Lift Measurements - Page 9 - JeepForum.com
post #121 of 175 Old 03-02-2013, 05:46 PM
tfranzone
2008 WK
Originally Posted by anthonyribeca
i wanna get 23front 23 rear.
right now im sitting at 21front 21 rear with a daystar bb.
still waiting for my ome hd kit too come in.
23 in the front is the danger number where **** can get real messed up. I'd suggest going 23 in rear and 22.5 in front
2008 4.7L V8 WK --- BLACK, 2" Daystar Lift, 1.5" Spidertrax Spacers
Cooper Discoverer AT3 265/70/17, Pinch Weld Mod, Black Shorty Antenna
25% tint, PD's Wheels & Emblems, Fogs, Weathertech Digital Liners,
Drop in K&N
tfranzone is offline
post #122 of 175 Old 03-02-2013, 06:52 PM
anthonyribeca
That's what the OME hd kit yields you in the front
anthonyribeca is offline
post #123 of 175 Old 03-04-2013, 09:06 PM
sshaughn
2008 WK
My CRD is really off, 20 1/4" rear, 18 1/2 front?! Is that because of the weight of the engine? I only have 48,000 miles on it so the shocks should be okay right?
2008 WK Overland 4WD CRD 3.0L, QD2, Green Diesel Engineering Hot-Tune, MBRP Exhaust, CB Engineering Turbo Resonator Delete Pipe, Kolak Addco Rear Sway Bar, K&N Air Filter, Propel Fuels B20 Biodiesel
sshaughn is offline
post #124 of 175 Old 03-04-2013, 09:19 PM
jjt250
2007 WK
I think my front sat about that when it was stock, but the rear seems pretty high for stock suspension.
2007 Grand Cherokee Limited | QDII | 3.0L Diesel | S4xC Shackles Mounts | Goodyear Duratracs
Bilstein HD Front/Rear | Rusty's 1/2" Strut Spacer | Hemi XK Front/Rear Coils | HID Projectors
jjt250 is offline
post #125 of 175 Old 03-04-2013, 11:23 PM
trax95008
2006 XK Commander
My HEMI gave me a decent rake stock
trax95008 is offline
post #126 of 175 Old 03-05-2013, 10:03 PM
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
That's about right. The CRD and Hemi will sit lower than the smaller engines. Mine was about 19 front and 20 rear when stock.
Omelet is offline
post #127 of 175 Old 03-05-2013, 10:59 PM
Valpacer
2007 WK
What Nathan Said.
Stock height is 20". My CRD was at 19.5" and 20" with a 12 month old OME setup. Weight will do that!
2007 WH Grand Cherokee CRD (Yup, RHD Australia)- 3" Exhaust, GDE Flash Tune, CRDSTU/SL Hybrid Lift & bash Plates, 4xGuard Rock Rails, Saguaro F & R Bars, RCV's, Warn 9.5cti-s, AEV Saverge Rims, Nitto Mud Grapplers, Snorkel, Custom Rear Drawers, On Board Air, BullyDog Monitor, Dual Batteries -
Valpacer is offline
post #128 of 175 Old 03-05-2013, 11:41 PM
anthonyribeca
Even with the ome hd setup you still got sag over time ?
post #129 of 175 Old 03-05-2013, 11:56 PM
Valpacer
2007 WK
Mine did, but mine is a very heavy Jeep. WHen i had the OME, i had the XL Rola Vortex rack, ARB bar and winch with steel cable, dual batteries in the front, full roller drawers in the rear with air compressor, air tank, 2 more batteries, tools, recovery gear etc. It didnt hold up long under wheeling conditions.
I went to a Murchison Products lift after that, 22.5 front and 23" rear, and it never dropped until i fitted a rear tyre carrier and bumper from Jackie Davis.
Then with the combined kit and SL bits 26.5 front and 27" rear.
Comp spec i run at 24.5 and 25" with the 33's.
Dave
Valpacer is offline
post #130 of 175 Old 03-06-2013, 07:58 AM
trax95008
2006 XK Commander
Any NEW spring is going to "settle" a little. That's normal
post #131 of 175 Old 03-06-2013, 08:11 AM
SSF556
2008 WK
After 1 year with the OME HD here are my settings...this is with a 1/2 tank of diesel and about 100 pounds of stuff in the back. Might be time to get some poly spacers for the rear.
Front 21 3/4
Rear 21 1/2
Silver WK Club Member #1
2008 CRD QT2
SSF556 is offline
post #132 of 175 Old 03-06-2013, 08:48 AM
BAH101
2008 WK
2 1/2 years with the OME lift, 45000 miles, 3/4 tank of diesel,
Front 21 3/4
Rear 21 3/4
2008 CRD QDII, OME HD, Pintlers wheels with 265/70/17 Goodyear Silent Armour's, Jeepinbyal UCA's. 4XGuard Front guard, Side Guard, belly guard, Matrix HC. GDE ECO Tune w/ delete.
BAH101 is offline
post #133 of 175 Old 03-06-2013, 09:19 AM
norwaywj
2006 XK Commander
I have an 2006 Hemi Commander. Before lift I had 18,1" in the front and 20,1" in the back.
After OME HD I have 20,9" in the front and 21,3" in the back.
norwaywj is offline
post #134 of 175 Old 03-06-2013, 09:52 AM
anthonyribeca
I sure hope I get more then 21 with my OME lift
post #135 of 175 Old 03-06-2013, 10:47 AM
tfranzone
2008 WK
I have a daystar with a 4.7L v8. I have 20.75 and 21 in the rear. So I think you'll get more with an OME for sure
Drop in K&N
03wj 4"lift center to center upper and lower ca measurements? ronsaun ZJ Grand Cherokee Forum 1 03-09-2010 09:59 PM
measurements nuey302 ZJ Grand Cherokee Forum 1 12-29-2009 09:11 PM
Actual hub to fender measurements with 4.5" lift? bjl95mustang ZJ Grand Cherokee Forum 18 06-23-2007 09:30 PM
bb lift measurements? mdsuave13 ZJ Grand Cherokee Forum 0 12-04-2006 05:02 PM
Measurements... gdupjeep ZJ Grand Cherokee Forum 9 04-22-2006 02:42 PM
