Lost a Wheel Yesterday... - JeepForum.com
post #1 of 17 Old 11-28-2013, 11:12 AM Thread Starter
jbarrett
Removed
jbarrett is offline
post #2 of 17 Old 11-28-2013, 11:17 AM
tjkj2002
2002 KJ Liberty
If you only torqued the lugnuts to 40lbs-ft that was the problem,should be 100lbs-ft.Once one loosens it vibrates the rest loose.
tjkj2002 is offline
post #3 of 17 Old 11-28-2013, 11:19 AM
Jeffro06
Jeffro06's Avatar
40ft lbs for lugs? Really? I do 95 ft lbs, re-check after 50 miles. Yes it's possible they all rattled loose....in fact I think you have he best evidence to back that up.
Sucks to hear that happened to you.
Jeffro06 is offline
post #4 of 17 Old 11-28-2013, 11:23 AM Thread Starter
jbarrett
Removed
jbarrett is offline
post #5 of 17 Old 11-28-2013, 11:23 AM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
I've had that happen before Not a fun time loosing a rear wheel on the hiway
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #6 of 17 Old 11-28-2013, 11:27 AM
tjkj2002
2002 KJ Liberty
Originally Posted by jbarrett View Post
Typo - sorry. 70 ft lbs. I understand the spec is 100 ft lbs (+/- 15), but I have been tightening those lugs to 70-75 lbs for years. Never had any problems. Ever.
100lbs +/- 15 is 85-115 so you were under.It was bound to happen sooner or later.I always go to max spec,better to safe the sorry and yes you must recheck after 50 miles or so.
By rotational forces the right side lugnuts tend to loosen while the left side tightens itself and why big trucks use both left hand and right hand thread wheel studs/lugnuts.
tjkj2002 is offline
post #7 of 17 Old 11-28-2013, 12:03 PM
yzjwk
2005 WK
I agree^^ and i think large temperature differences between the alloy rims and steel hubs makes a difference too.I torque to 120-130 ft lbs and my 125lb wife can break them loose with a 2' breaker bar .
5 and counting :05 WK 5.7 HEMI
90 YJ Islander 4.2L
94 ZJ Ltd 5.2 ,00 WJ 4.0
2010 MK Patriot
yzjwk is offline
post #8 of 17 Old 11-28-2013, 01:09 PM
tjkj2002
2002 KJ Liberty
Removed
Removed
Ahhhhh can't fess up to your own mistake?
tjkj2002 is offline
post #9 of 17 Old 11-29-2013, 09:45 AM
EasternPA
2005 WK
Maybe we should start a "lost a wheel" club. I lost the left front at 45-50 mph on a country highway.
EasternPA is offline
post #10 of 17 Old 11-29-2013, 02:47 PM
paroxysym
2007 WK
I'd join... Lost the left rear going into a right hander at 30
2007.5 WK Laredo 4.7
OEM+
paroxysym is offline
post #11 of 17 Old 11-29-2013, 06:49 PM
toycam
There is such a thing as over-torquing.
toycam is offline
post #12 of 17 Old 11-29-2013, 06:56 PM
colinzj
2006 WK
This becomes clear when your wheel goes rolling down the road with the studs still attached.
2006 WK Laredo 4x4 4.7L
1993 ZJ Laredo 4x4 4.0L Dead, sold, and rolling again
colinzj is offline
post #13 of 17 Old 11-29-2013, 07:59 PM
tjkj2002
2002 KJ Liberty
Yes there is but going to max spec is not "over-torqueing" and they under rate the wheel studs by a far amount.
tjkj2002 is offline
post #14 of 17 Old 11-29-2013, 09:57 PM
toycam
It's true that the studs can handle a bit more stress, but I make it a practice to initially torque it to the minimum setting. That way if theres any play or discrepancy in my mind that it's not secure enough, I still have some wiggle room in how much more torque I can apply.
| '05 4.7L V8 | OME HD | Matrix 4xGuard | 4xGuard Front Skid | 265/70/17 TreadWright M/Ts |
toycam is offline
post #15 of 17 Old 11-30-2013, 07:39 AM
BAH101
2008 WK
In aviation, unless it is a castellated nut with a cotter pin we always torque to the max setting. Then when checking the torque, you use the min setting to ensure it hasn't moved.
2008 CRD QDII, OME HD, Pintlers wheels with 265/70/17 Goodyear Silent Armour's, Jeepinbyal UCA's. 4XGuard Front guard, Side Guard, belly guard, Matrix HC. GDE ECO Tune w/ delete.
BAH101 is offline
