Looking for DPF Delete Pipe - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Looking for DPF Delete Pipe
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LinePANDEMIC-USA 50" Double row LED LIGHT BAR!! These thi50" SINGLE ROW PANDEMIC LED Light bar FEATURES 4D Opt
Unread 02-22-2014, 02:38 PM   #1
jaje
2007 WK
I actually bought one long ago and sold it as was not figuring I'd use it. But I need one as I'm doing a GDE tune with the delete (have a cost P242F so need to replace it anyway). Please let me know if anyone has one for sale. Thanks.
'14 WK2 EcoDiesel Limited
'13 Subaru BRZ
#74 Exocet - NASA ST3 / E0
jaje is offline   Reply With Quote Quick reply to this message
Unread 02-22-2014, 03:48 PM   #2
hulikner
2008 WK
Contact tnadanzig on here. He still sells some I believe.
hulikner is offline   Reply With Quote Quick reply to this message
Unread 02-22-2014, 06:20 PM   #3
jaje
2007 WK
Sent a PM last week and haven't heard back so he might be really busy. Just in a bind right now - CRD runs fine but want to get the tune and delete done. Trading up on a WK2 Ecodiesel so want to get this done before I sell it.
'13 Subaru BRZ
Unread 04-30-2014, 07:07 PM   #4
C12H23
New to the forum
I am also interested in doing the DPF Delete
I read a previous thread by ( Tnadanzig ) on DPF and pondering removing the CAT also
Does anybody know if he still fabs the delete pipe?
Has anybody chopped the CAT?
If so would you need to install Sim's on the 02 sensors,
or could you just run spark plug anti foulers?
Sorry about all the questions :P
C12H23 is offline   Reply With Quote Quick reply to this message
Unread 04-30-2014, 07:19 PM   #5
The_Admiral
2007 WK
Originally Posted by C12H23 View Post
New to the forum
Same question for me, is Tnadanzig still doing fabs for 07 DPF Delete? What about elephant pipe mods (I'm smelling quite a bit of fumes when I roll to a stop.)
The_Admiral is offline   Reply With Quote Quick reply to this message
Unread 04-30-2014, 07:25 PM   #6
TangoTango
2008 WK
What CAT? There is a resonator, DPF and muffler. What are you guys talking about?
TangoTango is offline   Reply With Quote Quick reply to this message
Unread 04-30-2014, 08:53 PM   #7
caddydaddy
2007 WK
Are you sure about that?
2007 CRD Limited 4x4
GDE ECO Tune, Turbo Resonator Delete
2" RC lift
173,000+ miles!
caddydaddy is offline   Reply With Quote Quick reply to this message
Unread 04-30-2014, 09:38 PM   #8
Ariont
2009 WK
Here's a couple of links that might help you out as far as where to get the DPF Delete pipe and also Chirpz step by step procedure
Step by Step by Chirpz - http://www.jeepforum.com/forum/f67/d...-step-1490831/
Additional performance mods including DPF delete - http://www.jeepforum.com/forum/f67/j...-mods-1411857/
HTH
Mine - 2009 Grand Cherokee Overland, 5.7 Hemi, QD II, K&N Air Filter, Headlight Beauty Covers, Cabin air Filter
Wife's - 2004 Grand Cherokee Special Edition, 4.0 L, 4x2
Proud Member of the Black WK Club - MEMBER #128
Ariont is offline   Reply With Quote Quick reply to this message
Unread 04-30-2014, 10:40 PM   #9
tnadanzig
tnadanzig's Avatar
2007 WK
I still make the DPF deletes. I will PM with info. I just got done making some new downpipes that remove the CAT's (2). You will plug the O2 sensor back in the new downpipe. If you have DPF delete tuning you will not get a CEL if you remove the CATS. I have EHM plugs and kits.
Preview Picture of downpipe. The stock one is two pieces and I wouldn't want to try to snake a one piece into that location.
CB Engineering
CB-engineer.com
2008 3.0L CRD WK LTD - Wifes, GDE DPF Delete Tune, Turbo Resonator Delete, 3" Intercooler, Addcoo Rear Sway Bar, 3.07 gears
2007 3.0L CRD WK LTD - Stage 2 Custom Spooling Tune, Go Fast Parts
Pro-lite Build
2003 F250 6.0L CCLB - Gearhead Tunes
tnadanzig is offline   Reply With Quote Quick reply to this message
Unread 05-01-2014, 06:09 AM   #10
BAH101
2008 WK
What are the pros and cons of removing the CATs?
2008 CRD QDII, OME HD, Pintlers wheels with 265/70/17 Goodyear Silent Armour's, Jeepinbyal UCA's. 4XGuard Front guard, Side Guard, belly guard, Matrix HC. GDE ECO Tune w/ delete.
BAH101 is offline   Reply With Quote Quick reply to this message
Unread 05-01-2014, 09:25 AM   #11
tnadanzig
tnadanzig's Avatar
2007 WK
The pros of removing the CAT's are lower EGT's and better performance. However, you won't notice it unless you are running a HOT tune or ugraded turbo. I have both so I need all the help I can get. I am working to get 300 whp so I won't leave anything to chance. You will have to run a DPF delete tune for the downpipe to work. Worse emissions and a little bit more exhaust smell, but it's really not any worse than with just a DPF delete.
CB Engineering
CB-engineer.com
Pro-lite Build
Unread 05-01-2014, 01:37 PM   #12
jediknight
2008 WK
Is your lambda sensor disconnected?
2008 WK CRD Blue, QD II, Startech SD6 mod.
jediknight is offline   Reply With Quote Quick reply to this message
Unread 05-01-2014, 02:11 PM   #13
The_Admiral
2007 WK
My google search engine (Big brother's watchdog) "randomly"popped this link up on my screen. http://news.pickuptrucks.com/2013/01...te-filter.html
So this stuff makes me wanna cuss. Is the DPF delete illegal or not?
Unread 05-01-2014, 07:34 PM   #14
tnadanzig
tnadanzig's Avatar
2007 WK
No, it is connected.
CB Engineering
CB-engineer.com
Pro-lite Build
Unread 06-22-2014, 05:17 PM   #15
ItsCalicoJack
2008 WK
Alright, I have all the pieces and software to knock this out. How much time should I realistically allot myself to do the DPF delete?
2008 WK S-Limited CRD, GDE Eco tune, 2" OME HD lift, Goodyear Duratrac 265/70R17
ItsCalicoJack is offline   Reply With Quote Quick reply to this message
