On Line Parts - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > On Line Parts
The Original 3/8" Ruffstuff Diff Cover!The Cure for your Tie Rod Roll!Bolt In Jeep JK Tie Rod Kit!
Unread 07-16-2015, 03:58 PM   #1
rhusak
2008 WK
On Line Parts
Hi all..
I have an 08 Overland CRD.. I have some parts I need to replace due to the Colorado Highway Departments use of Mag Chloride..
At a minimum these are.. The Grill, The lower front bumper cover Moulding and a rear bumper step pad.. The last is not due to the mag chloride but just jeep parts fade..
Could use all the stainless parts (TRim) replaced but other than that listed I can tolerate..
Anyone have a good on line location to buy OEM parts? My local dealers are charging over list!!! Called indexing..
Any tips would be appreciated..
Ron Husak
08 Overland CRD with InMotion Tune
Livin at 9200Feet lookin down at ya!
rhusak is offline   Reply With Quote Quick reply to this message
Unread 07-16-2015, 06:52 PM   #2
n7vrz
2005 WK
www.rockauto.com
n7vrz is offline   Reply With Quote Quick reply to this message
Unread 07-17-2015, 06:03 AM   #3
nvrdone1
2007 WK
try LKQ.com. They recycle just about any body & mechanical part you might need
nvrdone1 is offline   Reply With Quote Quick reply to this message
Unread 07-17-2015, 06:38 AM   #4
paroxysym
2007 WK
justforjeeps.com, they offer 5% off with certain coupon codes.. PM ME if youd like the code.
also check out rtpartsco.com for your OEM parts needs as well.
2007.5 WK Laredo 4.7
OEM+
paroxysym is online now   Reply With Quote Quick reply to this message
Unread 07-17-2015, 07:42 AM   #5
caulk04
2008 WK
For the grille and bumper cover, I'd just look into aftermarket replacements from RockAuto or eBay. Otherwise, look for used OE parts at a salvage yard.
On the rear bumper pad, remove it and paint it. I used Krylon Fusion semi-gloss black and it's great. Bonded well, looks like a brand new part and it looks to me like it'll last 3-4 years before I want to redo it, I did it about 2 years ago.
08 5.7 Limited WK - Basic stuff...
caulk04 is offline   Reply With Quote Quick reply to this message
