-   WK Grand Cherokee & XK Commander Forum (http://www.jeepforum.com/forum/f67/)
-   -   looking to do first lift need advice (http://www.jeepforum.com/forum/f67/looking-do-first-lift-need-advice-2082138/)
CherokeeRokr 02-06-2014 07:58 PM
Alright I own a 2006 jeep grand Cherokee and have been wanting to lift it for awhile now I finally found some spare money and now I'm unsure which way to go
Looking for 2-3 more inches and planning on adding largest tires I can but am unsure of which type of lift to go with I have seen three different lifts.
only spacers for all four wheels no other parts
New coil springs and spacers
Or new socks and struts and coil springs
I'm not sure what the actual differences are and would appreciate someone helping me by explaining a little
I was looking at a skyjacker 3" lift in the picture shows coil springs and for bars that look like struts with no compression just sold bars and was wondering how good of a quality these are
Thanks in advance
pancake 02-06-2014 08:43 PM
Originally Posted by CherokeeRokr
Alright I own a 2006 jeep grand Cherokee and have been wanting to lift it for awhile now I finally found some spare money and now I'm unsure which way to go Looking for 2-3 more inches and planning on adding largest tires I can but am unsure of which type of lift to go with I have seen three different lifts. only spacers for all four wheels no other parts New coil springs and spacers Or new socks and struts and coil springs I'm not sure what the actual differences are and would appreciate someone helping me by explaining a little I was looking at a skyjacker 3" lift in the picture shows coil springs and for bars that look like struts with no compression just sold bars and was wondering how good of a quality these are Thanks in advance
What you're describing is not for the wk... Look at the daystar lift for the wk, rough country lift for the wk, and if you are willing to spend more money then go for the Old man emu lift for the wk. If you need new shocks and struts then go with the ome lift because it consists of new shocks and struts in addition to new coil springs.
The first two I mentioned are both spacer lifts that run ~ $140 these are probably your best bet if your shocks and struts don't need replacong
CherokeeRokr 02-06-2014 09:49 PM
ok but is there an actual difference between the three in ride and control and longevity of the vehicle?
Jeepforthewin 02-07-2014 05:47 AM
With a spacer lift the ride will be more rough. A full suspension lift will typically ride like stock if not better (usually better in most peoples mind). A spacer lift is basically stacking a peice of steel or poly on top of your coils front and rear. In the long run this will cause more wear on the coils and other suspension components. A Suspension lift comes with longer coil and also slightly longer shocks and struts to achieve the best ride possible.
BoraBora 02-07-2014 09:44 AM
Really? My OME rides REALLY rough. I mean literally I feel every bump in the road and speed bumps just straight suck.
dieseljeep07 02-07-2014 10:18 AM
If you were looking at a 3" lift then I would say just go for the 4" Superlift or an OME. I had the 2" daystar and loved it, but after a year I just wanted to go bigger. So save the $150 and just go big. Then you can run the nice 33" tires and it looks so sweet.
Anon155 02-07-2014 10:27 AM
Bora, what psi are you running in those duratrac's? You may be running them a bit high, I had to lower my pressure down some to get a bit more give for road use and better wear. I've read most say the duratrac 285's run best at 32-35 psi. If you're running higher than that, that may be why the bumps feel so harsh. The OME rides like a dream compared to some of the other suspensions I've had on other cars/trucks....
BoraBora 02-07-2014 12:02 PM
I have no idea what PSI they're at...hmmm that actually probably is it because I've read everyone else loves the ride. I on the other hand bounce around. I'll try 33 or 34 PSI and report back. Thanks man
Jeepforthewin 02-07-2014 12:16 PM
Exactly what happened to me and now i have a modified SL and 35's sitting in my garage :2thumbsup:
The time now is 04:58 PM.
