lift questions to the pro's - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > lift questions to the pro's
JKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 10-18-2013, 07:19 AM   #1
Eastwk
2007 WK
Guys i have been reading all kinds of things and have searched for the answer but cant seem to find it. I am curently running a RC 2in bb and want to put in some new shocks and struts. wanted to go with blisten 5100 adjustables in the front and monre f150 load levers in the rear. Is there any issues running the adjustables in the front even though I already have a strut spacer I want to do this to get a little more lift and to bring the jeep back to level after putting on the load levelers in the rear I thank yall for your advice and if you have any pics or suggestions please fell free.
Eastwk is offline   Reply With Quote Quick reply to this message
Unread 10-18-2013, 07:47 AM   #2
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
As long as you tune the adjustable struts to keep your hub to fender measurement inside 23" you should be fine.
~Mike~
Build Thread WK
Other Build Thread XJ
September 2013/January 2015 COTM
JeepN4KC is offline   Reply With Quote Quick reply to this message
Unread 10-18-2013, 08:08 AM   #3
ca07wk
2007 WK
What is your front hub to fender now?
Crawl-Offroad.com-Boycott Paved Roads
2006 WK Limited Modified QT2
OME HD/RRO UCA/Wrangler MTRs on Moabs/JKS Rear Discos/Steel Armadillo Skids, Sliders,Front Shackles,Antenna Mount/Crawl Rear Skid
ca07wk is offline   Reply With Quote Quick reply to this message
Unread 10-18-2013, 09:42 AM   #4
Eastwk
2007 WK
I am right at 21" how it sits now
Unread 10-18-2013, 09:50 AM   #5
ca07wk
2007 WK
You should be fine running the 5100's, 23" is about the safe limit in the front
