Looking for CRD trans pan with drain. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Looking for CRD trans pan with drain.
XJ Rail Sale!The Ruffstuff NOT Universal 4 Link Kit!Vanco Big Brake Kit Promotion!
Unread 05-30-2014, 10:10 AM   #1
meatlord
Animals taste good
meatlord's Avatar
I have been searching for a trans pan with a drain in it for my 07 CRD. I saw a link here somewhere and after searching extensively have had no luck at all. What are the options for drains and deep capacity pans?
05 Rubicon "Big Stupid" / 99 XJ on 31s "Nurple" FOR SALE. / 07 WK Limited CRD GDE Hot Tuned DPF delete. / 00 TJ "One Shot Wonder"/ 03 Nissan SE-R 6 speed V spec. / 00 Suzuki DR650.
meatlord is offline   Reply With Quote Quick reply to this message
Unread 05-30-2014, 10:50 AM   #2
scootr29
scootr29's Avatar
2008 WK
Not sure if this has the drain..can't see it in the picture...
http://europarts-sd.com/engineoilpan2007-2012-1.asp
Silver WK Club Member #1
2008 CRD QT2
scootr29 is offline   Reply With Quote Quick reply to this message
Unread 05-30-2014, 10:56 AM   #3
meatlord
Animals taste good
meatlord's Avatar
That is engine oil pan, looking for transmission pan with drain and or extra capacity.
Unread 05-30-2014, 11:46 AM   #4
caulk04
2008 WK
Why not just buy an aftermarket drain plug? Drill hole, install plug, done.
http://www.amazon.com/80250-Automati.../dp/B00029WR78
Tint, Superchips, SRT intake tube, Gibson catback, catch can. One hardcore DD/kid hauler...yeah.
caulk04 is offline   Reply With Quote Quick reply to this message
Unread 05-30-2014, 11:51 AM   #5
meatlord
Animals taste good
meatlord's Avatar
That is definitely an option and I am a very experienced TIG welder. My interest is more in a larger capacity(6+ quarts) one was MB I believe.
Unread 05-30-2014, 01:00 PM   #6
scootr29
scootr29's Avatar
2008 WK
sorry about that...here is the transmission oil pan with drain
http://europarts-sd.com/transmissionpan2002-2009.asp
2008 CRD QT2
Unread 05-30-2014, 02:55 PM   #7
grywlfbg
I ran a PML pan on my Liberty CRD for the last 5 years - 2.5 quarts over stock and has a drain plug.
http://www.yourcovers.com/transmission_pans.html
Chris
Current: 2007 WK CRD Limited
Past: 2005 KJ CRD Limited, 2000 TJ
grywlfbg is offline   Reply With Quote Quick reply to this message
Unread 05-30-2014, 03:59 PM   #8
ca07wk
Crawl-Offroad.com
2007 WK
I just ordered one from here.
http://www.mercedespartscenter.com/p...&siteid=215720
Also B&M makes a deep pan with drain and temp gauge port.
http://www.crawl-offroad.com/#!produ...deep-trans-pan
Crawl-Offroad.com-Boycott Paved Roads
2006 WK Limited Modified QT2
OME HD/RRO UCA/Wrangler MTRs on Moabs/JKS Rear Discos/Steel Armadillo Skids, Sliders,Front Shackles,Antenna Mount/Crawl Rear Skid
ca07wk is offline   Reply With Quote Quick reply to this message
Unread 05-30-2014, 06:05 PM   #9
Hendrix9
2007 WK
That B&M pan looks awesome!
2007 CRD QDII
4XGuard Matrix, GDE Eco Tune
DPF delete, RC 2.5 lift on 265/70/17s
Hendrix9 is offline   Reply With Quote Quick reply to this message
Unread 05-30-2014, 07:21 PM   #10
ca07wk
Crawl-Offroad.com
2007 WK
It really does, Im pretty excited it has a trans temp gauge port, wish I would have waited and got that instead of the Mercedes one
Unread 05-30-2014, 08:16 PM   #11
TangoTango
2008 WK
just FYI
The trans pan is not where you want the trans temp guage. It is just convenient, but not the correct place. The correct place is to put the temp sensor in the hot line. You can use some plumbing parts from lowes ot home depot to T-Tap it in the hot line.
ALSO.. a deep dish pan is unless if you do not install the drop down for trans-oil the pick up. So make sure you also get the pick-up adapter.
TangoTango is offline   Reply With Quote Quick reply to this message
Unread 05-30-2014, 08:48 PM   #12
ca07wk
Crawl-Offroad.com
2007 WK
the B&M comes with everything required to make it work correctly.
Unread 06-01-2014, 11:33 AM   #13
meatlord
Animals taste good
meatlord's Avatar
Thanx for all the helpful replies. Does anyone have details on the longer pick up tube that was mentioned? Or would the supplier be better to ask this question?
Unread 06-01-2014, 01:38 PM   #14
ca07wk
Crawl-Offroad.com
2007 WK
I would ask B&M, on their website is says extended filter mount.
Unread 06-01-2014, 08:57 PM   #15
quicksilverado
2007 WK
I have bought several B&M deep pans over the years, they all came with the extension tube. It says the extension tube is included.
07 Grand Cherokee Limited CRD 4X4 GDE tune
00 Silverado 10 sec work truck
quicksilverado is offline   Reply With Quote Quick reply to this message
