Lift Measurements - Page 7 - JeepForum.com
post #91 of 175 Old 05-06-2012, 01:11 PM
blanco
2009 WK
Originally Posted by Budasac View Post
Yes, you can use the longer rear shocks w/ the RC lift. Mine are about 1.5" longer then stock.
Ok so i can use larger shocks only in rear and not in the front???
and thank you for respond
blanco is offline
post #92 of 175 Old 05-06-2012, 01:42 PM Thread Starter
Budasac
2005 WK
Front shocks/struts are the same length as stock.
Budasac is online now
post #93 of 175 Old 05-06-2012, 02:50 PM
JMorash
2005 WK
I feel like im the last one left running an RK lift.
I have the Bilstien problem, where now the front sits higher than the rear. Going to make some spacers to compensate for the rear springs. Compress them, and then slide in the spacers.
Had i known the OME was better, i would be runnin that.
2005 WK 5.7L Hemi
HEMI Club Member #28
3.5 Rock crawler lift.265/65R17 Toyo AT SuperChips Flashpaq MDS delete
JMorash is offline
post #94 of 175 Old 05-09-2012, 09:32 PM
blanco
2009 WK
Men i have the same problem. Mi wk its so high in the front with the Rough Country Lift 2". i dont know why??
blanco is offline
post #95 of 175 Old 05-09-2012, 09:55 PM
kllshadow
2006 WK
Add Monroe LLs they will bring the back up
Black WK Club Member #61
kllshadow is offline
post #96 of 175 Old 05-10-2012, 08:30 PM
blanco
2009 WK
I alredy use a more larger old man emu shocks and its the same. Can u pots a picture of your spring. i think tha my spring are compressed, maybe a wrong installation??
blanco is offline
post #97 of 175 Old 05-10-2012, 08:40 PM
elfirebird
2005 WK
Back to the measurements, Bilstein HDs in front, Monroe 58643's in back and Daystar BB.
Front - 22"
Rear - 22.5"
Riding on stock wheels and tires for now... ordered my wheels, and by the time they got ordered, they were down to 2 wheels, and they're no longer being produced. Every other wheel I had in mind, same story... or 2 month wait. =\
Have something else in mind, but they wont ship til May 20th... so.. I'll look goofy for a week and half.
2005 WK Limited Deep Beryl Green Hemi QD2 - Daystar, Bilsteins and MLL - 265 70 17 Toyo AT II - Black Rock Viper Black wheels - Aq1200D + SDC2.512 = 870 watts RMS
elfirebird is offline
post #98 of 175 Old 05-10-2012, 09:16 PM Thread Starter
Budasac
2005 WK
Your OME shocks don't help lift the rear at all, it doesn't matter how long they are. The Monroe Load Leveler shocks give a little boost because they're actually coil-over shocks. So the pressure from the shock coil deflects some of the weight from the rear springs. The stock length yield about .75" of lift but alot of people (myself included) use the shock for a F150 which is longer and gives (in my case) over 1" of lift.
post #99 of 175 Old 05-12-2012, 09:14 PM
blanco
2009 WK
Thanks a lot my fried, i got it!!!
blanco is offline
post #100 of 175 Old 05-27-2012, 11:10 AM
Jvenrick
2007 WK
With RC 2in lift and MLL's in the rear...
Front: 21 1/2
Rear: 22 1/4
Also a quick question for anyone with this set up. Did you guys find it nessary to extend the break lines. Im going to hopefully be doing a bunch of off roading this summer and just want to make sure my lines will be long enough? Thanks!!
**NVM got an answer to my question!!**
2007 Grand Cherokee Rocky Mountain Edition: 4.7L V8- QTII- Green
The build:
Jvenrick is offline
post #101 of 175 Old 05-28-2012, 06:07 AM
Luck06
2006 WK
RC lift and MLL 58643's.....
Front: 22 3/8
Rear: 22 1/4
It looks like I'm about an inch higher in the front than most of you with same lift. I just installed mine on Sat. so maybe it hasn't settled completely yet. Either that or maybe it's just the weight difference between my 3.7L and your V8's?
Luck06 is offline
post #102 of 175 Old 06-06-2012, 09:20 PM
Static83
2014 JK Wrangler
This is great info. Was curious what my OME HD lift will do when I get it. Sitting at 18 3/4 front right now and 19 3/4 back. Really need the lift, already have 255/75/17s on
Static83 is offline
post #103 of 175 Old 06-06-2012, 09:23 PM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
Dude - OME HD will leave you very satisfied...............
For a while..............:-)
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is offline
post #104 of 175 Old 06-06-2012, 10:03 PM
Static83
2014 JK Wrangler
I'm already thinking about getting spacers lol
Stock for now
Static83 is offline
post #105 of 175 Old 06-06-2012, 10:39 PM
Camp
2005 WK
Satisfied me for about 2 months. Now its on to Superlift!! Then modified Superlift. Then who knows
Sent from my HTC 3D using JeepForum
Camp is offline
03wj 4"lift center to center upper and lower ca measurements? ronsaun ZJ Grand Cherokee Forum 1 03-09-2010 09:59 PM
measurements nuey302 ZJ Grand Cherokee Forum 1 12-29-2009 09:11 PM
Actual hub to fender measurements with 4.5" lift? bjl95mustang ZJ Grand Cherokee Forum 18 06-23-2007 09:30 PM
bb lift measurements? mdsuave13 ZJ Grand Cherokee Forum 0 12-04-2006 05:02 PM
Measurements... gdupjeep ZJ Grand Cherokee Forum 9 04-22-2006 02:42 PM
