Lift Measurements - Page 2 - JeepForum.com
post #16 of 175 Old 10-26-2011, 08:09 AM
trax95008
2006 XK Commander
Bone STOCK, XK limited with HEMI, full tank of gas,
Front 18"
Rear 19.5"
Thanks to the OP for starting this thread. It's good info when trying to decide which lift to get. I noticed some variation with OME. Anyone know why this is? Is ARB's tolerances that loose?
trax95008 is offline
post #17 of 175 Old 10-26-2011, 08:23 AM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
Old Man Emu Heavy Duty:
F: 22.25
R: 22.5
The difference in OME's - in my unofficial opinion - will depend on HD vs MD; full or undersized spare (and location: on the roof won't bring the rear down like in the well because it centers over the rear axle better); gear in your rig; fuel tank full or not; is the ground the rig sits on level when measurements taken.
Buda: good thread - like the idea.
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is offline
post #18 of 175 Old 10-26-2011, 08:30 AM
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Originally Posted by trax95008 View Post
Bone STOCK, limited with HEMI, full tank of gas,
Front 18"
Rear 19.5"
It can be the differance between engines, armor, gas, and whatever else they are/aren't carrieing.
Where in Cali are you? SoCal by any chance?
My stock measurement at 45K with stock skids and no added weight was:
F - 19"
R - 19 3/4"
Omelet is offline
post #19 of 175 Old 10-26-2011, 09:29 AM
trax95008
2006 XK Commander
F - 19"
R - 19 3/4"
I'm in San Jose. (sf bay area)
I noticed no one else has a 1.5" rake like I have. I guess a HEMI and skids add a full inch of sag. I would assume my vehicle is on the heavy side as I have every option that adds weight. Skids, HEMI, tow pkg, 3rd row seats...
post #20 of 175 Old 10-26-2011, 09:44 AM
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Plus it is a Commander! How many miles are on it? If it has a lot of miles the front shocks might be bad. Adding some Bilsteins might bring it up a little.
Omelet is offline
post #21 of 175 Old 10-26-2011, 12:55 PM
paroxysym
2007 WK
bilsteins and a set of rustys spacers upfront to level her out would do the trick..
2007.5 WK Laredo 4.7
OEM+
paroxysym is offline
post #22 of 175 Old 10-26-2011, 01:23 PM
meep
2008 WK
do the bilsteins really add any lift by themselves?
meep is offline
post #23 of 175 Old 10-26-2011, 01:31 PM
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
If the struts are blown then there is no pressure in them, as opposed to a good strut that will have pressure forcing the suspension up. People have reported slight increase in height after installing new ones.
Omelet is offline
post #24 of 175 Old 10-26-2011, 01:49 PM
paroxysym
2007 WK
i think the concensus on them is they will give you like 1/2" to 3/4"...
OEM+
post #25 of 175 Old 10-26-2011, 04:27 PM
t3kmitch
2005 WK
Rough Country Spacers with [longer than stock] Monroe load levelers
Front: 21.5
Rear Passenger: 22
Rear Driver: 22 1/4
1/4 tank of gas and roughly 100lbs of tools in the back.
Update: Measured driver's side rear as well cause I didn't seem to get as much lift out of the longer Monroe's. Most of the weight in the back is sitting on passenger's side. But I also filled up today and it really didn't move. Still came out to 22 passenger side. However in the end I did notice a difference after putting them on. It now sits about perfect. (Besides that I had to scrounge around for a 7"ish drop to pull the parade float.)
-Sold 3/13. Replaced by 2010 VW Jetta 2.5-
2005 WK 3.7L Laredo. RC 2", 265 70 17 Bridgestone Dueler Revo 2's. Class III OEM hitch added. Bilstein Struts. Monroe Load Levelers (58643).
Blue WK Club Member #32
t3kmitch is offline
post #26 of 175 Old 10-27-2011, 03:04 PM
meep
2008 WK
dang. that's like over 75lbs of pressure per shock at least. hmm.
I really just want 1" front and 1/2" back. bilsteins + the 1/2 front spacer may be my ticket.
WITH ~600 lbs in the back: 19.5 front, 18 rear. I'll come back with unloaded numbers.
M
meep is offline
post #27 of 175 Old 10-27-2011, 03:20 PM Thread Starter
Budasac
2005 WK
M
I don't think you gain any lift from the pressure of the strut. It's the design of the body and where it mounts to the fork. I believe the stop tab is .5 -.75" lower on the shock body which results in the slight lift.
Budasac is online now
post #28 of 175 Old 10-27-2011, 03:25 PM
meep
2008 WK
WOW. THAT is sticky-worthy info. for real? Sounds like a boo-boo on bilstein's part but I *like* that. The
"B" won't lose its lift as it ages and loses pressure. But the same wouldn't apply for the rear... right?... so a full set of B's basically helps level the front up 1/2" and "might" raise the rear 1/4" if it has fresher pressure.
Right? There's another member here who wanted to do similar to me.... this would be the ticket to get the front up 1"... bilsteins + spacer. then cut down a poly spacer for the rear...
M
meep is offline
post #29 of 175 Old 10-27-2011, 04:08 PM Thread Starter
Budasac
2005 WK
You can use the Monroe Load Levelers in the rear if you just want a little bump. They're coil-overs so they deflect some of the pressure from the factory springs resulting in some height. They have stock replacements or if you're lifted some of us have been using the longer model made for an F-150. With the longer set I gained over an inch in the rear.
post #30 of 175 Old 10-27-2011, 06:48 PM
meep
2008 WK
I'd rather stick with "one set" of springs in the rear.... I thought about the monroes but would prefer to do the spacers out back. Front-- I'd double the rusty's spacers if the studs on the strut plate were longer, but they aren't, and my one attempt to hammer them out was a fail. So front is either, figure out how to hammer out studs so I can install longer ones with another 1/4" shim, or possibly go the bilstein route.
do we know for certain that the bilsteins have a different tab location? I'll order them tomorrow... Would kolak know?
M
meep is offline
03wj 4"lift center to center upper and lower ca measurements? ronsaun ZJ Grand Cherokee Forum 1 03-09-2010 09:59 PM
measurements nuey302 ZJ Grand Cherokee Forum 1 12-29-2009 09:11 PM
Actual hub to fender measurements with 4.5" lift? bjl95mustang ZJ Grand Cherokee Forum 18 06-23-2007 09:30 PM
bb lift measurements? mdsuave13 ZJ Grand Cherokee Forum 0 12-04-2006 05:02 PM
Measurements... gdupjeep ZJ Grand Cherokee Forum 9 04-22-2006 02:42 PM
