Lockers for Commander? - JeepForum.com
post #1 of 7 Old 12-05-2005, 11:50 PM Thread Starter
Dan_McCarthy
Does anyone know what aftermarket lockers or limited slips are available for the Commander?
I understand that the Commander rear is a Chrysler 8.25 inch. Is that right?
And does anyone know what the Commander front end is?
Dan_McCarthy is offline
post #2 of 7 Old 12-06-2005, 07:30 AM
BlaineWasHere
BecauseRacecar
BlaineWasHere's Avatar
The front end is IFS so it would not be a axel commonly known to Jeepers... If infact the XK does what the 8.25 rear end then there are lockers for that axel. Check www.xkjeeps.com for info on what axels it has and such...
2013 FR-S
BlaineWasHere is offline
post #3 of 7 Old 12-06-2005, 07:31 AM
BlaineWasHere
BecauseRacecar
What 4WD do you have? If you have the QuardaDriveII you already have front and rear electronic Limted Slips... and If you have QuadraTracII you have a Limted Slip in the rear...
2013 FR-S
post #4 of 7 Old 12-07-2005, 07:12 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Blaine,
that guy did a drive by posting.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #5 of 7 Old 12-07-2005, 09:29 AM Thread Starter
Dan_McCarthy
I am thinking of getting one with the Quadratrack II, not the CommandTrack II. The CommandTrack II only comes in the Limited and I don't want to spend that much.
Are you sure that the QuadtraTrack II already has a limited slip in the rear end? My local dealer doesn't know anything about it, unfortunately. They say the front end is a "200 mm" and I got the parts guy to confirm that the rear is a Chrysler 8.25. So there are aftermarket lockers and limited slips for the rear (if it does not come with one) but that leaves open the question of what might be available for the front.
Thanks!
post #6 of 7 Old 12-07-2005, 10:29 AM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
If it is the same axle as the Liberty (Liberty has the 8.25 in the rear as well) then a D30 IFS is up front if that helps your search for a locker/LSD.
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #7 of 7 Old 12-20-2005, 11:27 AM
carmannj
I thought the commander had the same drivetrain as the grand cherokees, jeep just basically put a different body on that platform.
carmannj is offline
08+4.7 in an 06 commander? medicbear WK Grand Cherokee & XK Commander Forum 4 12-08-2009 04:15 AM
Does the Commander have locking differential 4 wheel drive? ie 06 commander Glock23 WK Grand Cherokee & XK Commander Forum 1 03-28-2007 07:43 AM
ARB Lockers for Commander TRCommander WK Grand Cherokee & XK Commander Forum 5 08-21-2006 07:23 AM
Should i buy a commander jeepdude10000 WK Grand Cherokee & XK Commander Forum 35 07-05-2006 07:05 PM
commander vs H3 cwbrg WK Grand Cherokee & XK Commander Forum 56 11-22-2005 03:19 PM
