-   WK Grand Cherokee & XK Commander Forum (http://www.jeepforum.com/forum/f67/)
-   -   Maintenance Questions 3.7 WK (http://www.jeepforum.com/forum/f67/maintenance-questions-3-7-wk-1629017/)
JackB1 09-27-2013 01:56 PM
These questions came about after I downloaded the pdf. file for WK maintenance manual. I have an 08 WK Larerdo with 3.7., Q1
First the main. manual definitely states to use 5w-30 in 3.7 and 5w-20 for V-8 yet my owners manual states to use 5w-20 and oil cap states 5w-20. Why the discrepancy?
Second is that the main. manual refers to lubricating an upper knuckle ball stud but I cannot see that in owners manual lube recommendations. Is that only in certain models?
I am light duty use and transmission oil change for that in manual shows it at 102k or 5 years. Transfer case and axles seems to be every 30K. Sound right?
modernblueWK 09-28-2013 09:09 AM
Yes the miles reccomendation for the trans and axles sounds good. You should check their condition more often though.
5w20 was adopted for increased mpg's. You can use either. Both oil viscosities will work fine.
JackB1 09-29-2013 09:38 AM
Thanks for the reply. What about this upper knuckle ball stud. Has that been eliminated as a grease point on later WKs?
colinzj 09-29-2013 10:31 AM
No grease fittings on the WK. Everything's sealed and lifetime lubed.
If you're looking at the 05 FSM that's floating around, some of it's copied and pasted from the WJ. When in doubt, check twice and assume it's wrong.
JackB1 09-29-2013 06:13 PM
Thanks. Yes the FSM I have was downloaded from someone who put it on the forum. I could not find a date on it which is why I thought the grease fitting might have been eliminated. Glad I do not have to worry about that. It also might explain why 5w-30 oil is recommended in the FSM and not in my owners manual.
Drew 09-30-2013 06:49 PM
My mileage intervals are pretty much the same......However, Personally, I'd shorten the interval on the tranny fluid. I do mine at 60k. IMHO 100k is way to many miles.
It's an easy pan drop and filter change.
twistedlizard72 10-01-2013 02:18 AM
1 Attachment(s)
Be sure to double check the T-Case fluid recommendation. I just found out the other day, the service manual says 245/247/249 specific fluid for the 245, but the Owners manual says AFT+4.
JRLT 10-01-2013 08:44 AM
The QT1 uses ATF+4. That's what came out of mine so that's what I put back in.
yzjwk 10-01-2013 09:36 AM
The 2007 owners manual from wkjeeps .com states :
Transfer Case (3.7L Engine Only) Mopar ATF+4 Automatic Transmission Fluid
Transfer Case Mopar NV 247/245 Transfer Case Lubricant
The 3.7L engine is only available with QTI /nv140 transfer case and is the only case that ATF+4 is specified .
Drew 10-01-2013 11:29 AM
While it won't say in the owners/service manual, you can pretty much run any ATF or light weight oil in the nv140. It won't matter. That case is super simple and a quite durable single gear chain drive.
Jeep specs ATF+4 cause it's readily available in the jeep lineup but it's not critical.
I had 2 quarts of amsoil leftover from another vehicle and used it up in the transfercase of my jeep for the last 2 changes.
modernblueWK 10-02-2013 09:38 AM
Qt2 was available with the 3.7 although rare.
yzjwk 10-02-2013 12:56 PM
I've heard that too , but IMO unless someone comes forward i think it's a myth , just like the myth that some 5.7L WKs came without MDS .
The time now is 04:28 AM.
