Long start issues after engine rebuild - JeepForum.com
post #1 of 17 Old 01-22-2013, 08:05 PM Thread Starter
rizzmonkey
Hey All,
I purchased a 2005 GC limited about 6 months ago. 3 months after, it blew a head gasket. Thus far we have completely replaced the heads and all components, injectors, timing chain guides, and EGR valve.
Since the car came back from the mechanic it now has long start issue. It will crank over for 3-5 seconds before it starts. This never happened one time before the repair. The mechanic said to get the ECU reflashed because he thought it may have been messed up since it was un-plugged from a power source for over a week. This doesn't make much sense to me.
Does anyone have any advice?
Thank you.
rizzmonkey is offline
post #2 of 17 Old 01-22-2013, 08:23 PM
Butterjeep
2015 WK
Try this, disco the negative terminal from the battery and then step on the brake pedal to "bleed" out any residual electrical energy out of the system, then let it sit for a few minutes for good measure. Then reconnect the battery and turn the engine on (should take longer to crank) and once it's started, let it idle for a few minutes. Then, without turning the engine off, hop in and drive a few miles, stop and go, a little bit of highway speeds if you can, etc. this is to give it a chance to relearn everything. Hopefully this cures the issue.
2014 Mustang GT Track Pack
2015 WK2 Limited 4x4
Butterjeep is offline
post #3 of 17 Old 01-23-2013, 01:20 PM
Radcrd
2007 WK
Sounds like the timing may be off.
2007 WK CRD QDII, GDE HOT tune. 275/55/18'' on Sahara's, SRT8 suspension.
2000 Jetta TDI (hers)
2006 Liberty CRD (sold)
3 VW TDI's (sold)
Radcrd is offline
post #4 of 17 Old 01-23-2013, 05:34 PM Thread Starter
rizzmonkey
Is it electronically timed? It runs excellent once it gets going...
post #5 of 17 Old 01-24-2013, 08:38 AM
Radcrd
2007 WK
Im not sure..., did they remove the timing chain when they did the work? could it be re-installed one tooth off by accident? I have never worked on a chained car but have seen belts off by one tooth. Typically resulting in slow start and lack of power.
3 VW TDI's (sold)
Radcrd is offline
post #6 of 17 Old 01-24-2013, 11:49 AM Thread Starter
rizzmonkey
No it would be way off if they did that. Like i said it runs excellent ones it's running.
post #7 of 17 Old 01-24-2013, 05:08 PM
oldfamilyguy
Check the fuel line connections. It may be leaking pressure and needs a few seconds priming to get it back up again.
oldfamilyguy is offline
post #8 of 17 Old 01-24-2013, 05:57 PM
yzjwk
2005 WK
another thing you can try is to prime the pump a couple times to build presssure and to see if the pump or as stated above a loose connection is bleeding the pressure down. turn the key to the on position but don't start it then turn the key all the way to off , wait 1 sec and then back to on and try to start as normal .if it's bleeding back quickly you may have to go to on-off a few times .
good luck
5 and counting :05 WK 5.7 HEMI
90 YJ Islander 4.2L
94 ZJ Ltd 5.2 ,00 WJ 4.0
2010 MK Patriot
yzjwk is offline
post #9 of 17 Old 01-24-2013, 08:31 PM
manhands
2007 XK Commander
My hemi commander doing same thing after installing junk yard engine . cant figure it out either . not happening all the time just when park and hop back n and fire it up after short time .
Never use a XK as a sub. Hemi's dont like water.
manhands is offline
post #10 of 17 Old 01-25-2013, 07:21 PM
R32R1
2006 WK
Fuel pump might be tired
R32R1 is offline
post #11 of 17 Old 11-23-2013, 04:17 PM Thread Starter
rizzmonkey
Just wanted to revisit this after some time as I still have this problem.
post #12 of 17 Old 11-23-2013, 05:52 PM
90grandoneer
90grandoneer's Avatar
2006 WK
Does it do this every time you start it, or just the first time after sitting a while? Did you ever check the fuel pressure? If it is good, it could be a leaky injector that's bleeding off pressure when it sits.If this is the case, you can do like yzjwk said in Post 8. I'd do the key on-off thing a few times though, before trying to start it.
Also, when it finally does start, is it a little rough right at first....and then smooth out?
06 GCO, Dk Khaki, QDII, Flshing Hi 3rd Bk Lt, MDS "ON" Lt, Airtab Vortex Gens, Debadged, Fumoto Drain Valve, BT Catch Can, Chopped EGR Tube, SRT8 CAI, K&N Filter, Sonnax Trans Line Press Booster, SC Tuner W/Adv Trans Tune App, DS Tuner, Cust tubular hdrs w/3 in Magnaflow/Xlerator AP Exh Sys, Bilsteins, SRT Springs/Sways, Cust Eng Cvr, SRT8 frt/rear bumpers, FRI Sidewinder Cam/6.1 valvetrain, SLP 25% UD Pulley, BBK true 90mm T-Body, SOS Ign Coils w/.060 spark plug gaps, SRT Reps with 265/45&295/40X20's.
90grandoneer is offline
post #13 of 17 Old 11-23-2013, 07:14 PM Thread Starter
rizzmonkey
It usually only does it after it's been sitting for a while. And yes, it does sputter a bit when i finally goes. Weird is that when the top end was redone, the mechanic has the fuel injectors sent to some other vendor that cleans them and inspects them.
I will go try the key off key on test to see if that helps. Stay tuned!
post #14 of 17 Old 11-23-2013, 07:55 PM
twistedlizard72
2007 WK
No DTC's?
Per the Service manual for 5.7L no start condition:
1. weak battery
2. corroded or loose battery connection
3. faulty starter
4. incorrect spart plug gap
5. dirt or water in fuel system
6. faulty fuel pump, relay or wiring
Engine stalls or rough idle:
1. idle speed set to low
2. vacuum leak
3. incorrect timing
Nothing specifically for a long start issue. I'm sure you can rule out most of those, but may be able to find a direction to solve the problem.
Kevin K.
twistedlizard72 is offline
post #15 of 17 Old 11-24-2013, 02:24 PM Thread Starter
rizzmonkey
Thanks for your response!
I do have a check light that comes and goes and just pulled it. It is P0404 which has to do with the EGR. This is most frustrating since the EGR valve was replaced about 10 months ago. Also I commented on each of your ideas below.
Originally Posted by twistedlizard72 View Post
No DTC's?
1. weak battery (just replaced)
2. corroded or loose battery connection (100% clean)
3. faulty starter (cranks over strong every time, would assume that means OK right?)
4. incorrect spark plug gap (possible but wouldn't this cause it to run poor once running?)
5. dirt or water in fuel system (possible but would i've been dealing with this for 10 months)
6. faulty fuel pump, relay or wiring (probably most likely except we never had this problem until the heads were replaced. Grr!!!)
2. vacuum leak
3. incorrect timing
