Lower Grill Expanded Metal Insert - JeepForum.com
post #1 of 9 Old 07-14-2013, 02:21 PM Thread Starter
DRCracker
2006 WK
I was able to make an aluminum lower grill insert fairly easily.
The toughest part was removing the bumper cover,
but that is comparatively quick and easy.
I purchased a sheet of 3/4" expanded aluminum from a local truck body shop.
Cost about $35 for 3'X3'. I chose aluminum because it would be lighter, easier to bend, less likely to corrode quickly, and strong enough to offer some radiator protection.
Measuring the lower grill opening and the angles I came up with a pattern.
36" in length, 4" top section,' 4.5" middle section, 1" lower section.
Upper angle approx. 140 deg., lower angle approx. 40 deg.
Primed, painted, clearcoat. Would work easily with bedliner or any paint.
The insert fits into and around the lower opening and was secured with ss bolt and nylock nut and washer above insert.
This will not work with a front receiver and it was secured in a similar fashion from the bottom in that case.
The aluminum is easily trimmed with snips to allow clearance for tow hooks or matrix fittings.
Sorry the light is not good and the photo's don't show the insert well,
but as it is Dark Khaki, it is hard to see here.
Good luck.
TC
MOLON LABE: 2006 WK Limited, Dark Khaki Pearl, 5.7 HEMI, QDII,
Console XDs-45acp, Billet Catch Can, Airaid CAI Tube,
1" Spacers, Steel Armadillo Sliders, Dark Khaki 4xGuard Front Skid,
Dark Khaki 2011 #9104 Wheels, Firestone Destination A/T 265/70/17's.
OME HD lift. Dark Khaki Matrix Brush Guard, Dark Khaki Painted Headlight Bezels.
Hemi Club #65 // Khaki WK Club #40
DRCracker is offline
post #2 of 9 Old 07-15-2013, 01:55 PM
TurboDiesel
2008 WK
looks good!!
2008 CRD // GDE Eco // DPF delete // 3" intercooler // OME HD // 265 dirtytracs etc.
TurboDiesel is offline
post #3 of 9 Old 07-15-2013, 03:00 PM
0321Nick
2006 WK
Tip of the hat to you sir.
Where did you get the expanded sheet from?
KHAKI CLUB #65
2006 WK 4.7L V8 - Modified OME HD with Bilstein 5125s (28" length); JBA UCA; JKS Rear Discos; K&N CAI; PowerStop Discs; HyperTech; TOYO Open Country AT IIs 285/70/17; + some other goodies
0321Nick is offline
post #4 of 9 Old 07-15-2013, 06:36 PM
BurmaJack
2008 WK
Nice job!
'08.5 WK Laredo CRD North Edition; QTII;
Modern Blue Pearl; GDE HOT Tune
Blue WK Club Member #2
BurmaJack is offline
post #5 of 9 Old 07-15-2013, 07:16 PM Thread Starter
DRCracker
2006 WK
Thanks,
The local Lowes had no idea what I was looking for.
I purchased it at a local Truck Fabrication shop, named J&J Truck Bodies.
Try your local shops that use these products, farm supply, etc.
TC
post #6 of 9 Old 09-19-2013, 08:31 PM
Whit
1950 CJ3A
Thanks for that mod!
I will be doing this and glad you did it that way. I started to look into it but no time to take the cover off and explore.
1950 Willys CJ3A, all stock except 33" BFG M/T
2011 black WK2, 5.7L Hemi
Whit is offline
post #7 of 9 Old 11-18-2014, 01:40 PM
luckyse7ens
2010 XK Commander
I came across this on the expanded sheet grille thread. Do you have any better pictures of how this is attached?
Black WK Club #152
luckyse7ens is offline
post #8 of 9 Old 11-18-2014, 02:08 PM
BoraBora
2015 JK Wrangler
Lol I was just looking at this earlier too and was wondering the same thing.
'15 JK 2.5" lift on 35's
'06 WK 3.5" lift on 33's (Sold)
BoraBora is offline
post #9 of 9 Old 11-18-2014, 07:41 PM Thread Starter
DRCracker
2006 WK
It is secured with nuts and bolts through the upper fascia.
I drilled two holes in the upper lip of the bumper cover as you can see in some of the photo's.
The profile of the metal bends under the opening at the bottom and is bolted above the opening at the top.
If you look carefully at the photo's you can see the two bolts and the lim in the metal going underneath the grill opening.
I hope you can see it.
Even after snipping out parts for the tow hooks, the metal was still very secure.
TC
