Low headbeam - JeepForum.com
post #1 of 27 Old 12-23-2013, 10:00 PM Thread Starter
iamruano
2005 WK
Low headbeam
I'm new to the forum, and just purchased a 2005 grand cherokee. I noticed that my headlights seem to be rather low, the beam doesn't seem to have much of a distance on them. Is this a common problem or have a common fix? My first jeep.
iamruano is offline
post #2 of 27 Old 12-24-2013, 04:59 AM
marka2k
2006 WK
Headlights on the WK in my opinion are not very good, a lot of people swap in Silverstars or another quality bulb (easiest upgrade), if you want to get creative you can go all the way up to Projectors with HID bulbs.
Have you checked the alignment to see if they are angled down to far?
Silver WK Club #46
06 WK Overland
04 Rubicon
2000 Grand Cherokee
2006 Commander Limited - Wife's
marka2k is offline
post #3 of 27 Old 12-24-2013, 09:13 AM
oldsmoke
2009 WK
Aiming Headlights
There are several posts on this topic but here goes again.
I find the stock headlights on my WK are very good when aimed properly
If you look under the hood near the headlights on each side you will see an adjuster by the back the headlights that accepts a medium size Philips screwdriver. It is marked with a bi-directional arrow marked R and L
This means raise and lower not right and left. There is no adjustment for right and left and both low and high beams are aimed together with the one adjustment. I found out the hard way that the driver's side adjuster is labeled backwards. I am assuming the headlights on the 05 are the same as mine. I have the round headlights.
Diesel Ecotune-DPF, 32" tires, 2" lift. 4xGuard bib, tow hooks
oldsmoke is offline
post #4 of 27 Old 12-24-2013, 09:26 AM Thread Starter
iamruano
2005 WK
Thanks for your response, I'll look around a little next time before asking a question.
iamruano is offline
post #5 of 27 Old 12-24-2013, 09:57 AM
modernblueWK
I installed silverstars and adjusted them up just a bit. HUGE DIFFERENCE.
SOLD 2008 WK 4.7 V8
2013 Hemi Durango Crew
2007 Silverado Crewcab LT3
modernblueWK is offline
post #6 of 27 Old 12-24-2013, 10:49 AM
oldsmoke
2009 WK
Silverstars
Yah, you can never have too much light. I may look into some Silverstars. Will I need a bigger alternator to power them
oldsmoke is offline
post #7 of 27 Old 12-24-2013, 10:59 AM
marka2k
2006 WK
No, in this case a bigger alternator would not help, depending on voltage at the connector a upgraded harness might due to line loss.
Silver WK Club #46
06 WK Overland
04 Rubicon
2000 Grand Cherokee
marka2k is offline
post #8 of 27 Old 12-24-2013, 11:48 AM
imthehink
The biggest improvement are HIR 9012 Bulbs. Very pleased with mine, don't waste your money on silverstars.
imthehink is online now
post #9 of 27 Old 12-25-2013, 08:04 AM
ducktail
2009 WK
If I have read correctly, you may have to trim the 9012 bulb base to fir the connector in the jeep or the headlight lamp base. If they were meant to be used, I would think you would not have to trim. Being that I once had an old vehicle that light upgrades were a bit rough on, I would be hesitant to upgrade to make it fit.
The new lights melted the wire sheathing on my light harness and the dimmer switch never worked for very long. Got very hot to the touch and when driving barefoot, it was a surprise to have a torched toe.
I have had no problems with Silverstars in any vehicle and they do help over a standard bulb or so it seems. You should just replace bulbs every so often anyway as the filaments wear out.
2009 GC Limited. 265 70 18 is the only change to date. Bought some Rubicon 17" wheels and put BFG M/T's on for hunting season OME HD Front, OME MD rear, winch to come, basket and lights bars first
ducktail is offline
post #10 of 27 Old 12-25-2013, 08:20 AM
modernblueWK
Silverstars are great. Zero risk of anything but bright white light.
SOLD 2008 WK 4.7 V8
post #11 of 27 Old 12-25-2013, 09:13 AM
imthehink
Have a read, might learn something.
http://www.danielsternlighting.com/t...good/good.html
And 9012's are completely safe, do a search.
post #12 of 27 Old 12-28-2013, 07:29 AM
DVB
2006 WK
I was thinking of grabbing these silverstars. Plug and go right?
2006 4.7 Limited QD II, Stock
DVB is offline
post #13 of 27 Old 12-28-2013, 08:13 AM
modernblueWK
Yes. My 08 might take a different model though. Not 100%. Really happy with them though.
SOLD 2008 WK 4.7 V8
post #14 of 27 Old 12-28-2013, 09:02 AM
DVB
2006 WK
I'll probably pick them up. I've been looking for a better light (white) and I'm not interested in anything super fancy. Thanks.
DVB is offline
post #15 of 27 Old 12-28-2013, 10:25 AM
modernblueWK
I installed mine in april 2009 when I bought the Jeep. Just had one go out during this last summer. 4 years and 40k miles or so. Not bad. I replaced both and kept the old good one as a spare. I still have the stock high beams. Happy with those.
SOLD 2008 WK 4.7 V8
