Lift Measurements - Page 10 - JeepForum.com
post #136 of 175 Old 03-14-2013, 10:00 AM
paroxysym
2007 WK
currently sitting at:
front- 20.5"
rear -22"
daystar BB w/ bilstein HDs (45k on those) and 58646 MLLs in the rear.
2007.5 WK Laredo 4.7
OEM+
paroxysym is offline
post #137 of 175 Old 05-23-2013, 08:13 AM
Whit
1950 CJ3A
2010 with 3.7L
2.25" RRO and Bilstein struts/shocks freshly installed for 1 week.
front=21.75"
rear=21.75"
1950 Willys CJ3A, all stock except 33" BFG M/T
2011 black WK2, 5.7L Hemi
Whit is offline
post #138 of 175 Old 05-24-2013, 07:16 PM
anthonyribeca
Soo after 3 months I sagged about a half inch in the front and .25inch Inch in the rear I guess I'll add some rustys spacers up front
anthonyribeca is offline
post #139 of 175 Old 05-30-2013, 11:17 AM
0321Nick
2006 WK
Originally Posted by 2005GRANDONE View Post
That is why I went with ome and then added the .25 spacers.
I see you put in some Bilstein 5150s. What model did you use? Did they add to the OME HD?
KHAKI CLUB #65
2006 WK 4.7L V8 - Modified OME HD with Bilstein 5125s (28" length); JBA UCA; JKS Rear Discos; K&N CAI; PowerStop Discs; HyperTech; TOYO Open Country AT IIs 285/70/17; + some other goodies
0321Nick is offline
post #140 of 175 Old 08-12-2013, 09:11 PM
sshaughn
2008 WK
Since my stock ride height is 18 1/4" front and 20 1/4" rear, maybe when I get the OME lift I should opt for HD in the front (engine weight and potential sag) and MD in the rear. I would prefer to have equal height and wear. Any thoughts?
2008 WK Overland 4WD CRD 3.0L, QD2, Green Diesel Engineering Hot-Tune, MBRP Exhaust, CB Engineering Turbo Resonator Delete Pipe, Kolak Addco Rear Sway Bar, K&N Air Filter, Propel Fuels B20 Biodiesel
sshaughn is offline
post #141 of 175 Old 08-12-2013, 09:46 PM
ca07wk
2007 WK
I've heard negative remarks about mixing the HD and MD. I would stick with one or the other, if you plan on adding armor or a winch, any weight at that I'd go HD, or go Bilstein 5100 strut up front because its adjustable from .75-2"
Crawl-Offroad.com-Boycott Paved Roads
2006 WK Limited Modified QT2
OME HD/RRO UCA/Wrangler MTRs on Moabs/JKS Rear Discos/Steel Armadillo Skids, Sliders,Front Shackles,Antenna Mount/Crawl Rear Skid
ca07wk is offline
post #142 of 175 Old 08-13-2013, 11:35 AM
overland-wk
2006 WK
I'm sitting at
Front 22 1/2"
Rear 22"
06 ROR lifted wk (mine)
07 RC lifted xk (wife's)
Youtube channel
Bumsmodified98xj
overland-wk is offline
post #143 of 175 Old 08-13-2013, 03:52 PM
audiophonicz
2007 WK
Front: 25.5"
Rear: 26.0"
audiophonicz is offline
post #144 of 175 Old 10-22-2013, 11:00 AM
overland-wk
2006 WK
Just an update on my lift measurements.
Rustys springs
Front 23" 1/2
Rear 22" 1/2
Youtube channel
Bumsmodified98xj
post #145 of 175 Old 10-22-2013, 11:31 AM
K9SAR
Front 25 1/2"
Rear 25 3/4"
'06 Overland 5.7 Hemi / QDII / Silver WK Member #59, LED Backup lights, AEV Argent Pintlers, Floor liners. Gibson 3" Stainless Steel Exhaust, 6" Hybrid Superlift / OME lift, 6" JBA rear springs, JBA UCA's, JBA rear track bar, 35x12.5/17 Goodyear MTR's, Steel Armadillo Rock Sliders, 4xGuard Bash Plates
K9SAR is offline
post #146 of 175 Old 10-22-2013, 11:56 AM
ca07wk
2007 WK
OME with Bilsteins
Front 23"
Rear 23"
I have 4 rear coil isolators on each side.
ca07wk is offline
post #147 of 175 Old 10-22-2013, 12:18 PM
Jeepforthewin
2010 JK Wrangler
Originally Posted by K9SAR
Front 25 1/2" Rear 25 3/4"
I'll be there soon!!
Currently at
Front 21.5
Rear 22.0
2" RC lift with MLL's in the rear
2010 JKU - Stock for now
2005 WK - 6" lift, 35" BFG's, a lot more (SOLD)
Jeepforthewin is offline
post #148 of 175 Old 07-30-2014, 01:16 PM
paroxysym
2007 WK
BUMP:
so i went from:
20.25" front/ 20.785" with a daystar BB, front bilstein hds, and OEM rear shocks and stock springs with 125k on them
TO
current set up- bilstein HDS on all 4 corners, XK hemi coils with a JBA strut spacer up front, SRT springs in the rear
front: 18.75-19"
rear: 19.5"
damn near level
OEM+
post #149 of 175 Old 10-03-2014, 04:59 AM
paroxysym
2007 WK
delete.. sorry
OEM+
post #150 of 175 Old 01-20-2015, 06:55 AM
una4dbl55
2008 WK
OK, I'm on Information Overload after 3 days of searching these threads,
cant decide to go with the rusty's spacer up front or not
I've got an 08 WK with the 3.7 no armor
daystar lift now and it sits at about 20 1/2" in front and 20" in the rear (to keep this post on subject)
Ive ordered the OME HD set up with OME shocks and struts and if I use a rustys spacer up front will that put me over the 23" mark or under?
I dont want to have to take it apart again to either add it or remove it,
una4dbl55 is offline
03wj 4"lift center to center upper and lower ca measurements? ronsaun ZJ Grand Cherokee Forum 1 03-09-2010 09:59 PM
measurements nuey302 ZJ Grand Cherokee Forum 1 12-29-2009 09:11 PM
Actual hub to fender measurements with 4.5" lift? bjl95mustang ZJ Grand Cherokee Forum 18 06-23-2007 09:30 PM
bb lift measurements? mdsuave13 ZJ Grand Cherokee Forum 0 12-04-2006 05:02 PM
Measurements... gdupjeep ZJ Grand Cherokee Forum 9 04-22-2006 02:42 PM
