Lifts, I just don't understand them... - Page 2 - JeepForum.com
post #16 of 32 Old 04-16-2013, 11:48 PM Thread Starter
Jaashua
2005 WK
As far as I can tell the off roading is much better out there. I'm excited to join in the fun.
Jaashua is offline
post #17 of 32 Old 04-17-2013, 03:01 AM
Tbonfire
2006 WK
Easier to change the oil lol
Tbonfire is offline
post #18 of 32 Old 04-17-2013, 10:44 AM
06JeepXKHEMI
As its been stated, knowing the tires you want to run and wheeling you'll be doing is what dictates the type of lift you need/want. Typically, people go for the cheap route to start, RC spacer lift which since you have new struts/shocks, may be a good option. These spacers go between the strut assembly and strut tower, giving approximately 2" of lift. The good part of these lifts is theyre cheap, easy install and pretty much does the job. The next set up is what I have the OldManEmu springs with struts and shocks. The struts and shocks themsleves do not give lift, but rather the springs and increased spring rate (stiffness). This lift will yield anywhere from 2.5-3" depending on the options of your rig, HEMI, V6, steel bumpers, etc.. Some people, including myself opted to get longer shocks in the rear, which help with articulation or flexing when off camber, this is not a must but more of preference to increase abilites of wheeling. Because this lift yields more lift, larger tires can fit with some minor modifications. When lifting these IFS, independent front suspension, Jeeps, there is very little articulation, flex, in the front suspension. Which leads to the next lift, the 4" Superlift, which utilizes a similar strut spacer upfront with stock or equivalent shocks, struts and springs, but also includes drop down brackets for the front differential and other components keeping close to if not identical stock geometry. This will help with articulation and performance off-road. Some people then take it to the next step, and use a SL with OME yielding 6-8" of lift, but this puts more stress on front end components and youre now back to limiting articulation.. Hope this helps a bit..
05 LJRubi Currie 4" Springs, Savvy Fox shocks, MC trackbars, MC CA's single adj lower double uppers, 37x13.50 Cooper STT Pros on 17x9 ATX Ravine, MC Overlines front, Genright rear, Revolution 5.38s, Carolina Driveline driveshafts, MCAI
06JeepXKHEMI is offline
post #19 of 32 Old 04-17-2013, 11:11 AM
bhawks28
2014 JK Wrangler
ahh, yes this is one benefit I didn't foresee when I put my lift on. I love it!
2014 JKU Rubicon
bhawks28 is offline
post #20 of 32 Old 04-17-2013, 12:15 PM
Willboy93
Actually you don't even need to lift if you aren't looking for that big of tires. You can buy the highline fender kit and fit up to 35s on those
Willboy93 is offline
post #21 of 32 Old 04-17-2013, 12:19 PM Thread Starter
Jaashua
2005 WK
This is the best description I have seen. I cant exactly think of a time when I would need more than the spacer lift.
Sent from my Samsung S2 using JeepForum
Jaashua is offline
post #22 of 32 Old 04-17-2013, 12:56 PM
06JeepXKHEMI
Its all a matter of what type of wheeling you will be doing and what level of wheeling at that. The more difficult trails will be easier with a better suspension set-up, that being said many have done a lot with simple spacer lifts..
post #23 of 32 Old 04-17-2013, 12:56 PM
06JeepXKHEMI
Unfortunately we dont have those highline fender kits for our Jeeps, you lucky bastards!!
post #24 of 32 Old 04-17-2013, 01:05 PM
Imped
Imped's Avatar
What supports the vehicle off of the axles from the factory? Springs. Longer/higher rate springs will sit higher, therefore "lifting" the Jeep. Moving the body further away from the axles will move the upper shock mounts (on the body) further away from the lower shock mounts (on the axle). Therefore, longer shocks are needed. When it comes to travel bias, bump stops, link suspension geometry and the finer nuances of suspension components, those are different subjects that you'll find information on elsewhere.
This is why I hate the terms "lift" or "lift kit." That doesn't actually tell you anything....I prefer calling the components by their name--springs, shocks, control arms, bump stops, etc instead of referring to an entire "kit" as "a lift." The only time you'll hear me use that word is when I'm talking about a 2 or 4 post unit.
OlllllllO
IndyORV
Imped is offline
post #25 of 32 Old 04-17-2013, 01:12 PM
Willboy93
Oh haha I go through so many forums I forgot this wasn't a tj thread!
post #26 of 32 Old 04-17-2013, 01:51 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
I would hope you would be able to keep track of both of your posts.
Luck Favours The Prepared
Anticanman is offline
post #27 of 32 Old 04-17-2013, 02:05 PM
Willboy93
Yeah it should be easy. What I meant was I look through a lot.
post #28 of 32 Old 04-17-2013, 02:10 PM
R4TCHET
2005 WK
you should see colorado...
also the RC lift is a good lift. however, i would go with OME MD or HD as it will ride better and lift it a little more, and in general is just better, it is a ~$500 difference though.
| (dark)KHAKI WK CLUB MEMBER 17 | 2005 4.7L QTII | JBA UCAs | Modified OME MD 3.5" lift | Rusty's Adj. track bar | 4XG Matrix | 285/70r17 Duratracs | 17" KMC Enduro Wheels | Rola Roof Rack | 21" Bean LED Light bar on Roof Rack | 2 12" Punch P3 Subs | Expanded Sheet Grille | SA Sliders |
R4TCHET is offline
post #29 of 32 Old 04-17-2013, 02:47 PM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
Once you put good shocks/struts on all corners to go with the RC it isn't that much of a difference.
If you trully plan to wheel it - OME FTW!
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is offline
post #30 of 32 Old 04-17-2013, 03:43 PM
R4TCHET
2005 WK
I know lol there were reasons i got what I got (see sig) but in the end of it, it would have been better to get the OME
Sent from my Jailbroken iPhone using JeepForum
R4TCHET is offline
