Loud clicking noise from dash - Page 2 - JeepForum.com
post #16 of 37 Old 01-09-2012, 05:50 AM
LJS8510
LJS8510's Avatar
2015 WK
It could be the recirculation flap mechanism.
I had the 1/2 gear part that operates the recirculation flap break. It closed recirculation flap all the time, even when the knob was not set on it.
This gear is a half gear located under the dash, near the center hump on passenger side. You need to remove the cover & look for broken plastic.
I did not change it myself but the mechanic knew right where to go & as I watched he pulled out the part.
It looked fairly easy to check & replace.
2015 WK II 5.7 Overland, Offroad Group II,- 2008 WK Limited 3.0 CRD, - 2003 WJ Laredo 4.7, - 2001 WJ Laredo 4.0, - 1999 WJ Limited 4.7-
LJS8510 is offline
post #17 of 37 Old 01-09-2012, 06:34 AM
oyealiz
Originally Posted by Z28Justin View Post
I think there is a thread here that gives instructions, but you utilize the a/c and rear defrost instead of the buttons listed.
My noise case back so I just unplugged the actuator because I'm cheap and don't really use the recirculate
How do we get to the actuator to unplug it?
oyealiz is offline
post #18 of 37 Old 01-09-2012, 07:00 AM
Z28Justin
2005 WK
The recirculate actuator is behind the glove box, so you have to remove that. If it's one of the other actuators there is a panel under the steering wheel you can remove to get to them
2005 WK Laredo. 4.7L Quadratrac-II (K&N)
1995 Camaro Z28 (too many mods to list)
Z28Justin is offline
post #19 of 37 Old 01-09-2012, 10:51 AM
trax95008
2006 XK Commander
This is the gear everyone is talking about
trax95008 is offline
post #20 of 37 Old 04-18-2013, 11:09 AM
andyblack
I'm bringing this thread back to the top to see if anyone has verified that this actuator gear thing is what's causing the loud noise before I tear into my wife's '08 Grand Cherokee to see if I can get the noise to stop. Does the '08 have the same setup as the '05? Hers has got the automatic dual climate control.
Has anyone replaced this gear and got the noise to stop?
andyblack is offline
post #21 of 37 Old 04-18-2013, 10:49 PM
trax95008
2006 XK Commander
That gear fixed it on my 06
post #22 of 37 Old 10-29-2013, 07:49 AM
paroxysym
2007 WK
whats the part number on that
2007.5 WK Laredo 4.7
OEM+
paroxysym is offline
post #23 of 37 Old 03-06-2014, 04:56 PM
HudsonBronson
anyone know a part #? I think this is happening on my 03 TJ
HudsonBronson is offline
post #24 of 37 Old 11-17-2014, 09:26 AM
MistyLawrence
My 06 Jeep Grand Cherokee started doing this as well.
MistyLawrence is offline
post #25 of 37 Old 11-17-2014, 06:32 PM
segona
2007 XK Commander
I believe Part # 68072190AA
segona is offline
post #26 of 37 Old 02-11-2015, 02:59 PM
brademeyer21
2010 Jeep Liberty noise
I have the same noise and problem on a 2010 Liberty. It is coming from the actuator on the air dam in the heating system. Looking for a resolution.
brademeyer21 is offline
post #27 of 37 Old 02-11-2015, 07:02 PM
Tango.
2008 WK
This is usually some leaf or twing got into the blower. Remove the blower, remove the leaf or twig and put it back together (unusally 3 screws). ... buy a cabin filter if it happens alot.
or ... try turning the fan to high then off then high then off and try and chop up the leaf or twig with the fan if your lazy.
Life is hard-John Wayne
Tango. is offline
post #28 of 37 Old 02-11-2015, 07:15 PM
05BlackWK
2005 WK
Has anyone been able to find the cause and resolution of this yet? Happens almost every time I start my car for around 15 seconds... Pretty annoying...
05BlackWK is offline
post #29 of 37 Old 02-13-2015, 11:59 PM
AFguy247
2005 WK
Mine does too. It seems to really do it though when i switch my ac to heat while in AUTO setting...
AFguy247 is offline
post #30 of 37 Old 02-14-2015, 08:37 AM
05BlackWK
2005 WK
Next time I go to the dealership I'm going to ask
Loud clicking noise when looseing traction fugi ZJ Grand Cherokee Forum 13 10-14-2009 09:12 AM
Loud clicking noise when going 60...plz help 4x4jeepguy ZJ Grand Cherokee Forum 3 05-05-2009 10:36 AM
HELP...All of a sudden a loud clicking/ticking noise after filling up JeepMeNow ZJ Grand Cherokee Forum 11 05-04-2009 10:10 PM
HELP~~Engine started making a loud clicking/ticking/knocking noise yesterday... JeepMeNow ZJ Grand Cherokee Forum 4 05-04-2009 09:20 PM
Clicking Noise Behind Dash?? Dawggrl ZJ Grand Cherokee Forum 15 11-21-2006 09:55 AM
