Quantcast Loss in MPG after new plugs - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Loss in MPG after new plugs
Old 03-15-2010, 02:23 PM   #1
Kaliber35
So, this week I did the following maintenance and repairs to my 05 WK:
New NGK Platinum Core Plugs
New front and rear diff oil (Mobile 1)
New transfer case oil
New rear hub assembly
New power steering pump
New rear brakes
Within a few days I have noticed my MPG drop from 16-17 to 13-14. Any idea as to the cause? I suspect the plugs...
Kaliber35 is offline   Reply With Quote
Old 03-15-2010, 03:39 PM   #2
robpp
do you have the 5.7 V8 Hemi (2005-2008) then it calls for Mopar p/n SPRE14MCC4 (Champion 570) (.045 gap, 16 plugs, tighten to 13 ft. lbs.*)
maybe you should stick to the original copper core plugs?????
I know its a must on the 4.7. or if you have the 4.7, then its a def NO on the platinum plugs.
Rob 007 Laredo 4.7 FFV 27X; DeBadg'd; Zaino'd; SRT8 Grill, Pedals, Strut; ClearBra; WeatherTech; LED Reverse; HIR Hi/Lo; SS Fog; Stealth Turns; 15% Tint; Stubbie; Rear Spoiler; Magnaflow; V1; 22Elite Console/Visors; Body Kit; Color Match Everything; TintedTails; K&N 63; Front Skid; QuickOilDrainValve; BatteryTender; SuperChips 91; Bilstein; Billet Window Switches; Greasable Addco Sways; RamMedic Hood; Fastman TB; BWoody Links; Kicker Upgrade w/Single Sub; AVIC F90BT Hacked; NeffyWrap ABCD; Putco LEDs; Viper 20s w/255/50; R1 Slot/Dimple w/Hawk Pro Ceramic; Whistler Mod w/FlashTech Halos
robpp is offline   Reply With Quote
Old 03-15-2010, 04:31 PM   #3
Kaliber35
I have the 3.7
Old 03-15-2010, 04:38 PM   #4
thewalrus
2005 WK
I noticed this also on my EVIC readout on the dash, it will only last for a couple of weeks with normal driving then you will notice an improvement. No need to worry, the car is just relearning how to drive is all.
-Thanks
ASE Master Tech
thewalrus is offline   Reply With Quote
Old 03-15-2010, 05:08 PM   #5
Kaliber35
Is this a verifiable fact? No offense...
Old 03-15-2010, 10:31 PM   #6
maxst2
2006 WK
It will do that only briefly. Computer will pretty much sort it out in a minute at the most.
You should have copper plugs in it per factory recommendations.
Side note did you check the gap? Buddy with a WJ 4.0L got platinum's for his and couple were off. He ended up taking them back and got coppers after I told him too and he got his MPG back.
maxst2 is offline   Reply With Quote
Old 03-16-2010, 02:44 AM   #7
dsalinas
2006 WK
factory plugs are the best for these jeeps, I would stick with copper for sure
dsalinas is offline   Reply With Quote
Glock Forum
