2013, 07:53 PM
jediknight
2008 WK
Oh I guess there will be some Torx 10 bolts on the engine.. Those might be compatible lol
