Max tire size on 2"inch lift? - JeepForum.com
post #1 of 6 Old 06-21-2009, 01:39 PM Thread Starter
Moparcherokee99
Hi i have a 2005 Jeep Grand Cherokee. I just bought a 2inch lift kit and i was wondering what the maximum tire size i could put on it without trimming. Also would you recomend going down to 15" rims? Thanks alot
Moparcherokee99 is offline
post #2 of 6 Old 06-21-2009, 05:14 PM
Acidcold
2005 WK
17'' is the smallest wheel you can fit, with 2'' lift, you can get away with a 265/70/17 with minor rubbing (not a big deal and it only happens at full lock)
Acidcold is offline
post #3 of 6 Old 06-21-2009, 05:39 PM
anywaytothetop
2006 WK
Or you can run a 255/75 R17 which is a tad taller, but not as wide.
anywaytothetop is offline
post #4 of 6 Old 06-23-2009, 08:15 AM
MOUNTAINGARAGE
MOUNTAINGARAGE's Avatar
might need a spacer to move the tire away from the upper ball joint bolt, and/or trim it with 265's.
Custom Built NP231's Complete Teralow & 2wdlow Units available.
MOUNTAINGARAGE is offline
post #5 of 6 Old 06-24-2009, 05:12 PM
2005GRANDONE
2005 WK
i have 265 70 17 destination mt with no lift and home made 3/16 wheel spacers to keep from hitting ball joint stud have had no problems dont know how to add pics or i would
2005GRANDONE is offline
post #6 of 6 Old 06-24-2009, 08:13 PM
BIGMEL
I put some firestone destination MT 265 70 17 as well with a 1.5" spacer i needed to hammer and trim the plastic under the jeep to stop some really annoying rubbing. Before the spacer however, the tire would rub against the ball joint studd and rub slightly on the inside wells. plus handling was compromised.
BIGMEL is offline
4 inch lift max. tire size 04limegreen ZJ Grand Cherokee Forum 1 08-16-2009 09:44 AM
What size tire with 4 inch lift? StreetBMXer88 ZJ Grand Cherokee Forum 2 05-18-2009 01:17 PM
What size tire for max flex 3.5-4 inch lift trailblazr81 ZJ Grand Cherokee Forum 5 03-02-2009 09:56 PM
Tire size on a 2" lift wj CgeranWJ ZJ Grand Cherokee Forum 1 10-15-2008 01:37 PM
What size tire with 1-3/4" lift Invisible ZJ Grand Cherokee Forum 2 01-21-2003 05:48 PM
