Lifted before plates - Page 2 - JeepForum.com
post #16 of 62 Old 09-26-2013, 06:31 PM
fiddy5cj5
1955 CJ5
What's up with the pinch welds
fiddy5cj5 is offline
post #17 of 62 Old 09-26-2013, 07:06 PM
Jeepforthewin
2010 JK Wrangler
What do you mean?
2010 JKU - Stock for now
2005 WK - 6" lift, 35" BFG's, a lot more (SOLD)
Jeepforthewin is offline
post #18 of 62 Old 09-26-2013, 07:22 PM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
It's a unibody thing......... you wouldn't understand.
(CJ5) ;-)
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is offline
post #19 of 62 Old 09-26-2013, 07:23 PM
WieSeL
Originally Posted by fafafofi View Post
Had to do pinch weld because of 285s. You can keep your MDs in front and order the bilstein struts. They adjust from 3/4", 1.5 or 2. They were around $175 a pair.
Got them from Kolak but I saw someone in the forum had a set for sale too
Ok I did my fronts already but wasn't able to get the fender liner to flatten out too much
WieSeL is offline
post #20 of 62 Old 09-26-2013, 08:48 PM Thread Starter
fafafofi
2006 WK
After using a heat gun for multiple hours, I just cut out the section that bubbled out
fafafofi is offline
post #21 of 62 Old 09-26-2013, 08:57 PM
sk1er18
2007 XK Commander
Self tapping screw.... 10 seconds, done.
-Matt
sk1er18 is offline
post #22 of 62 Old 09-26-2013, 09:16 PM
WieSeL
Did that....
WieSeL is offline
post #23 of 62 Old 09-26-2013, 10:30 PM
fiddy5cj5
1955 CJ5
Originally Posted by JeepN4KC
It's a unibody thing......... you wouldn't understand. (CJ5) ;-)
Actually I sold the 5 now I got a cj3a but I got my wife a wk and I wanna do a 2-3 in lift and 285s so I was curious what your doin with pinch welds
post #24 of 62 Old 09-27-2013, 07:03 AM
sk1er18
2007 XK Commander
Originally Posted by WieSeL View Post
Did that....
And it didn't pull the liner back?
The past 4 pinch welds i've done I was easily able to use a self tapper on each one to pull liner against it.
I don't have pictures with a screw, but this shows how flat i get the pinch weld. Maybe yours bulges out a bit still so its hard to get the liner flush against it?
http://www.theultimatejeep.com/showt...ot-How-To-quot
-Matt
sk1er18 is offline
post #25 of 62 Old 09-27-2013, 07:19 AM
JeepN4KC
JeepN4KC's Avatar
The pinch weld is more or less the only spot to open up for clearance in the front wheel wells to fit bigger tires. It's the hump you see in the rear of the front wheel wells of your wife's WK. It's very common on all the unibody platforms (XJ, ZJ, WJ, WK, KJ, haven't seen a KK yet) to do this mod to get bigger meats and avoid rubbing or worse to the tires.
I have a pretty thorough write up in my build thread (posts 171 and 176) but photobucket doesn't like me right now. A quick search would probably give you what you need to know but in a nutshell: pull the wheel, wheel well liner, notch the pinch weld every couple inches between the spot welds, fold the "tabs" over with bfh, remold/self tap the liner back in place as flat as you can.
~Mike~
WK
XJ
JeepN4KC is offline
post #26 of 62 Old 09-27-2013, 09:19 AM
fiddy5cj5
1955 CJ5
Ahh ok I see what your talking about now after looking at that link it's true what they say that pics tell a 1000 words lol but Jeeze that's a huge pinch weld lol
post #27 of 62 Old 09-27-2013, 11:35 AM
Jeepforthewin
2010 JK Wrangler
Yes it is and it's fun to take some anger out on it! I actually had fun doing this mod. It's a simple process with huge gains. Especially for people wanting to run 35's!
post #28 of 62 Old 09-27-2013, 11:50 AM
fiddy5cj5
1955 CJ5
35s on a wk !!! Wow how much lift is needed for 35s
And what size meats can you fit with the pinch weld mod and no lift
post #29 of 62 Old 09-27-2013, 12:11 PM
BoraBora
2015 JK Wrangler
255/75 or 265/70 with no lift.
'15 JK 2.5" lift on 35's
'06 WK 3.5" lift on 33's (Sold)
BoraBora is offline
post #30 of 62 Old 09-27-2013, 12:25 PM
Jeepforthewin
2010 JK Wrangler
35s on a wk !!! Wow how much lift is needed for 35s And what size meats can you fit with the pinch weld mod and no lift
It's possible with the superlift if you pound the pinch weld really good and the rear fendor roll and drive only on the road. But a 6" modified superlift will fit 35's decently
