Max tire size for 2005 jeep grand cherokee - JeepForum.com
post #1 of 27 Old 03-14-2012, 10:12 AM Thread Starter
thuhreb
What's the max height tire size I can go with on a stock 2005 grand cherokee laredo without having any scrubbing occur? Currently, I have 245 65 r17. For those who suggest a taller size, what amount of lift could I expect?
thuhreb is offline
post #2 of 27 Old 03-14-2012, 10:35 AM Thread Starter
thuhreb
Also, if I lower the tread width from 245(what I have now) to 235 (stock), would I see any mpg improvement?
thuhreb is offline
post #3 of 27 Old 03-14-2012, 11:09 AM
Tamerin
2005 WK
Sup,
Here ya go. This is for the WJ, but it's pretty much the same for us. Change the 16's for 17'' rims.
'05 Grand Cherokee, 3.7l V6, Sold
'05 Grand Cherokee, 5.7l V8, Current, Stock
Black WK Club #110
Tamerin is offline
post #4 of 27 Old 03-14-2012, 11:53 AM Thread Starter
thuhreb
so 245/70/17 should be just fine? Can anyone verify this config running on a wk with no lift?
thuhreb is offline
post #5 of 27 Old 03-14-2012, 01:47 PM
trax95008
2006 XK Commander
Originally Posted by Tamerin
Sup,
First of all, you can't just change the rim size from 16 to 17. That would make the tire an inch taller. You need to change the profile number to compensate and keep the overall diameter the same.
Second, the WK/XK can fit a larger tire than the WJ to begin with.
trax95008 is offline
post #6 of 27 Old 03-14-2012, 01:53 PM
trax95008
2006 XK Commander
That size only adds less than half an inch to the radius. So my educated guess would be that your fine
post #7 of 27 Old 03-14-2012, 02:39 PM
Danno75
2005 WK
I had 245 /65/17 on stock set up, no problems. Its not 245/70......but thought I'd share.
2005 WK Grand Cherokee Limited
5.7 Hemi ~ 265/70/17 Stock Rims with GY MTRs Tires
2" Daystar BB~Matrix Brushguard with Hoop~AirAid CAI
Danno75 is offline
post #8 of 27 Old 03-14-2012, 02:59 PM
Budasac
2005 WK
Danno, he has 245/65's too.
Some one , somewhere, in the last year or so posted pics of 265/70/17's with stock suspension. I know there was some minor rubbing inside the wheel well. I guess my point is they did fit.
So if you wanted to stick with the 245 width I would guess you could go as tall as a 245/75/17. Which would be about 31.5" (depending on the tire model) amd roughly 2" taller then what you have now. (Giving you 1" of lift). I wouldn't imagine you'd be anywhere near the BJ bolt or have rub issues. If you added wheel spacers you might have to mod the pinch weld though.
Budasac is offline
post #9 of 27 Old 03-14-2012, 10:30 PM
trax95008
2006 XK Commander
245/65-17 is a stock size. Of course you didn't have any problems
post #10 of 27 Old 04-03-2012, 11:06 AM
dcbull36
Hi all, im new to the forum. I am planning a 3.5 inch lift on my 2005 grand cherokee. What are your opinions about what tire size and rim i should go with? I was thinking about 31x10.50R17.
dcbull36 is offline
post #11 of 27 Old 04-03-2012, 12:05 PM
OhFiveHemi
2005 WK
http://www.jeepforum.com/forum/f67/f...-wk-xk-703598/
Blue WK Club Member #41
... | `05 WK - HEMI - QDII - Mods | ... | `07 XK - 3.7L - Stock | ...
OhFiveHemi is offline
post #12 of 27 Old 04-03-2012, 12:20 PM
JHill11
2006 WK
I ran 265/70/17 with 1.5 spacers stock. Just had to do the front pinch weld
JHill11 is offline
post #13 of 27 Old 07-21-2013, 10:28 AM
Hazemonster
2014 WK
Will 2014 Wheels (style 14 on this list) fit a 2005 Jeep Grand Cherokee? I am selling 4 NEW ($645 LIST) for $1000 and this guy with a 2005 JGC wants to know if they will fit.
http://www.wk2jeeps.com/wk2_wheels.htm
Can someone help please? Thanks. Haze
Hazemonster is offline
post #14 of 27 Old 07-22-2013, 07:32 AM
Hazemonster
2014 WK
Thanks for the help!! Sheesh :rolleyes
post #15 of 27 Old 07-22-2013, 07:39 AM
Jeepforthewin
2010 JK Wrangler
I don't see why not as long as its a 5x5 bolt pattern.
2010 JKU - Stock for now
2005 WK - 6" lift, 35" BFG's, a lot more (SOLD)
Jeepforthewin is offline
what tire size do you recommend for my stock 1997 jeep grand cherokee? webhostingdesig ZJ Grand Cherokee Forum 26 10-30-2014 08:56 PM
Tire inflation valve stem cracking 2005 Jeep Grand Cherokee Laredo JamieRE WK Grand Cherokee & XK Commander Forum 19 11-12-2012 08:12 AM
2005 4.7 Jeep Grand Cherokee jdhalat WK Grand Cherokee & XK Commander Forum 2 08-07-2011 06:06 PM
99 Jeep Grand Cherokee whats the biggest size tire with a 2 in. without trimming Duckbuster177 ZJ Grand Cherokee Forum 1 10-15-2008 10:15 PM
max tire size 94 jeep grand cherokee motox8410 ZJ Grand Cherokee Forum 12 05-13-2006 06:13 AM
