LSD for 2005 4.7L WK (limited) - JeepForum.com
post #1 of 7 Old 06-22-2009, 01:51 PM Thread Starter
alexr40
Hi
I got a 4.7L limited (auto)
its 2wd with open diffs..
I am looking forward adding an LSD to the rear.
anybody knows what type / model is the rear differential?
Chrysler 8.25, dana..etc?
I read that its 3.73 gear ratio
I just need to know which diff its in order to shop for it.
thanks
1998 Jeep Wrangler 2.5L Turbo @11psi
Locked Front & Rear, 4.56s, 4:1 low range with 2LO. 35's with Beadlocks .
2005 WK Limited 4.7L - 4x4 (QT-II)
2" RC Lift, 265/70/17 BFG AT/KO, OME Rear Shocks, Saguaro Shackle Mounts, Mopar OEM Hitch
alexr40 is offline
post #2 of 7 Old 06-22-2009, 03:03 PM
Texas WJ
Texas WJ's Avatar
2005 WK
Texas WJ is offline
post #3 of 7 Old 06-22-2009, 03:23 PM Thread Starter
alexr40
yep I saw that. but the only info it provides there is the gear ratio and the ring diameter.
alexr40 is offline
post #4 of 7 Old 06-22-2009, 06:30 PM
nostaw22
The 8.3" ring gear indicates a Chrysler 8.25 axle.
D44 is only on the SRT models.
JW
1998 XJ - built for offroading
2007 WK CRD - DashHawk, for towing the XJ
nostaw22 is offline
post #5 of 7 Old 06-22-2009, 07:07 PM
Acidcold
2005 WK
I thought that the 2 wd wk's had a 3.92 gear? maybe it's just the 3.7's
Acidcold is offline
post #6 of 7 Old 06-22-2009, 10:26 PM
nostaw22
That is the gear ratio, not the size (diameter) of the ring gear. Gear ratio is a function of the number of teeth on the pinion gear and on the ring gear.... The ring gear diameter doesn't change.
The 3.73 gear ratio is pretty standard for most WKs.
JW
nostaw22 is offline
post #7 of 7 Old 06-23-2009, 07:49 AM
scottydog
2017 WK
Maybe trade it in for a 4wd/lsd?
scottydog is offline
2005 Limited 5.7 questions RusherRacing WK Grand Cherokee & XK Commander Forum 9 02-05-2010 10:24 AM
Problems with 2005 4.7 Limited sf2007 WK Grand Cherokee & XK Commander Forum 13 08-23-2009 08:25 PM
Rims for 2005 GC Limited altgilbersnick WK Grand Cherokee & XK Commander Forum 3 11-17-2007 10:33 PM
2005 JGC Limited Gas milage mdmliberty ZJ Grand Cherokee Forum 11 08-30-2005 11:53 AM
