lift completed...tires next - Page 2 - JeepForum.com
post #16 of 29 Old 01-13-2012, 02:33 PM
naidib04
2006 WK
I have the Firestone Destination M/T in 265/70/17 and they are wearing very well for me. Been around 12k miles and still have 18-19/32 tread left. Great in mud, dry, and wet pavements. Snow is about a 6 out of 10. As far as road noise they hum a lot but with my intake and exhaust I for sure don't notice it.
PM me for details on Jeep
Blue WK Club Member #35
naidib04 is offline
post #17 of 29 Old 01-13-2012, 03:46 PM
t3kmitch
2005 WK
Originally Posted by dferr17 View Post
Everyone seems to love the look without the lower air dam. I just dont know if im sold on it yet. I might remove it, drive it around for a little and see if it grows on me. If i get the front skid i might be forced to remove it unless i could figure out a way of modding the air dam and making custom brackets.
I thought it looked weird at first but now I think they look weird with them on. They look like they have more lift with it off.
Also I've read the air dam will fit on over the top of the skid, you just can't utilize the middle tabs.
-Sold 3/13. Replaced by 2010 VW Jetta 2.5-
2005 WK 3.7L Laredo. RC 2", 265 70 17 Bridgestone Dueler Revo 2's. Class III OEM hitch added. Bilstein Struts. Monroe Load Levelers (58643).
Blue WK Club Member #32
t3kmitch is offline
post #18 of 29 Old 01-13-2012, 03:57 PM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
Just do it!
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is offline
post #19 of 29 Old 01-13-2012, 04:32 PM
mattydipps
2006 WK
mine came with the lower air dam off and i went out and bought one to put it back on ...
i think once i put front recovery points on and a little bigger tires ill take the air dam off... i just think itll look way too ... empty in the front.
Sold-
mattydipps is offline
post #20 of 29 Old 01-24-2012, 02:22 PM Thread Starter
dferr17
2007 WK
OK, since the last time i posted photos i added the HIR 9012 bulbs the meep or someone talked about (ordered them off Amazon for 21 a piece.) and today i put on the General Grabber AT2. 265/70. The tires make a big difference for sure.
dferr17 is offline
post #21 of 29 Old 01-24-2012, 04:12 PM
JeepN4KC
JeepN4KC's Avatar
^^^ Wow! That last pic makes it look really close to the bolt. But as long as it clears.
~Mike~
WK
XJ
JeepN4KC is offline
post #22 of 29 Old 01-24-2012, 05:38 PM
SSF556
2008 WK
I would say that on a 2" lift...265/70 is probably the biggest you can go...looks good though.
Silver WK Club Member #1
2008 CRD QT2
SSF556 is offline
post #23 of 29 Old 01-24-2012, 06:12 PM Thread Starter
dferr17
2007 WK
Yep, the wheel clears the bolt. From some of the other pics i saw i didnt think i would have needed to cut that much off. There is a slight rub on the sway bar when the wheel is turned to full lock. But yea, without spacers and just the 2'' lift i think thats as big as i couldve went with the Generals.
dferr17 is offline
post #24 of 29 Old 01-24-2012, 06:23 PM
corswandtm
2007 WK
Any clunk noise dfer?
2007 WK Red Rock Limited - 5.7 HEMI w/QD-II - Stainless 22" Magnaflow muffler - AFE Stage 2 CAI - Bilstein HD shocks/struts - JBA Strut Spacers - 245-70/17 Firestone Destination AT
corswandtm is offline
post #25 of 29 Old 01-24-2012, 06:43 PM Thread Starter
dferr17
2007 WK
clunk noise as in what or from where? Only noise i heard was when i turned the wheel all the way and heard the tread rubbing slightly against the sway bar, that was it.
dferr17 is offline
post #26 of 29 Old 01-25-2012, 07:35 AM
corswandtm
2007 WK
A lot of chatter on here about a clunk noise, usually from the rear, when going over bumps after the spacer lift is installed. Some have it and some don't it seems.
post #27 of 29 Old 01-25-2012, 07:59 AM
Budasac
2005 WK
Looks good dferr. What are your thoughts on the HIR bulbs. Much of an improvement?
If you have a "clunk" noise after installing a lift it's because A: something is loose, or B: you have a bad bushing somewhere.
Typically it's in the front and either the top strut bolt or the sway bushings. If it's in the rear it would likely be the rear shock mount. (if the shocks were changed)
Budasac is online now
post #28 of 29 Old 01-25-2012, 09:59 AM Thread Starter
dferr17
2007 WK
Nope havent had any clunks or weird noises after the lift or tires. I'll be sure to keep an ear open
As for the HIR bulbs, i havent test driven it on the road yet to get a feel for what sort of improvements they are over the stock halogens. However, they do look to be a bit brighter and whiter from what i can tell inside the garage. I'll let you know after i drive at night what sort of difference there is
dferr17 is offline
post #29 of 29 Old 01-25-2012, 01:41 PM
yetti182
2007 WK
265/70/17 Nitto Grapplers just got to my house. They look like school bus tires. I'm a little intimidated. Glad I didn't go bigger. Tread is exactly what I wanted tho.
07 Black Jeep WK Rky Mtn Edt. 3.7L
2" RC Lift/1.5" RC Spacers
265/70/17 Nitto Terra Grapplers
yetti182 is offline
daystar , lift , limited , tires
Lift completed, Adjustable Trackbar needed ASAP SDT03GCOverland ZJ Grand Cherokee Forum 8 08-10-2009 10:46 PM
Lift Completed... PICS Yardman Harry ZJ Grand Cherokee Forum 24 07-17-2007 05:10 PM
Additional lift completed SpeedyCat3 ZJ Grand Cherokee Forum 31 06-09-2007 10:53 AM
just completed the job TravisL1213 ZJ Grand Cherokee Forum 3 02-24-2007 10:47 AM
Poll. tires with rims, or tires with lift. Derek33 ZJ Grand Cherokee Forum 2 03-15-2005 05:43 PM
