Long Crank,Engine Light,Throttle Light on 2008 WK CRD - JeepForum.com
post #1 of 2 Old 05-04-2010, 10:32 AM Thread Starter
CanDieselJeep
2008 WK
Wife went to drive my son to work and the GC cranked for 15 seconds before starting. When it finally started the throttle warning light and engine lights were on. She drove it to get him to school and shut it off to walk him in. When she came out it restarted like normal with no lights on.
Just a minor hiccup or is there a more serious problem lurking here?
By the way it only has 32000km on it and it has never had any previous problems!
CanDieselJeep is offline
post #2 of 2 Old 05-04-2010, 10:18 PM
Funtuzzi
2008 WK
That has happened to my wife as well. Similar scenario. Turned the Jeep off, did her business, went back to the truck.......started normal, no dash lights, and has never happened since.
One other time, I also got a MIL light for crank position sensor. Engine was running fine. Cleared the code with my OBD II scanner, and never re-appeared.
I have 16 000 km's, and other than that has been running well. Must be a hiccup of some sort, like you said.
Funtuzzi is offline
Engine Light came on our CRD(PO 335 Crank Sensor Circuit Fault) CanDieselJeep WK Grand Cherokee & XK Commander Forum 8 06-04-2011 09:55 PM
Will a light/check engine light come on ltningjace WK Grand Cherokee & XK Commander Forum 1 03-03-2010 08:04 PM
Check engine light after long trips Tantor WK Grand Cherokee & XK Commander Forum 9 01-03-2010 12:00 AM
CRD Wouldn't Start on First Try & CEL & Throttle Light Came On WKDiesel WK Grand Cherokee & XK Commander Forum 4 11-28-2009 11:19 PM
Light Throttle 'hooting'? lawdogg ZJ Grand Cherokee Forum 1 01-12-2008 08:42 AM
