Lift Measurements - Page 6 - JeepForum.com
post #76 of 175 Old 03-06-2012, 11:25 AM
mattydipps
2006 WK
Oh, I'm definately researching and exploring my options. The Rusty's rear poly spacers for the WK and a couple strut plates per side is looking more and more like a solid option - requiring some other additions of course - but I'm still wondering about the LL's. In the end I'll most likely be "runnin what I brung" for a while.
i just ordered my MLLs... should be here wednesday/thursday and on by the end of the week
Sold-
mattydipps is offline
post #77 of 175 Old 03-06-2012, 11:26 AM
SSF556
2008 WK
Originally Posted by meep View Post
I'd consider adding urethane spacers in the rear as an alternative to Load Levelers. slightly more work, but you just bought the new shocks, and there are a few reports of LL's making noise.
Is there a good source for WK poly spacers...I would like to add a 1/2 spacer.
Silver WK Club Member #1
2008 CRD QT2
SSF556 is offline
post #78 of 175 Old 03-06-2012, 11:39 AM
t3kmitch
2005 WK
^^^ Hey, Buda - been a while since anything on your build thread. Anything new?
With those Monroe LL's - how long have you been running those?
Do you think the boost they provide has any longevity issues?
As far as longevity with the MLL's, I figure even if they do settle over time, the worst that could happen is you go closer to the original result of the RC lift. It's not like you're going to be sagging, you'd just be level again.
I think the benefit of MLL's over a spacer would be towing. Adding a cut down poly spacer will get you the lift you want for slightly more work (getting the longer MLL's on isn't hard but took a little creativity), but once you hook up a trailer you're going to sag just as much as before.
This should be moved over to the MLL thread though, don't want to muddy up this thread too much.
-Sold 3/13. Replaced by 2010 VW Jetta 2.5-
2005 WK 3.7L Laredo. RC 2", 265 70 17 Bridgestone Dueler Revo 2's. Class III OEM hitch added. Bilstein Struts. Monroe Load Levelers (58643).
Blue WK Club Member #32
t3kmitch is offline
post #79 of 175 Old 03-06-2012, 11:59 AM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
Good point.
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is offline
post #80 of 175 Old 03-06-2012, 01:47 PM
meep
2008 WK
lots out there. basically if you get the ID and OD right, any flat spacer should do. see different thicknesses on left...
http://www.jackit.com/suspension-parts/springs-and-accessories/coil-spring-spacers.html
these are what they have in 3/4"
http://www.jackit.com/suspension-par...ift_height=270
meep is offline
post #81 of 175 Old 03-07-2012, 03:13 PM
kingpin57
Finally found my tape measure and the results for my Hemi with an empty roof rack and 3/4 tank of fuel is:
Front: 21.5 inches
Rear: 21.5 inches
Rock Krawler 2in lift with stock struts up front and stock shocks in rear.
kingpin57 is offline
post #82 of 175 Old 05-01-2012, 03:05 PM
sixfoot9psu
2005 WK
rocky road leveling spacers, bilstein HD's, and some armor weight
front: 19.75"
rear 19.5"
'05 GC 5.7L Hemi QDII...Rock Krawler lift, 4XGuard Matrix, rock sliders, front and rear skids, belly guard, rear diff guard, Bilstein HDs, Volant intake, 265/70 Goodyear DuraTracs, Superchips, Rola roof rack, BORA wheel spacers, Rocky Road Leveling Spacers, Magnaflow muffler, KC Slimlights, BT catch can, tb cover, and underhood kit, Expanded Sheet Metal Grille
'09 G8 GT 6.0L...Kooks Headers, Rotofab intake, SLP exhaust, Vector Motorsports Tune
sixfoot9psu is offline
post #83 of 175 Old 05-02-2012, 03:10 AM
Valpacer
2007 WK
New specs for mine.
Full armour (front, rear, sliders, under body) full drawers and 1/2 tank.
Front: 25.5"
Rear: 26"
2007 WH Grand Cherokee CRD (Yup, RHD Australia)- 3" Exhaust, GDE Flash Tune, CRDSTU/SL Hybrid Lift & bash Plates, 4xGuard Rock Rails, Saguaro F & R Bars, RCV's, Warn 9.5cti-s, AEV Saverge Rims, Nitto Mud Grapplers, Snorkel, Custom Rear Drawers, On Board Air, BullyDog Monitor, Dual Batteries -
Valpacer is offline
post #84 of 175 Old 05-02-2012, 07:00 AM
croth
2005 WK
Stone stock, 121K miles 20 rear, 19.5 front
croth is offline
post #85 of 175 Old 05-05-2012, 08:22 PM
blanco
2009 WK
Some Help
Hi guys im from Venezuela. I have a WK with Old Man Emu "MD" Spring and shocks. the shocks are mre larger than the stock.
But now i want to remove the old man emu springs and put a Rough Country 2" Lift. The cuestion its. If the larger shocks works properly with that kit, or i have to put the original sise shocks.??
Thank you for your anwser's!!
blanco is offline
post #86 of 175 Old 05-05-2012, 09:11 PM
naidib04
2006 WK
Why switch to the RC from OME? Weird IMO.
PM me for details on Jeep
Blue WK Club Member #35
naidib04 is offline
post #87 of 175 Old 05-05-2012, 09:23 PM
blanco
2009 WK
Because the springs are due. and i have my original sprigns totally new
blanco is offline
post #88 of 175 Old 05-06-2012, 05:26 AM Thread Starter
Budasac
2005 WK
Yes, you can use the longer rear shocks w/ the RC lift. Mine are about 1.5" longer then stock.
Budasac is offline
post #89 of 175 Old 05-06-2012, 05:38 AM
Rob 99TJ
Front: 19 1/8
Rear: 19 3/16
Stock with about 88K miles on what looks like original shocks.
99' TJ Gunmetal Blue Sport /w D30 No-Slip/D44 Trac-Loc, 5spd, 2" susp./1" body, 33"MT/R's/AR767's, Durabak, Currie, Warn
07' WK Silver 5.7 QD2, Bilsteins & front strut plates.
Rob 99TJ is offline
post #90 of 175 Old 05-06-2012, 09:10 AM
ruholm
2008 WK
Front 22 1/8
Rear 21
OME MD lift kit 245/70/17 Revo's2, 5/8 shackles
ruholm is offline
03wj 4"lift center to center upper and lower ca measurements? ronsaun ZJ Grand Cherokee Forum 1 03-09-2010 09:59 PM
measurements nuey302 ZJ Grand Cherokee Forum 1 12-29-2009 09:11 PM
Actual hub to fender measurements with 4.5" lift? bjl95mustang ZJ Grand Cherokee Forum 18 06-23-2007 09:30 PM
bb lift measurements? mdsuave13 ZJ Grand Cherokee Forum 0 12-04-2006 05:02 PM
Measurements... gdupjeep ZJ Grand Cherokee Forum 9 04-22-2006 02:42 PM
