Locker Options for WK - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Locker Options for WK
FLASH SALE! Open thread to reveil the Newest Sale @ ROCKRIIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Wrangler RGB Multicolor Fog Light LEDs: Awesome Effect
Unread 03-05-2015, 09:05 PM   #1
VT-05WK
2005 WK
So I'm going to put a locker in the rear in the upcoming months but I have some questions. First off, I have an 05 limited 4.7 L with quadra trac 2
1. The rear axle is listed as 213 mm which is 8.38" however I thought the WK had the Chrysler 8.25" so what exactly fits in the rear axle?
2. If it is 8.25" then it is either 27 spline or 29 spline. Is the only way to know for sure to pull an axle shaft and count?
3. If I do have to pull a shaft, are they floating shafts or are they c-clips?
I'd like to do an Aussie or lunchbox type locker such as a trac lock or something along those lines. Anyone running lockers and have advice?
Any help is appreciated
'05 WK 4.7L V8, OME HD w/ Bilsteins, 1.5" Spidertraxx, Flowmaster 40 series
Cobra CB, Dipped Badges
VT-05WK is offline   Reply With Quote Quick reply to this message
Unread 03-05-2015, 09:23 PM   #2
johngreen1234
2010 WK
When I was researching custom diff covers my noggin also absorbed the following bits of info which I will post for you, although I don't pretend to understand it:
The casing (pumpkin), and ONLY the casing, is a Chrysler 8.25. Everything else inside conforms to the 213mm standard. ISTR also that it was an odd spline count and none of the usual suspects would fit it.
Someone who knows what they're talking about will post soon and provide full and correct info. In the meantime I would be VERY skeptical of anyone who assures you it's an 8.25 inside.
johngreen1234 is offline   Reply With Quote Quick reply to this message
Unread 03-06-2015, 05:22 AM   #3
VT-05WK
2005 WK
Hmmm that's very interesting. Thanks for the info! I'll have to keep all that in mind. Hopefully someone running a locker can shed some light on it
Unread 03-06-2015, 06:07 AM   #4
GermantownJeep
When Nitro did their WK build, the used an ARB for the 8.25. I don't see a spline count.
http://www.jeepforum.com/forum/f67/n...topics/1666505
1995 Wrangler Rio Grande: RE 4.5" Lift, 33" MT/R's
2010 Grand Cherokee Limited: Hemi, QD II, 30" Nitto Terra Grapplers
GermantownJeep is offline   Reply With Quote Quick reply to this message
Unread 03-06-2015, 06:14 AM   #5
SSF556
SSF556's Avatar
2008 WK
This is what you need...RD93....I have this one sitting in my garage and will be installing it in the next couple of weeks...
http://www.4wheelparts.com/Drivetrai...9&t_pn=ARBRD93
Silver WK Club Member #1
2008 CRD QT2
SSF556 is offline   Reply With Quote Quick reply to this message
Unread 03-06-2015, 06:49 AM   #6
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
With the exception of the SRT8s, all the WK/XKs have a C8.25 29 spline rear axle.
~Mike~
Build Thread WK
Other Build Thread XJ
September 2013/January 2015 COTM
JeepN4KC is offline   Reply With Quote Quick reply to this message
Unread 03-06-2015, 07:01 AM   #7
VT-05WK
2005 WK
Thanks for all the input. Unfortunately, an ARB air locker is out of the question for me due to money. I'm hoping that I can figure this stuff out and get an Aussie or something else similar to that
Unread 03-06-2015, 08:03 AM   #8
yzjwk
2005 WK
there's a few guys on here that have already done the Aussie locker you just have to search http://www.jeepforum.com/forum/f67/a...-rear-1246750/
I'm pretty sure you can find at least one guy with a powertrax as well
Good luck
5 and counting :05 WK 5.7 HEMI
90 YJ Islander 4.2L
94 ZJ Ltd 5.2 ,00 WJ 4.0
2010 MK Patriot
yzjwk is offline   Reply With Quote Quick reply to this message
Unread 03-06-2015, 09:54 AM   #9
caulk04
2008 WK
Only very early 8.25" axles were 27spline. I'm not talking early WK axles either, I'm talking early in production of the 8.25 overall.
FWIW...
08 5.7 Limited - Intake - Exhaust - SC Tuner - BT catch can - 5100's - white LED dash and lighting
caulk04 is offline   Reply With Quote Quick reply to this message
Unread 03-06-2015, 10:37 PM   #10
VT-05WK
2005 WK
Yeah I saw that earlier but wasn't sure since I didn't know the spline count. I just want to verify before purchasing anything but all of this definitely helps. Thanks guys!
Unread 03-06-2015, 10:57 PM   #11
TangoTango
2008 WK
With a 29 Spline... won't this Detroit fit it?
Detroit Locker | Part Number: EAT187SL47A
AMC Model 20 3.07 Up Automatic Locker
http://www.4wheelparts.com/Drivetrai...pn=EAT187SL47A
They are c-clips... floating is usually only on 3/4 ton+
Black WK Club #147
Life is hard. ...- John Wayne
TangoTango is offline   Reply With Quote Quick reply to this message
Unread 03-06-2015, 11:07 PM   #12
TangoTango
2008 WK
This is the one I have been looking at.. TrueTrac. ... have one on the front end in my ram diesel. It is limited slip Clutchless Operation.
Chrysler 8.25 29 Spline TrueTrac
Detroit Locker | Part Number: EAT912A553
http://www.4wheelparts.com/Drivetrai..._pn=EAT912A553
Black WK Club #147
Unread 03-06-2015, 11:29 PM   #13
Kolak
Vendor
Kolak's Avatar
If a True Trac would work, one would then assume a lunchbox type setup such as the Powertrax No-Slip would as well. That would save you from having to swap carriers and thus the added labor of re-shimming the diff and getting installing carrier bearings.
Kolak Performance and Offroad
Member: Specialty Equipment Market Association
Telephone: 480 998-3661
kolak@aol.com or kolak@kolakperformance.com
Kolak is offline   Reply With Quote Quick reply to this message
Unread 03-07-2015, 08:41 AM   #14
Red_liner740
Correct me if i'm wrong, but my axles just pulled out from the hub side when i did my rear hubs...wouldnt that make them floating and not c-clip axles?
Red_liner740 is offline   Reply With Quote Quick reply to this message
Unread 03-10-2015, 08:13 PM   #15
hxdrummerxc
hxdrummerxc's Avatar
2008 WK
Im very interested in the rear Aussie locker that user Lifted_Up installed here http://www.jeepforum.com/forum/f67/a.../#post11999279
It seems very nice, an im sure I could live with the daily driving quirks. And the price isn't bad at all. I can afford $299, but $1,000+ for an air locker..... not gonna happen for me.
But I have one question, why the rear?
I was talking to my brother and he says that a lot of JK guys will put lockers on the front first. For two reasons..... 1. Less problems with daily driving even with AWD because the front's arent being used very often 2. Rock crawling and "step-up" situations, wouldn't it make more sense to have your fronts locked since those are going to be up on the the rocks or higher ground first, essentially pulling you up?
Do we not have a locker option for our fronts?
EDIT:
There is also the spartan locker that fits our rear.
http://www.usastandardgear.com/Produ...x?ProdID=11590
08' Limited 5.7L QTII | Hemi Club #76 | RC lift | Custom painted headlights with Oracle LED Halos | Bwoody 4" Short Ram Velocity Intake | Flowmaster Super 44 & resonator delete | Superchips Vivid |
hxdrummerxc is offline   Reply With Quote Quick reply to this message
