Maintenance Questions 3.7 WK - JeepForum.com
post #1 of 12 Old 09-27-2013, 01:56 PM Thread Starter
JackB1
2008 WK
These questions came about after I downloaded the pdf. file for WK maintenance manual. I have an 08 WK Larerdo with 3.7., Q1
First the main. manual definitely states to use 5w-30 in 3.7 and 5w-20 for V-8 yet my owners manual states to use 5w-20 and oil cap states 5w-20. Why the discrepancy?
Second is that the main. manual refers to lubricating an upper knuckle ball stud but I cannot see that in owners manual lube recommendations. Is that only in certain models?
I am light duty use and transmission oil change for that in manual shows it at 102k or 5 years. Transfer case and axles seems to be every 30K. Sound right?
JackB1 is offline
post #2 of 12 Old 09-28-2013, 09:09 AM
modernblueWK
Yes the miles reccomendation for the trans and axles sounds good. You should check their condition more often though.
5w20 was adopted for increased mpg's. You can use either. Both oil viscosities will work fine.
SOLD 2008 WK 4.7 V8
2013 Hemi Durango Crew
2007 Silverado Crewcab LT3
modernblueWK is offline
post #3 of 12 Old 09-29-2013, 09:38 AM Thread Starter
JackB1
2008 WK
Thanks for the reply. What about this upper knuckle ball stud. Has that been eliminated as a grease point on later WKs?
JackB1 is offline
post #4 of 12 Old 09-29-2013, 10:31 AM
colinzj
2006 WK
No grease fittings on the WK. Everything's sealed and lifetime lubed.
If you're looking at the 05 FSM that's floating around, some of it's copied and pasted from the WJ. When in doubt, check twice and assume it's wrong.
2006 WK Laredo 4x4 4.7L
1993 ZJ Laredo 4x4 4.0L — Dead, sold, and rolling again
colinzj is offline
post #5 of 12 Old 09-29-2013, 06:13 PM Thread Starter
JackB1
2008 WK
Thanks. Yes the FSM I have was downloaded from someone who put it on the forum. I could not find a date on it which is why I thought the grease fitting might have been eliminated. Glad I do not have to worry about that. It also might explain why 5w-30 oil is recommended in the FSM and not in my owners manual.
JackB1 is offline
post #6 of 12 Old 09-30-2013, 06:49 PM
Drew
2007 WK
My mileage intervals are pretty much the same......However, Personally, I'd shorten the interval on the tranny fluid. I do mine at 60k. IMHO 100k is way to many miles.
It's an easy pan drop and filter change.
2007 WK 3.7
Drew is offline
post #7 of 12 Old 10-01-2013, 02:18 AM
twistedlizard72
2007 WK
Be sure to double check the T-Case fluid recommendation. I just found out the other day, the service manual says 245/247/249 specific fluid for the 245, but the Owners manual says AFT+4.
Kevin K.
twistedlizard72 is offline
post #8 of 12 Old 10-01-2013, 08:44 AM
JRLT
2010 WK
The QT1 uses ATF+4. That's what came out of mine so that's what I put back in.
2010 3.7L, 4XGuard Matrix, Fastman TB, TB Ground Mod, Injen CAI, 255/60/18 Nitto Terra Grapplers, Bilstein Shocks & Struts, Cruiser Alloy Wheels - Switchblade, Stillen Brakes, Cargo Light Strip Mod, Electric Ashtray Mod, Jet-powered, Monkey Navigated...
JRLT is offline
post #9 of 12 Old 10-01-2013, 09:36 AM
yzjwk
2005 WK
The 2007 owners manual from wkjeeps .com states :
Transfer Case (3.7L Engine Only) Mopar ATF+4 Automatic Transmission Fluid
Transfer Case Mopar NV 247/245 Transfer Case Lubricant
The 3.7L engine is only available with QTI /nv140 transfer case and is the only case that ATF+4 is specified .
5 and counting :05 WK 5.7 HEMI
90 YJ Islander 4.2L
94 ZJ Ltd 5.2 ,00 WJ 4.0
2010 MK Patriot
yzjwk is offline
post #10 of 12 Old 10-01-2013, 11:29 AM
Drew
2007 WK
While it won't say in the owners/service manual, you can pretty much run any ATF or light weight oil in the nv140. It won't matter. That case is super simple and a quite durable single gear chain drive.
Jeep specs ATF+4 cause it's readily available in the jeep lineup but it's not critical.
I had 2 quarts of amsoil leftover from another vehicle and used it up in the transfercase of my jeep for the last 2 changes.
2007 WK 3.7
Drew is offline
post #11 of 12 Old 10-02-2013, 09:38 AM
modernblueWK
Qt2 was available with the 3.7 although rare.
SOLD 2008 WK 4.7 V8
post #12 of 12 Old 10-02-2013, 12:56 PM
yzjwk
2005 WK
I've heard that too , but IMO unless someone comes forward i think it's a myth , just like the myth that some 5.7L WKs came without MDS .
90 YJ Islander 4.2L
2010 MK Patriot
yzjwk is offline
